183 bool *auto_variables,
250 const char **labels);
294 void *p_define_input);
322 const int *writer_ids);
395 const fvm_nodal_t *location_mesh);
410 const char *mesh_name);
425 const char *mesh_name);
496 int mesh_location_id);
cs_probe_set_t * cs_probe_set_create_from_local(const char *name, cs_probe_set_define_local_t *p_define_func, void *p_define_input)
Define a new set of probes from rank-local definition function.
Definition: cs_probe.c:801
fvm_nodal_t * cs_probe_set_unlocated_export_mesh(cs_probe_set_t *pset, const char *mesh_name)
Define a fvm_nodal_t structure from the set of unlocated probes.
Definition: cs_probe.c:1439
void cs_probe_set_add_probe(cs_probe_set_t *pset, cs_real_t x, cs_real_t y, cs_real_t z, const char *label)
Add a new probe to an existing set of probes.
Definition: cs_probe.c:645
fvm_nodal_t * cs_probe_set_export_mesh(cs_probe_set_t *pset, const char *mesh_name)
Define a fvm_nodal_t structure from the set of probes.
Definition: cs_probe.c:1302
int cs_probe_set_get_n_local(const cs_probe_set_t *pset)
Return the number probes in the local domain.
Definition: cs_probe.c:1600
void cs_probe_set_snap_mode(cs_probe_set_t *pset, cs_probe_snap_t snap_mode)
Set snap mode related to the management of a set of probes.
Definition: cs_probe.c:899
void cs_probe_set_get_members(const cs_probe_set_t *pset, cs_probe_snap_t *snap_mode, int *n_probes, cs_real_3_t *coords[])
Retrieve the main members of a cs_probe_set_t structure.
Definition: cs_probe.c:1569
cs_probe_set_t * cs_probe_set_get(const char *name)
Retrieve a cs_probe_set_t structure.
Definition: cs_probe.c:488
int cs_probe_get_n_sets(void)
Retrieve the number of probe sets defined.
Definition: cs_probe.c:472
Definition: cs_defs.h:467
const char * cs_probe_set_get_name(cs_probe_set_t *pset)
Retrieve the name related to a cs_probe_set_t structure.
Definition: cs_probe.c:538
void cs_probe_set_associate_writers(cs_probe_set_t *pset, int n_writers, const int *writer_ids)
Associate a list of writers to a probe set.
Definition: cs_probe.c:847
void cs_probe_set_allow_overwrite(const char *name)
allow overwriting the definition of a given probe set.
Definition: cs_probe.c:828
Definition: cs_defs.h:302
const char * cs_probe_set_get_location_criteria(cs_probe_set_t *pset)
Return the location filter selection criteria string for a given probe set.
Definition: cs_probe.c:602
void cs_probe_set_locate(cs_probe_set_t *pset, const fvm_nodal_t *location_mesh)
Try to locate each probe and define the coordinate really used for the postprocessing step...
Definition: cs_probe.c:1021
cs_probe_snap_t
Definition: cs_probe.h:55
Definition: cs_probe.h:58
void cs_probe_set_get_post_info(const cs_probe_set_t *pset, bool *time_varying, bool *on_boundary, bool *on_curve, bool *auto_variables, int *n_writers, int *writer_ids[])
Retrieve information useful for the postprocessing step.
Definition: cs_probe.c:564
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:315
const cs_real_t * cs_probe_set_get_curvilinear_abscissa(const cs_probe_set_t *pset)
Return the list of curvilinear abscissa for the given probe set.
Definition: cs_probe.c:1621
const cs_lnum_t * cs_probe_set_get_elt_ids(const cs_probe_set_t *pset, int mesh_location_id)
Return the ids of a probe set's local matching elements, relative to a given mesh location...
Definition: cs_probe.c:1645
cs_probe_set_t * cs_probe_set_create_from_array(const char *name, int n_probes, const cs_real_3_t *coords, const char **labels)
Define a new set of probes from an array of coordinates.
Definition: cs_probe.c:693
void cs_probe_set_dump(const cs_probe_set_t *pset)
Dump a cs_probe_set_t structure.
Definition: cs_probe.c:1519
Definition: cs_defs.h:298
void cs_probe_finalize(void)
Free all structures related to a set of probes.
Definition: cs_probe.c:451
cs_probe_set_t * cs_probe_set_create(const char *name)
Create a new set of probes.
Definition: cs_probe.c:621
Definition: cs_probe.h:59
Definition: cs_defs.h:468
void cs_probe_set_option(cs_probe_set_t *pset, const char *keyname, const char *keyval)
Set optional parameters related to the management of a set of probes.
Definition: cs_probe.c:931
struct _cs_probe_set_t cs_probe_set_t
Definition: cs_probe.h:53
cs_probe_set_t * cs_probe_set_create_from_segment(const char *name, int n_probes, const cs_real_t start_coords[3], const cs_real_t end_coords[3])
Define a new set of probes from the segment spanned by two points.
Definition: cs_probe.c:733
void cs_probe_set_auto_var(cs_probe_set_t *pset, bool mode)
Set to true or false the automatic post-processing of variables.
Definition: cs_probe.c:875
cs_probe_set_t * cs_probe_set_get_by_id(int pset_id)
Retrieve a cs_probe_set_t structure from its id.
Definition: cs_probe.c:518
Definition: cs_probe.h:57
void() cs_probe_set_define_local_t(void *input, cs_lnum_t *n_elts, cs_real_3_t **coords, cs_real_t **s)
Function pointer to definition of probes based on rank-local points.
Definition: cs_probe.h:89
