#include <stdarg.h>
#include <mpi.h>
#include <MEDCoupling_version.h>
#include <MEDCouplingUMesh.hxx>
◆ cs_medcoupling_mesh_copy_from_base()
copy a cs_mesh_t into a cs_medcoupling_mesh_t
- Parameters
| [in] | csmesh | pointer to the cs_mesh_t struct to copy data from |
| [in] | pmmesh | pointer to the cs_medcoupling_mesh_t for copy |
| [in] | use_bbox | flag indicating if a reduced bounding is used. Usefull for interpolation to reduce the matrix sice. 0: Do not use a reduced bbox 1: Use a reduced bbox |
◆ cs_medcoupling_mesh_create()
| cs_medcoupling_mesh_t* cs_medcoupling_mesh_create |
const char * |
name, |
const char * |
select_criteria, |
int |
elt_dim |
create a new cs_medcoupling_mesh_t instance
- Parameters
| [in] | name | name of the mesh |
| [in] | selection_criteria | selection criteria (entire mesh or part of it) |
| [in] | elt_dim | dimension of elements. 2: faces 3: cells |
- Returns
- pointer to the newly created cs_medcoupling_mesh_t struct
◆ cs_medcoupling_mesh_destroy()
