#include "cs_defs.h"#include <stdarg.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <math.h>#include <mpi.h>#include <MEDCoupling_version.h>#include <MEDCouplingUMesh.hxx>#include <MEDCouplingField.hxx>#include <MEDCouplingFieldDouble.hxx>#include <ParaFIELD.hxx>#include <ParaMESH.hxx>#include <InterpKernelDEC.hxx>#include "bft_error.h"#include "bft_mem.h"#include "bft_printf.h"#include "cs_mesh.h"#include "cs_mesh_connect.h"#include "cs_parall.h"#include "cs_prototypes.h"#include "cs_selector.h"#include "cs_timer.h"#include "fvm_defs.h"#include "fvm_nodal_from_desc.h"#include "cs_medcoupling_utils.hxx"#include "cs_paramedmem_coupling.hxx"
| static void | _init_mesh_coupling (cs_paramedmem_coupling_t *coupling, _paramedmem_mesh_t *mesh) |
| static void | _destroy_mesh (_paramedmem_mesh_t **mesh) |
| static InterpKernelDEC * | _cs_paramedmem_create_InterpKernelDEC (int *grp1_global_ranks, int grp1_size, int *grp2_global_ranks, int grp2_size) |
| cs_paramedmem_coupling_t * | cs_paramedmem_create (const char *name, InterpKernelDEC *send_dec, InterpKernelDEC *recv_dec) |
| static void | _add_paramedmem_interpkernel (const char *name, int *grp1_global_ranks, int grp1_size, int *grp2_global_ranks, int grp2_size) |
| cs_paramedmem_coupling_t * | cs_paramedmem_coupling_by_id (int pc_id) |
| cs_paramedmem_coupling_t * | cs_paramedmem_interpkernel_create (const char *name, int *grp1_global_ranks, int grp1_size, int *grp2_global_ranks, int grp2_size) |
| void | cs_paramedmem_destroy (cs_paramedmem_coupling_t **coupling) |
| int | cs_paramedmem_define_mesh (cs_paramedmem_coupling_t *coupling, const char *name, const char *select_criteria, int elt_dim, bool is_source, bool is_dest) |
| void | cs_paramedmem_init_meshes (cs_paramedmem_coupling_t *coupling) |
| int | cs_paramedmem_mesh_id (cs_paramedmem_coupling_t *coupling, const char *mesh_name) |
| cs_lnum_t | cs_paramedmem_mesh_get_n_elts (const cs_paramedmem_coupling_t *coupling, int mesh_id) |
| const cs_lnum_t * | cs_paramedmem_mesh_get_elt_list (const cs_paramedmem_coupling_t *coupling, int mesh_id) |
| int | cs_paramedmem_field_add (cs_paramedmem_coupling_t *coupling, const char *name, int mesh_id, int dim, int medcpl_field_type, int medcpl_time_discr, int dirflag) |
| int | cs_paramedmem_field_get_id (cs_paramedmem_coupling_t *coupling, int mesh_id, const char *name) |
| void | cs_paramedmem_field_export (cs_paramedmem_coupling_t *coupling, int field_id, bool on_parent, const double field_values[]) |
| void | cs_paramedmem_field_import (cs_paramedmem_coupling_t *coupling, int field_id, bool on_parent, double field_values[]) |
| void | cs_paramedmem_sync_dec (cs_paramedmem_coupling_t *coupling, int dec_to_sync) |
| void | cs_paramedmem_send_data (cs_paramedmem_coupling_t *coupling) |
| void | cs_paramedmem_recv_data (cs_paramedmem_coupling_t *coupling) |
| void | cs_paramedmem_reattach_field (cs_paramedmem_coupling_t *coupling, int field_id) |
| int * | cs_paramedmem_get_mpi_comm_world_ranks (void) |
| static int | _n_paramed_couplers = 0 |
| static cs_paramedmem_coupling_t ** | _paramed_couplers = NULL |
| const int | cs_medcpl_cell_field = 0 |
| const int | cs_medcpl_vertex_field = 1 |
| const int | cs_medcpl_no_time = 0 |
| const int | cs_medcpl_one_time = 1 |
| const int | cs_medcpl_linear_time = 2 |
static |
static |
static |
static |
| cs_paramedmem_coupling_t* cs_paramedmem_coupling_by_id | ( | int | pc_id | ) |
| cs_paramedmem_coupling_t* cs_paramedmem_create | ( | const char * | name, |
| InterpKernelDEC * | send_dec, | ||
| InterpKernelDEC * | recv_dec | ||
| int cs_paramedmem_define_mesh | ( | cs_paramedmem_coupling_t * | coupling, |
| const char * | name, | ||
| const char * | select_criteria, | ||
| int | elt_dim, | ||
| bool | is_source, | ||
| bool | is_dest | ||
| void cs_paramedmem_destroy | ( | cs_paramedmem_coupling_t ** | coupling | ) |
| int cs_paramedmem_field_add | ( | cs_paramedmem_coupling_t * | coupling, |
| int | mesh_id, | ||
| int | dim, | ||
| int | medcpl_field_type, | ||
| int | medcpl_time_discr, | ||
| int | dirflag | ||
| void cs_paramedmem_field_export | ( | cs_paramedmem_coupling_t * | coupling, |
| int | field_id, | ||
| bool | on_parent, | ||
| const double | field_values[] | ||
| int cs_paramedmem_field_get_id | ( | cs_paramedmem_coupling_t * | coupling, |
| int | mesh_id, | ||
| const char * | name | ||
| void cs_paramedmem_field_import | ( | cs_paramedmem_coupling_t * | coupling, |
| int* cs_paramedmem_get_mpi_comm_world_ranks | ( | void | ) |
| void cs_paramedmem_init_meshes | ( | cs_paramedmem_coupling_t * | coupling | ) |
| cs_paramedmem_coupling_t* cs_paramedmem_interpkernel_create | ( | const char * | name, |
| int * | grp1_global_ranks, | ||
| int | grp1_size, | ||
| int * | grp2_global_ranks, | ||
| int | grp2_size | ||
| const cs_lnum_t* cs_paramedmem_mesh_get_elt_list | ( | const cs_paramedmem_coupling_t * | coupling, |
| int | mesh_id | ||
| cs_lnum_t cs_paramedmem_mesh_get_n_elts | ( | const cs_paramedmem_coupling_t * | coupling, |
| int | mesh_id | ||
| int cs_paramedmem_mesh_id | ( | cs_paramedmem_coupling_t * | coupling, |
| const char * | mesh_name | ||
| void cs_paramedmem_reattach_field | ( | cs_paramedmem_coupling_t * | coupling, |
| int | field_id | ||
| void cs_paramedmem_recv_data | ( | cs_paramedmem_coupling_t * | coupling | ) |
| void cs_paramedmem_send_data | ( | cs_paramedmem_coupling_t * | coupling | ) |
| void cs_paramedmem_sync_dec | ( | cs_paramedmem_coupling_t * | coupling, |
| int | dec_to_sync | ||
static |
static |
| const int cs_medcpl_cell_field = 0 |
| const int cs_medcpl_linear_time = 2 |
| const int cs_medcpl_no_time = 0 |
| const int cs_medcpl_one_time = 1 |
| const int cs_medcpl_vertex_field = 1 |
