Post-processing management. More...
#include "cs_defs.h"#include <assert.h>#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_mem.h"#include "bft_printf.h"#include "fvm_nodal.h"#include "fvm_nodal_append.h"#include "fvm_nodal_extract.h"#include "cs_base.h"#include "cs_boundary_zone.h"#include "cs_field.h"#include "cs_file.h"#include "cs_lagr_extract.h"#include "cs_log.h"#include "cs_lagr_query.h"#include "cs_mesh.h"#include "cs_mesh_connect.h"#include "cs_mesh_location.h"#include "cs_parall.h"#include "cs_prototypes.h"#include "cs_selector.h"#include "cs_timer.h"#include "cs_timer_stats.h"#include "cs_volume_zone.h"#include "cs_post.h"
| void | cs_post_define_writer (int writer_id, const char *case_name, const char *dir_name, const char *fmt_name, const char *fmt_opts, fvm_writer_time_dep_t time_dep, bool output_at_start, bool output_at_end, int frequency_n, double frequency_t) |
| Define a writer; this objects manages a case's name, directory, and format, as well as associated mesh's time dependency, and the default output frequency for associated variables. More... | |
| void | cs_post_define_volume_mesh (int mesh_id, const char *mesh_name, const char *cell_criteria, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[]) |
| Define a volume post-processing mesh. More... | |
| void | cs_post_define_volume_mesh_by_func (int mesh_id, const char *mesh_name, cs_post_elt_select_t *cell_select_func, void *cell_select_input, bool time_varying, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[]) |
| Define a volume post-processing mesh using a selection function. More... | |
| void | cs_post_define_surface_mesh (int mesh_id, const char *mesh_name, const char *i_face_criteria, const char *b_face_criteria, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[]) |
| Define a surface post-processing mesh. More... | |
| void | cs_post_define_surface_mesh_by_func (int mesh_id, const char *mesh_name, cs_post_elt_select_t *i_face_select_func, cs_post_elt_select_t *b_face_select_func, void *i_face_select_input, void *b_face_select_input, bool time_varying, bool add_groups, bool auto_variables, int n_writers, const int writer_ids[]) |
| Define a surface post-processing mesh using selection functions. More... | |
| void | cs_post_define_particles_mesh (int mesh_id, const char *mesh_name, const char *cell_criteria, double density, bool trajectory, bool auto_variables, int n_writers, const int writer_ids[]) |
| Define a particles post-processing mesh. More... | |
| void | cs_post_define_particles_mesh_by_func (int mesh_id, const char *mesh_name, cs_post_elt_select_t *p_select_func, void *p_select_input, bool trajectory, bool auto_variables, int n_writers, const int writer_ids[]) |
| Define a particles post-processing mesh using a selection function. More... | |
| void | cs_post_define_existing_mesh (int mesh_id, fvm_nodal_t *exp_mesh, int dim_shift, bool transfer, bool auto_variables, int n_writers, const int writer_ids[]) |
| Create a post-processing mesh associated with an existing exportable mesh representation. More... | |
| void | cs_post_define_edges_mesh (int mesh_id, int base_mesh_id, int n_writers, const int writer_ids[]) |
| Create a mesh based upon the extraction of edges from an existing mesh. More... | |
| void | cs_post_mesh_attach_writer (int mesh_id, int writer_id) |
| Associate a writer to a postprocessing mesh. More... | |
| void | cs_post_mesh_detach_writer (int mesh_id, int writer_id) |
| De-associate a writer from a postprocessing mesh. More... | |
| const int * | cs_post_mesh_get_ent_flag (int mesh_id) |
| Get a postprocessing meshes entity presence flag. More... | |
| cs_lnum_t | cs_post_mesh_get_n_cells (int mesh_id) |
| Get a postprocessing mesh's number of cells. More... | |
| void | cs_post_mesh_get_cell_ids (int mesh_id, cs_lnum_t *cell_ids) |
| Get a postprocessing mesh's list of cells. More... | |
| cs_lnum_t | cs_post_mesh_get_n_i_faces (int mesh_id) |
| Get a postprocessing mesh's number of interior faces. More... | |
| void | cs_post_mesh_get_i_face_ids (int mesh_id, cs_lnum_t i_face_ids[]) |
| Get a postprocessing mesh's list of boundary faces. More... | |
| cs_lnum_t | cs_post_mesh_get_n_b_faces (int mesh_id) |
