1 #ifndef __CS_CALCIUM_H__ 2 #define __CS_CALCIUM_H__ 46 #define CS_CALCIUM_CONTINUE 20 47 #define CS_CALCIUM_STOP 22 51 #define CS_CALCIUM_INSTANCE_LEN 72 52 #define CS_CALCIUM_VARIABLE_LEN 144 135 const char *var_name,
146 const char *var_name,
157 const char *var_name,
183 const char *var_name,
192 const char *var_name,
201 const char *var_name,
int cs_calcium_write_float(int comp_id, cs_calcium_timedep_t time_dep, double cur_time, int iteration, const char *var_name, int n_val, const float val[])
Definition: cs_calcium.c:766
Definition: cs_calcium.h:63
Definition: cs_defs.h:467
Definition: cs_calcium.h:62
int cs_calcium_read_float(int comp_id, cs_calcium_timedep_t time_dep, double *min_time, double *max_time, int *iteration, const char *var_name, int n_val_max, int *n_val_read, float val[])
Definition: cs_calcium.c:594
Definition: cs_calcium.h:71
Definition: cs_calcium.h:72
int cs_calcium_read_double(int comp_id, cs_calcium_timedep_t time_dep, double *min_time, double *max_time, int *iteration, const char *var_name, int n_val_max, int *n_val_read, double val[])
Definition: cs_calcium.c:656
void cs_calcium_load_yacs(const char *lib_path)
Definition: cs_calcium.c:900
int cs_calcium_disconnect(int comp_id, cs_calcium_continuation_t cont)
Definition: cs_calcium.c:501
int cs_calcium_read_int(int comp_id, cs_calcium_timedep_t time_dep, double *min_time, double *max_time, int *iteration, const char *var_name, int n_val_max, int *n_val_read, int val[])
Definition: cs_calcium.c:533
void cs_calcium_set_component(int comp_id, void *comp)
Definition: cs_calcium.c:870
int cs_calcium_write_double(int comp_id, cs_calcium_timedep_t time_dep, double cur_time, int iteration, const char *var_name, int n_val, const double val[])
Definition: cs_calcium.c:822
Definition: cs_defs.h:468
void cs_calcium_unload_yacs(void)
Definition: cs_calcium.c:959
void cs_calcium_start_yacs(void)
Definition: cs_calcium.c:993
Definition: cs_calcium.h:69
int cs_calcium_connect(int comp_id, char *s)
Definition: cs_calcium.c:477
void cs_calcium_set_verbosity(int n_echo)
Definition: cs_calcium.c:887
Definition: cs_calcium.h:60
int cs_calcium_write_int(int comp_id, cs_calcium_timedep_t time_dep, double cur_time, int iteration, const char *var_name, int n_val, const int val[])
Definition: cs_calcium.c:710
