◆ cs_interpolate_from_location_t
Function pointer for interpolatation of values defined on a mesh location at a given set of points.
- Parameters
| [in,out] | input | pointer to optional (untyped) value or structure. |
| [in] | datatype | associated datatype |
| [in] | val_dim | dimension of data values |
| [in] | n_points | number of interpolation points |
| [in] | point_location | location of points in mesh elements |
| [in] | location_vals | values at mesh location |
| [out] | point_vals | interpolated values at points |
◆ cs_interpolate_from_location_p0()
| void cs_interpolate_from_location_p0 |
void * |
input, |
cs_datatype_t |
datatype, |
int |
val_dim, |
cs_lnum_t |
n_points, |
const cs_lnum_t |
point_location[], |
const cs_real_3_t |
point_coords[], |
const void * |
location_vals, |
void * |
point_vals |
Interpolate values defined on a mesh location at a given set of points using a P0 interpolation.
This function allows unlocated points (with point_location < 0), to which the value 0 is assigned.
- Parameters
(DOXYGEN_SHOULD_SKIP_THIS)
- Parameters