| Get a postprocessing mesh's number of boundary faces. More... | |
| void | cs_post_mesh_get_b_face_ids (int mesh_id, cs_lnum_t b_face_ids[]) |
| cs_lnum_t | cs_post_mesh_get_n_vertices (int mesh_id) |
| Get a postprocessing mesh's number of vertices. More... | |
| void | cs_post_mesh_get_vertex_ids (int mesh_id, cs_lnum_t *vertex_ids) |
| Get a postprocessing mesh's list of vertices. More... | |
| void | cs_post_mesh_set_post_domain (int mesh_id, bool post_domain) |
| Set whether postprocessing mesh's parallel domain should be output. More... | |
| void | cs_post_free_mesh (int mesh_id) |
| Remove a post-processing mesh. More... | |
| bool | cs_post_writer_exists (int writer_id) |
| Check for the existence of a writer of the given id. More... | |
| bool | cs_post_mesh_exists (int mesh_id) |
| Check for the existence of a post-processing mesh of the given id. More... | |
| const char * | cs_post_get_default_format (void) |
| Return the default writer format name. More... | |
| const char * | cs_post_get_default_format_options (void) |
| Return the default writer format options. More... | |
| int | cs_post_get_free_writer_id (void) |
| Return the next "reservable" (i.e. non-user) writer id available. More... | |
| int | cs_post_get_free_mesh_id (void) |
| Return the next "reservable" (i.e. non-user) mesh id available. More... | |
| void | cs_post_activate_by_time_step (const cs_time_step_t *ts) |
| Update "active" or "inactive" flag of writers based on the time step. More... | |
| void | cs_post_activate_writer (int writer_id, bool activate) |
| Force the "active" or "inactive" flag for a specific writer or for all writers for the current time step. More... | |
| void | cs_post_disable_writer (int writer_id) |
| Disable specific writer or all writers not currently active until cs_post_enable_writer or cs_post_activate_writer is called for those writers. More... | |
| void | cs_post_enable_writer (int writer_id) |
| Enable a specific writer or all writers currently disabled by previous calls to cs_post_disable_writer. More... | |
| fvm_writer_t * | cs_post_get_writer (int writer_id) |
| Return a pointer to the FVM writer associated to a writer_id. More... | |
| fvm_writer_time_dep_t | cs_post_get_writer_time_dep (int writer_id) |
| Return time dependency associated to a writer_id. More... | |
| void | cs_post_add_writer_t_step (int writer_id, int nt) |
| Add an activation time step for a specific writer or for all writers. More... | |
| void | cs_post_add_writer_t_value (int writer_id, double t) |
| Add an activation time value for a specific writer or for all writers. More... | |
| void | cs_post_write_meshes (const cs_time_step_t *ts) |
| Output post-processing meshes using associated writers. More... | |
| void | cs_post_write_var (int mesh_id, int writer_id, const char *var_name, int var_dim, bool interlace, bool use_parent, cs_post_type_t var_type, const void *cel_vals, const void *i_face_vals, const void *b_face_vals, const cs_time_step_t *ts) |
| Output a variable defined at cells or faces of a post-processing mesh using associated writers. More... | |
| void | cs_post_write_vertex_var (int mesh_id, int writer_id, const char *var_name, int var_dim, bool interlace, bool use_parent, cs_post_type_t var_type, const void *vtx_vals, const cs_time_step_t *ts) |
| Output a variable defined at vertices of a post-processing mesh using associated writers. More... | |
| void | cs_post_write_particle_values (int mesh_id, int writer_id, int attr_id, const char *var_name, int component_id, const cs_time_step_t *ts) |
| Output an existing lagrangian particle attribute at particle positions or trajectory endpoints of a particle mesh using associated writers. More... | |
| void | cs_post_write_probe_values (int mesh_id, int writer_id, const char *var_name, int var_dim, cs_post_type_t var_type, int parent_location_id, cs_interpolate_from_location_t *interpolate_func, void *interpolate_input, const void *vals, const cs_time_step_t *ts) |
| void | cs_post_renum_cells (const cs_lnum_t init_cell_num[]) |
| Update references to parent mesh of post-processing meshes in case of computational mesh cell renumbering. More... | |
| void | cs_post_renum_faces (const cs_lnum_t init_i_face_num[], const cs_lnum_t init_b_face_num[]) |
