#include "cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <unistd.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "cs_base.h"#include "cs_calcium.h"
| int | cs_calcium_connect (int comp_id, char *s) |
| int | cs_calcium_disconnect (int comp_id, cs_calcium_continuation_t cont) |
| int | cs_calcium_read_int (int comp_id, cs_calcium_timedep_t time_dep, double *min_time, double *max_time, int *iteration, const char *var_name, int n_val_max, int *n_val_read, int val[]) |
| int | cs_calcium_read_float (int comp_id, cs_calcium_timedep_t time_dep, double *min_time, double *max_time, int *iteration, const char *var_name, int n_val_max, int *n_val_read, float val[]) |
| int | cs_calcium_read_double (int comp_id, cs_calcium_timedep_t time_dep, double *min_time, double *max_time, int *iteration, const char *var_name, int n_val_max, int *n_val_read, double val[]) |
| int | cs_calcium_write_int (int comp_id, cs_calcium_timedep_t time_dep, double cur_time, int iteration, const char *var_name, int n_val, const int val[]) |
| int | cs_calcium_write_float (int comp_id, cs_calcium_timedep_t time_dep, double cur_time, int iteration, const char *var_name, int n_val, const float val[]) |
| int | cs_calcium_write_double (int comp_id, cs_calcium_timedep_t time_dep, double cur_time, int iteration, const char *var_name, int n_val, const double val[]) |
| void | cs_calcium_set_component (int comp_id, void *comp) |
| void | cs_calcium_set_verbosity (int n_echo) |
| void | cs_calcium_load_yacs (const char *lib_path) |
| void | cs_calcium_unload_yacs (void) |
| void | cs_calcium_start_yacs (void) |
| int cs_calcium_connect | ( | int | comp_id, |
| char * | s | ||
| int cs_calcium_disconnect | ( | int | comp_id, |
| cs_calcium_continuation_t | cont | ||
| void cs_calcium_load_yacs | ( | const char * | lib_path | ) |
| int cs_calcium_read_double | ( | int | comp_id, |
| cs_calcium_timedep_t | time_dep, | ||
| double * | min_time, | ||
| double * | max_time, | ||
| int * | iteration, | ||
| int | n_val_max, | ||
| int * | n_val_read, | ||
| double | val[] | ||
| int cs_calcium_read_float | ( | int | comp_id, |
| float | val[] | ||
| int cs_calcium_read_int | ( | int | comp_id, |
| int | val[] | ||
| void cs_calcium_set_component | ( | int | comp_id, |
| void * | comp | ||
| void cs_calcium_set_verbosity | ( | int | n_echo | ) |
| void cs_calcium_start_yacs | ( | void | ) |
| void cs_calcium_unload_yacs | ( | void | ) |
| int cs_calcium_write_double | ( | int | comp_id, |
| double | cur_time, | ||
| int | iteration, | ||
| int | n_val, | ||
| const double | val[] | ||
| int cs_calcium_write_float | ( | int | comp_id, |
| int | n_val, | ||
| const float | val[] | ||
| int cs_calcium_write_int | ( | int | comp_id, |
| int | n_val, | ||
| const int | val[] | ||
