fvm_nodal_from_desc.h
1 #ifndef __FVM_NODAL_FROM_DESC_H__
2 #define __FVM_NODAL_FROM_DESC_H__
5  * Initialization of a nodal connectivity definition based upon
6  * a (possibly partial) descending connectivity
8
9 /*
10  This file is part of Code_Saturne, a general-purpose CFD tool.
11
12  Copyright (C) 1998-2019 EDF S.A.
13
17  version.
18
22  details.
23
27 */
28
30
31 #include "cs_defs.h"
32
33 /*----------------------------------------------------------------------------
34  * Local headers
35  *----------------------------------------------------------------------------*/
36
37 #include "fvm_defs.h"
38 #include "fvm_nodal.h"
45  * Public function prototypes
48 /*----------------------------------------------------------------------------
49  * Convert and add cells from an descending connectivity mesh to a nodal mesh.
50  *
51  * If the optional filter list extr_cells[] argument is non-NULL, cells
52  * {extr_cells[0], extr_cells[1], extr_cells[n_extr_cells - 1]} are converted
53  * and added to the nodal mesh. If this filter is set to NULL, cells
54  * {1, 2, ..., n_extr_cells} are considered.
55  *
56  * In addition, an optional parent_cell_num[] array may also be given, in
57  * case the descending connectivity mesh definition is based on a temporary
58  * subset of a parent mesh, (corresponding to the parent_cell_num[] list,
59  * using 1 to n numbering), and the final nodal mesh element parent numbering
60  * should correspond to that parent mesh and not the temporary subset.
61  *
62  * parameters:
63  * this_nodal <-> nodal mesh structure
64  * n_extr_cells <-- count of cells to add
65  * extr_cells <-- optional filter list of cells to extract (1 to n)
66  * n_face_lists <-- number of face lists
67  * face_list_shift <-- face list to common number index shifts;
68  * size: n_face_lists
69  * face_vertex_idx <-- face -> vertex indexes (per face list)
70  * face_vertex <-- face -> vertex ids (per face list)
71  * cell_face_idx <-- cell -> face indexes (1 to n)
72  * cell_face_num <-- cell -> face numbers (1 to n)
73  * cell_gc_id <-- cell -> group class ids, or NULL
74  * parent_cell_num <-- cell -> parent cell number (1 to n) if non-trivial
75  * (i.e. if cell definitions correspond to a subset
76  * of the parent mesh), NULL otherwise.
77  * cell_face_list --> numbers of faces defining polyhedra
78  *----------------------------------------------------------------------------*/
79
80 void
81 fvm_nodal_from_desc_add_cells(fvm_nodal_t *this_nodal,
82  const cs_lnum_t n_extr_cells,
83  const cs_lnum_t extr_cells[],
84  const int n_face_lists,
85  const cs_lnum_t face_list_shift[],
86  const cs_lnum_t *face_vertex_idx[],
87  const cs_lnum_t *face_vertex_num[],
88  const cs_lnum_t cell_face_idx[],
89  const cs_lnum_t cell_face_num[],
90  const int cell_gc_id[],
91  const cs_lnum_t parent_cell_num[],
92  cs_lnum_t *cell_face_list[]);
93
94 /*----------------------------------------------------------------------------
95  * Convert and add faces from an descending connectivity mesh to a nodal mesh.
96  *
97  * If the optional filter list extr_faces[] argument is non-NULL, faces
98  * {extr_faces[0], extr_faces[1], extr_faces[n_extr_faces - 1]} are converted
99  * and added to the nodal mesh. If this filter is set to NULL, faces
100  * {1, 2, ..., n_extr_faces} are considered.
101  *
102  * In addition, an optional parent_face_num[] array may also be given, in
103  * case the descending connectivity mesh definition is based on a temporary
104  * subset of a parent mesh, (corresponding to the parent_face_num[] list,
105  * using 1 to n numbering), and the final nodal mesh element parent numbering
106  * should correspond to that parent mesh and not the temporary subset.