| Update references to parent mesh of post-processing meshes in case of computational mesh interior and/or boundary faces renumbering. More... | |
| void | cs_post_set_deformable (void) |
| Configure the post-processing output so that a mesh displacement field may be output automatically for meshes based on the global volume mesh. More... | |
| void | cs_post_set_changing_connectivity (void) |
| Configure the post-processing output so that mesh connectivity may be automatically updated. More... | |
| void | cs_post_init_writers (void) |
| Initialize post-processing writers. More... | |
| void | cs_post_init_meshes (int check_mask) |
| Initialize main post-processing meshes. More... | |
| void | cs_post_time_step_begin (const cs_time_step_t *ts) |
| Check if post-processing is activated and then update post-processing of meshes if there is a need to update time-dependent meshes. More... | |
| void | cs_post_time_step_output (const cs_time_step_t *ts) |
| Loop on post-processing meshes to output variables. More... | |
| void | cs_post_time_step_end (void) |
| Flush writers and free time-varying and Lagragian mesh if needed of meshes if there is a time-dependent mesh. More... | |
| void | cs_post_write_vars (const cs_time_step_t *ts) |
| void | cs_post_finalize (void) |
| Destroy all structures associated with post-processing. More... | |
| void | cs_post_add_free_faces (void) |
| Postprocess free (isolated) faces of the current global mesh. More... | |
| void | cs_post_init_error_writer (void) |
| Initialize post-processing writer with same format and associated options as default writer, but no time dependency, intended to troubleshoot errors. More... | |
| int | cs_post_init_error_writer_cells (void) |
| Initialize post-processing writer with same format and associated options as default writer, but no time dependency, and associate and output global volume mesh. More... | |
| void | cs_post_add_time_dep_output (cs_post_time_dep_output_t *function, void *input) |
| Register a processing of time-dependent variables to the call to cs_post_write_vars(). More... | |
| void | cs_post_add_time_mesh_dep_output (cs_post_time_mesh_dep_output_t *function, void *input) |
| Register a processing of time-dependent variables than can be output on different meshes to the call to cs_post_write_vars(). More... | |
| void cs_post_activate_by_time_step | ( | const cs_time_step_t * | ts | ) |
Writers are activated if their output frequency is a divisor of the current time step, or if their optional time step and value output lists contain matches for the current time step.
| [in] | ts | time step status structure |
| void cs_post_activate_writer | ( | int | writer_id, |
| bool | activate | ||
| [in] | writer_id | writer id, or 0 for all writers |
| [in] | activate | false to deactivate, true to activate |
| void cs_post_add_free_faces | ( | void | ) |
| void cs_post_add_time_dep_output | ( | cs_post_time_dep_output_t * | function, |
| void * | input | ||
Note: if the input pointer is non-NULL, it must point to valid data when the output function is called, so either:
| [in] | function | function to register |
| [in,out] | input | pointer to optional (untyped) value or structure |
| void cs_post_add_time_mesh_dep_output | ( | cs_post_time_mesh_dep_output_t * | function, |
| void * | input | ||
| void cs_post_add_writer_t_step | ( | int | writer_id, |
| int | nt | ||
If a negative value is provided, a previously added activation time step matching that absolute value will be removed, if present.
| [in] | nt | time step value to add (or remove) |
| void cs_post_add_writer_t_value | ( | int | writer_id, |
| double | t | ||
| [in] | t | time value to add (or remove) |
| void cs_post_define_edges_mesh | ( | int | mesh_id, |
| int | base_mesh_id, | ||
| int | n_writers, | ||
| const int | writer_ids[] | ||
The newly created edges have no link to their parent elements, so no variable referencing parent elements may be output to this mesh, whose main use is to visualize "true" face edges when polygonal faces are subdivided by the writer. In this way, even highly non-convex faces may be visualized correctly if their edges are overlaid on the surface mesh with subdivided polygons.
