cs_medcoupling_utils.hxx
1 #ifndef __CS_MEDCOUPLING_UTILS_HXX__
2 #define __CS_MEDCOUPLING_UTILS_HXX__
5  * Usage of MEDCoupling base components.
30 #include "cs_defs.h"
36 #include <stdarg.h>
37 #include <stdio.h>
38 #include <stdlib.h>
39 #include <string.h>
41 #if defined(HAVE_MPI)
42 #include <mpi.h>
43 #endif
45 /*----------------------------------------------------------------------------
46  * MEDCOUPLING library headers
47  *----------------------------------------------------------------------------*/
48
49 #include <MEDCoupling_version.h>
50 #include <MEDCouplingUMesh.hxx>
51
52 using namespace MEDCoupling;
53
55
56 /*----------------------------------------------------------------------------
57  * MEDCoupling mesh structure
58  *----------------------------------------------------------------------------*/
59
60 typedef struct {
61
62  char *sel_criteria; /* Element selection criteria */
63
64  int elt_dim; /* Element dimension */
65
66  cs_lnum_t n_elts; /* Number of coupled elements */
67  cs_lnum_t *elt_list; /* List of associated elements
68  (0 to n-1) */
69  int *new_to_old; /* Connectivity used if only a section of
70  the mesh is read */
71
72  MEDCouplingUMesh *med_mesh; /* MED mesh structure */
73
74  cs_real_t *bbox; /* Bounding box to optimize search */
75
77
78 /*=============================================================================
79  * Public functions
80  *============================================================================*/
81
82 /* -------------------------------------------------------------------------- */
94 /* -------------------------------------------------------------------------- */
95
97 cs_medcoupling_mesh_create(const char *name,
98  const char *select_criteria,
99  int elt_dim);
100
101 /* -------------------------------------------------------------------------- */
113 /* -------------------------------------------------------------------------- */
114
115 void
117  cs_medcoupling_mesh_t *pmmesh,
118  int use_bbox);
119
120 /* -------------------------------------------------------------------------- */
127 /* -------------------------------------------------------------------------- */
128
129 void
131
132 /*----------------------------------------------------------------------------*/
133
135
136 #endif //__CS_MEDCOUPLING_UTILS_HXX__
Definition: cs_medcoupling_utils.hxx:60
void cs_medcoupling_mesh_copy_from_base(cs_mesh_t *csmesh, cs_medcoupling_mesh_t *pmmesh, int use_bbox)
copy a cs_mesh_t into a cs_medcoupling_mesh_t
Definition: cs_medcoupling_utils.cxx:552
cs_real_t * bbox
Definition: cs_medcoupling_utils.hxx:74
Definition: cs_defs.h:467
MEDCouplingUMesh * med_mesh
Definition: cs_medcoupling_utils.hxx:72
int elt_dim
Definition: cs_medcoupling_utils.hxx:64
Definition: cs_defs.h:302
Definition: cs_mesh.h:63
cs_medcoupling_mesh_t * cs_medcoupling_mesh_create(const char *name, const char *select_criteria, int elt_dim)
create a new cs_medcoupling_mesh_t instance
Definition: cs_medcoupling_utils.cxx:511
Definition: cs_defs.h:298
Definition: cs_defs.h:468
int * new_to_old
Definition: cs_medcoupling_utils.hxx:69
cs_lnum_t n_elts
Definition: cs_medcoupling_utils.hxx:66
cs_lnum_t * elt_list
Definition: cs_medcoupling_utils.hxx:67
char * sel_criteria
Definition: cs_medcoupling_utils.hxx:62
Definition: mesh.f90:26
void cs_medcoupling_mesh_destroy(cs_medcoupling_mesh_t *mesh)
Destroy a cs_medcoupling_mesh_t.
Definition: cs_medcoupling_utils.cxx:614