107  *
108  * parameters:
109  * this_nodal <-> nodal mesh structure
110  * n_extr_faces <-- count of faces to add
111  * extr_faces <-- optional filter list of faces to extract (1 to n)
112  * n_face_lists <-- number of face lists
113  * face_list_shift <-- face list to common number index shifts;
114  * size: n_face_lists
115  * face_vertex_idx <-- face -> vertex indexes (per face list)
116  * face_vertex <-- face -> vertex ids (per face list)
117  * face_gc_id <-- face -> group class ids, or NULL (per face list)
118  * parent_face_num <-- face -> parent face number (1 to n) if non-trivial
119  * (i.e. if face definitions correspond to a subset
120  * of the parent mesh), NULL otherwise.
121  *----------------------------------------------------------------------------*/
122
123 void
124 fvm_nodal_from_desc_add_faces(fvm_nodal_t *this_nodal,
125  const cs_lnum_t n_extr_faces,
126  const cs_lnum_t extr_faces[],
127  const int n_face_lists,
128  const cs_lnum_t face_list_shift[],
129  const cs_lnum_t *face_vertex_idx[],
130  const cs_lnum_t *face_vertex_num[],
131  const int *face_gc_id[],
132  const cs_lnum_t parent_face_num[]);
133
134 /*----------------------------------------------------------------------------
135  * Determination of a given cell's type.
136  *
137  * If the optional cell_vtx[8] array is given, it is filled with the vertex
138  * indexes of cell's vertices, unless the cell is a general polyhedron.
139  *
140  * parameters:
141  * cell_id <-- cell id (0 to n-1)
142  * n_face_lists <-- number of face lists
143  * face_list_shift <-- face list to common number index shifts;
144  * size: n_face_lists
145  * face_vertex_idx <-- face -> vertex indexes (per face list)
146  * face_vertex <-- face -> vertex ids (per face list)
147  * cell_face_idx <-- cell -> face indexes (1 to n)
148  * cell_face_num <-- cell -> face numbers (1 to n)
149  * vertex_num --> nodal connectivity of cell, if not a general
150  * polyhedron
151  *
152  * returns:
153  * type of cell defined by cell_id
154  *----------------------------------------------------------------------------*/
155
157 fvm_nodal_from_desc_cell(const cs_lnum_t cell_id,
158  const int n_face_lists,
159  const cs_lnum_t face_list_shift[],
160  const cs_lnum_t *face_vertex_idx[],
161  const cs_lnum_t *face_vertex_num[],
162  const cs_lnum_t cell_face_idx[],
163  const cs_lnum_t cell_face_num[],
164  cs_lnum_t vertex_num[8]);
165
166 /*----------------------------------------------------------------------------*/
167
169
170 #endif /* __FVM_NODAL_FROM_DESC_H__ */
Definition: cs_defs.h:467
fvm_element_t
Definition: fvm_defs.h:48
void fvm_nodal_from_desc_add_faces(fvm_nodal_t *this_nodal, const cs_lnum_t n_extr_faces, const cs_lnum_t extr_faces[], const int n_face_lists, const cs_lnum_t face_list_shift[], const cs_lnum_t *face_vertex_idx[], const cs_lnum_t *face_vertex_num[], const int *face_gc_id[], const cs_lnum_t parent_face_num[])
Definition: fvm_nodal_from_desc.c:1553
Definition: cs_defs.h:298
fvm_element_t fvm_nodal_from_desc_cell(const cs_lnum_t cell_id, const int n_face_lists, const cs_lnum_t face_list_shift[], const cs_lnum_t *face_vertex_idx[], const cs_lnum_t *face_vertex_num[], const cs_lnum_t cell_face_idx[], const cs_lnum_t cell_face_num[], cs_lnum_t vertex_num[8])
Definition: fvm_nodal_from_desc.c:1801
void fvm_nodal_from_desc_add_cells(fvm_nodal_t *this_nodal, const cs_lnum_t n_extr_cells, const cs_lnum_t extr_cells[], const int n_face_lists, const cs_lnum_t face_list_shift[], const cs_lnum_t *face_vertex_idx[], const cs_lnum_t *face_vertex_num[], const cs_lnum_t cell_face_idx[], const cs_lnum_t cell_face_num[], const int cell_gc_id[], const cs_lnum_t parent_cell_num[], cs_lnum_t *cell_face_list[])
Definition: fvm_nodal_from_desc.c:1281
Definition: cs_defs.h:468