| [in] | mesh_id | id of edges mesh to create (< 0 reserved, > 0 for user) |
| [in] | base_mesh_id | id of existing mesh (< 0 reserved, > 0 for user) |
| [in] | n_writers | number of associated writers |
| [in] | writer_ids | ids of associated writers |
| void cs_post_define_existing_mesh | ( | int | mesh_id, |
| fvm_nodal_t * | exp_mesh, | ||
| int | dim_shift, | ||
| bool | transfer, | ||
| bool | auto_variables, | ||
If the exportable mesh is not intended to be used elsewhere, one can choose to transfer its property to the post-processing mesh, which will then manage its lifecycle based on its own requirements.
If the exportable mesh must still be shared, one must be careful to maintain consistency between this mesh and the post-processing output.
The mesh in exportable dimension may be of a lower dimension than its parent mesh, if it has been projected. In this case, a dim_shift value of 1 indicates that parent cells are mapped to exportable faces, and faces to edges, while a dim_shift value of 2 would indicate that parent cells are mapped to edges. This is important when variables values are exported.
| [in] | mesh_id | id of mesh to define (< 0 reserved, > 0 for user) |
| [in] | exp_mesh | mesh in exportable representation (i.e. fvm_nodal_t) |
| [in] | dim_shift | nonzero if exp_mesh has been projected |
| [in] | transfer | if true, ownership of exp_mesh is transferred to the post-processing mesh |
| [in] | auto_variables | if true, automatic output of main variables |
| void cs_post_define_particles_mesh | ( | int | mesh_id, |
| const char * | mesh_name, | ||
| const char * | cell_criteria, | ||
| double | density, | ||
| bool | trajectory, | ||
Such a mesh is always time-varying, and will only be output by writers defined with the FVM_WRITER_TRANSIENT_CONNECT option.
If the trajectory_mode argument is set to true, this logic is reversed, and output will only occur for writers defined with the FVM_WRITER_FIXED_MESH option. In this case, a submesh consisting of trajectory segments for the current time step will be added to the output at each output time step.
| [in] | mesh_name | associated mesh name |
| [in] | cell_criteria | selection criteria for cells containing particles, or NULL. |
| [in] | density | fraction of the particles in the selected area which should be output (0 < density <= 1) |
| [in] | trajectory | if true, activate trajectory mode |
| void cs_post_define_particles_mesh_by_func | ( | int | mesh_id, |
| cs_post_elt_select_t * | p_select_func, | ||
| void * | p_select_input, | ||
The selection may be updated over time steps.
Note: if the p_select_input pointer is non-NULL, it must point to valid data when the selection function is called, so that value or structure should not be temporary (i.e. local);
| [in] | p_select_func | pointer to particles selection function |
| [in] | p_select_input | pointer to optional input data for the particles selection function, or NULL |
| void cs_post_define_surface_mesh | ( | int | mesh_id, |
| const char * | i_face_criteria, | ||
| const char * | b_face_criteria, | ||
| bool | add_groups, | ||
| [in] | i_face_criteria | selection criteria for interior faces |
| [in] | b_face_criteria | selection criteria for boundary faces |
| [in] | add_groups | if true, add group information if present |
| void cs_post_define_surface_mesh_by_func | ( | int | mesh_id, |
| cs_post_elt_select_t * | i_face_select_func, | ||
| cs_post_elt_select_t * | b_face_select_func, | ||
| void * | i_face_select_input, | ||
| void * | b_face_select_input, | ||
| bool | time_varying, | ||
The selection may be updated over time steps if both the time_varying flag is set to true and the mesh is only associated with writers defined with the FVM_WRITER_TRANSIENT_CONNECT option.
Note: if i_face_select_input or b_face_select_input pointer is non-NULL, it must point to valid data when the selection function is called, so either:
| [in] | i_face_select_func | pointer to interior faces selection function |
| [in] | b_face_select_func | pointer to boundary faces selection function |
| [in] | i_face_select_input | pointer to optional input data for the interior faces selection function, or NULL |
| [in] | b_face_select_input | pointer to optional input data for the boundary faces selection function, or NULL |
| [in] | time_varying | if true, try to redefine mesh at each output time |
| void cs_post_define_volume_mesh | ( | int | mesh_id, |
| [in] | cell_criteria | selection criteria for cells |
| void cs_post_define_volume_mesh_by_func | ( | int | mesh_id, |
| cs_post_elt_select_t * | cell_select_func, | ||
| void * | cell_select_input, | ||
Note: if the cell_select_input pointer is non-NULL, it must point to valid data when the selection function is called, so either:
| [in] | cell_select_func | pointer to cells selection function |
| [in] | cell_select_input | pointer to optional input data for the cell selection function, or NULL |
| void cs_post_define_writer | ( | int | writer_id, |
| const char * | case_name, | ||
| const char * | dir_name, | ||
| const char * | fmt_name, | ||
| const char * | fmt_opts, | ||
| fvm_writer_time_dep_t | time_dep, | ||
| bool | output_at_start, | ||
| bool | output_at_end, | ||
| int | frequency_n, | ||
| double | frequency_t | ||
This function must be called before the time loop. If a writer with a given id is defined multiple times, the last definition supercedes the previous ones.
Current reserved ids are the following: CS_POST_WRITER_DEFAULT for main/default output, CS_POST_WRITER_ERRORS for error visualization, CS_POST_WRITER_PROBES for main probes, CS_POST_WRITER_PARTICLES for particles, CS_POST_WRITER_TRAJECTORIES for trajectories. Other negative ids may be dynamically reserved by the code depending on options. Positive ids identify user-defined writers.
The format_name argument is used to choose the output format, and the following values are allowed (assuming the matching support was built):
EnSight Gold (EnSight also accepted)MED CGNS CCM (only for the full volume and boundary meshes)Catalyst (in-situ visualization)MEDCoupling (in-memory structure, to be used from other code)plot (comma or whitespace separated 2d plot files)time_plot (comma or whitespace separated time plot files)The format name is case-sensitive, so ensight or cgns are also valid.
The optional fmt_opts character string contains a list of options related to the format, separated by spaces or commas; these options include:
binary for a binary format version (default)big_endian to force outputs to be in big-endian mode (for EnSight).text for a text format version (for EnSight).adf for ADF file type (for CGNS).hdf5 for HDF5 file type (for CGNS, normally the default if HDF5 support is available).discard_polygons to prevent from exporting faces with more than four edges (which may not be recognized by some post-processing tools); such faces will therefore not appear in the post-processing mesh.discard_polyhedra to prevent from exporting elements which are neither tetrahedra, prisms, pyramids nor hexahedra (which may not be recognized by some post-processing tools); such elements will therefore not appear in the post-processing mesh.divide_polygons to divide faces with more than four edges into triangles, so that any post-processing tool can recognize them.divide_polyhedra} to divide elements which are neither tetrahedra, prisms, pyramids nor hexahedra into simpler elements (tetrahedra and pyramids), so that any post-processing tool can recognize them.separate_meshes to multiple meshes and associated fields to separate outputs.Note that the white-spaces in the beginning or in the end of the character strings given as arguments here are suppressed automatically.
| [in] | writer_id | id of writer to create. (< 0 reserved, > 0 for user); eveb for reserved ids, the matching writer's options may be redifined by calls to this function |
| [in] | case_name | associated case name |
| [in] | dir_name | associated directory name |
| [in] | fmt_name | associated format name |
| [in] | fmt_opts | associated format options string |
| [in] | time_dep | FVM_WRITER_FIXED_MESH if mesh definitions are fixed, FVM_WRITER_TRANSIENT_COORDS if coordinates change, FVM_WRITER_TRANSIENT_CONNECT if connectivity changes |
| [in] | output_at_start | force output at calculation start if true |
| [in] | output_at_end | force output at calculation end if true |
| [in] | frequency_n | default output frequency in time-steps, or < 0 |
| [in] | frequency_t | default output frequency in seconds, or < 0 (has priority over frequency_n) |
| void cs_post_disable_writer | ( | int | writer_id | ) |
For each call to this function for a given writer, the same number of calls to cs_post_enable_writer or a single call to cs_post_activate_writer is required to re-enable the writer.
This is useful to disable output even of fixed meshes in preprocessing stages.
| void cs_post_enable_writer | ( | int | writer_id | ) |
For each previous call to cs_post_disable_writer for a given writer, a call to this function (or a single call to cs_post_activate_writer) is required to re-enable the writer.
| void cs_post_finalize | ( | void | ) |
| void cs_post_free_mesh | ( | int | mesh_id | ) |
No further post-processing output will be allowed on this mesh, so the associated structures may be freed.
A post-processing mesh that has been associated with a time-varying writer may not be removed.
| [in] | mesh_id | postprocessing mesh id |
| const char* cs_post_get_default_format | ( | void | ) |
| const char* cs_post_get_default_format_options | ( | void | ) |
| int cs_post_get_free_mesh_id | ( | void | ) |
| int cs_post_get_free_writer_id | ( | void | ) |
| fvm_writer_t* cs_post_get_writer | ( | int | writer_id | ) |
| [in] | writer_id | associated writer id |
| fvm_writer_time_dep_t cs_post_get_writer_time_dep | ( | int | writer_id | ) |
| void cs_post_init_error_writer | ( | void | ) |
| int cs_post_init_error_writer_cells | ( | void | ) |
This is intended to help troubleshoot errors using fields based on cells.
| void cs_post_init_meshes | ( | int | check_mask | ) |
The check_flag variable is a mask, used for additionnal post-processing:
It is recommended that post-processing meshes be defined before calling this function, though specific "automatic" meshes (for example those related to couplings) may be defined between this call and a time loop.
| [in] | check_mask | mask used for additional output |
| void cs_post_init_writers | ( | void | ) |
| void cs_post_mesh_attach_writer | ( | int | mesh_id, |
| int | writer_id | ||
This function must be called during the postprocessing output definition stage, before any output actually occurs.
If called with a non-existing mesh or writer id, or if the writer is already associated, no setting is changed, and this function returns silently.
| [in] | writer_id | id of writer to associate |
| void cs_post_mesh_detach_writer | ( | int | mesh_id, |
If called with a non-existing mesh or writer id, or if the writer was not previously associated, no setting is changed, and this function returns silently.
| bool cs_post_mesh_exists | ( | int | mesh_id | ) |
| [in] | mesh_id | mesh id to check |
| void cs_post_mesh_get_b_face_ids | ( | int | mesh_id, |
| cs_lnum_t | b_face_ids[] | ||
The array of boundary face ids must be of at least size cs_post_mesh_get_n_b_faces(mesh_id).
| [out] | b_face_ids | array of associated boundary faces ids (0 to n-1 numbering, relative to main mesh) |
| void cs_post_mesh_get_cell_ids | ( | int | mesh_id, |
| cs_lnum_t * | cell_ids | ||
The array of cell ids must be of at least size cs_post_mesh_get_n_cells(mesh_id).
| [out] | cell_ids | array of associated cell ids (0 to n-1 numbering, relative to main mesh) |
| const int* cs_post_mesh_get_ent_flag | ( | int | mesh_id | ) |
This flag is an array of 3 integers, indicating the presence of elements of given types on at least one subdomain (i.e. rank): 0: presence of cells 1: presence of interior faces 2: presence of boundary faces
| void cs_post_mesh_get_i_face_ids | ( | int | mesh_id, |
| cs_lnum_t | i_face_ids[] | ||
| [out] | i_face_ids | array of associated interior faces ids (0 to n-1 numbering, relative to main mesh) |
| cs_lnum_t cs_post_mesh_get_n_b_faces | ( | int | mesh_id | ) |
| cs_lnum_t cs_post_mesh_get_n_cells | ( | int | mesh_id | ) |
| cs_lnum_t cs_post_mesh_get_n_i_faces | ( | int | mesh_id | ) |
| cs_lnum_t cs_post_mesh_get_n_vertices | ( | int | mesh_id | ) |
| void cs_post_mesh_get_vertex_ids | ( | int | mesh_id, |
| cs_lnum_t * | vertex_ids | ||
The array of vertex ids must be of at least size cs_post_mesh_get_n_vertices(mesh_id).
| [out] | vertex_ids | array of associated vertex ids (0 to n-1 numbering, relative to main mesh) |
| void cs_post_mesh_set_post_domain | ( | int | mesh_id, |
| bool | post_domain | ||
| [in] | post_domain | true if parallel domain should be output, false otherwise. |
| void cs_post_renum_cells | ( | const cs_lnum_t | init_cell_num[] | ) |
This function may be called only once, after possible renumbering of cells, to update existing post-processing meshes. Post-processing meshes defined after renumbering will automatically be based upon the new numbering, so this function will not need to be called again.
| [in] | init_cell_num | initial cell numbering (new -> old) |
This function may be called only once, after possible renumbering of faces, to update existing post-processing meshes. Post-processing meshes defined after renumbering will automatically be based upon the new numbering, so this function will not need to be called again.
| [in] | init_i_face_num | initial interior numbering (new -> old) |
| [in] | init_b_face_num | initial boundary numbering (new -> old) |
| void cs_post_set_changing_connectivity | ( | void | ) |
This is done for meshes defined using selection criteria or functions. The behavior of Lagrangian meshes is unchanged.
To be effective, this function should be called before defining postprocessing meshes.
| void cs_post_set_deformable | ( | void | ) |
| void cs_post_time_step_begin | ( | const cs_time_step_t * | ts | ) |
| [in] | ts | time step status structure, or NULL |
| void cs_post_time_step_end | ( | void | ) |
| void cs_post_time_step_output | ( | const cs_time_step_t * | ts | ) |
This handles all default fields output, as well as all registered output functions and outputs defined in cs_user_postprocess_values
| void cs_post_write_meshes | ( | const cs_time_step_t * | ts | ) |
If the time step structure argument passed is NULL, a time-independent output will be assumed.
| void cs_post_write_particle_values | ( | int | mesh_id, |
| int | writer_id, | ||
| int | attr_id, | ||
| int | component_id, | ||
| [in] | mesh_id | id of associated mesh |
| [in] | writer_id | id of specified associated writer, or CS_POST_WRITER_ALL_ASSOCIATED for all |
| [in] | attr_id | associated particle attribute id |
| [in] | var_name | name of variable to output |
| [in] | component_id | if -1 : extract the whole attribute if >0 : id of the component to extract |
| void cs_post_write_probe_values | ( | int | mesh_id, |
| int | var_dim, | ||
| cs_post_type_t | var_type, | ||
| int | parent_location_id, | ||
| cs_interpolate_from_location_t * | interpolate_func, | ||
| void * | interpolate_input, | ||
| const void * | vals, | ||
| [in] | var_dim | 1 for scalar, 3 for vector, 6 for symmetric tensor, 9 for non-symmetric tensor |
| [in] | var_type | variable's data type |
| [in] | parent_location_id | asociated values mesh location, or 0 if values are passed directly |
| [in] | interpolate_func | pointer to interpolation function, or NULL for default |
| [in] | interpolate_input | pointer to optional interpolation input data, or NULL for default |
| [in] | vals | variable's values |
| void cs_post_write_var | ( | int | mesh_id, |
| int | var_dim, | ||
| bool | interlace, | ||
| bool | use_parent, | ||
| const void * | cel_vals, | ||
| const void * | i_face_vals, | ||
| const void * | b_face_vals, | ||
| [in] | interlace | if a vector, true for interlaced values, false otherwise |
| [in] | use_parent | true if values are defined on "parent" mesh, false if values are defined on post-processing mesh |
| [in] | cel_vals | cell values |
| [in] | i_face_vals | interior face values |
| [in] | b_face_vals | boundary face values |
| void cs_post_write_vars | ( | const cs_time_step_t * | ts | ) |
| void cs_post_write_vertex_var | ( | int | mesh_id, |
| int | var_dim, | ||
| const void * | vtx_vals, | ||
| [in] | vtx_vals | vertex values |
| bool cs_post_writer_exists | ( | int | writer_id | ) |
| [in] | writer_id | writer id to check |
