Hi
Following the installation of Code Saturne 2.3.1, i re-ran a test that used to run well on Saturne 2.0.4
I may have found 1 issue:
-> everything runs fine when using "iterative handling of non-orthogonalities" for the gradient calculation method (albeit a message reading "run_solver.sh[10]: module: not found [No such file or directory]") but the calculation can not run when using all the methods with "least squares method"
I have this message in the listing:
"/tmp/saturne-2.3.1/installer/code_saturne-2.3.1/src/mesh/cs_mesh_quantities.c:1663: Fatal error.
The option selection indicator for the cocg computation
for vector gradients can take the following values:
0: do not compute cocg dimensionless matrices
1: compute cocg matrices
and not 0."
I am attaching the listing of a calculation that runs OK (***-1312) and calculations that doesn't run (***-1401)
Have a nice day
[SOLVED] Code Saturne 2.3.1: issues /gradient calculation
laurent
- listing-20120730-1312.txt
- Listing of a calculation running OK with "iterative handling of non-orthogonalities" for gradient calculation method
- (930.62 KiB) Downloaded 950 times
- listing-20120730-1401.txt
- Listing of a calculation running NOK with "least squares method" for gradient calculation method
- (4.72 KiB) Downloaded 969 times
Jacques Fontaine
Re: Code Saturne 2.3.1: small issues with gradient calculati
I attached a fix, you can recompile Code_Saturne with it or add this files onto your SRC folder.
Could you tell me if the fix works on your test case?
Thanks for the feedback.
- cs_mesh_quantities.c
- (77.55 KiB) Downloaded 969 times
- iniusi.f90
- (14.25 KiB) Downloaded 902 times
laurent
Hi
I tried the fix, it didn't seem to work BUT i was a bit in a hurry so i would prefer to take sometime to do things properly before saying it doesn't work.
Could have a closer look in about 1week and sadly i have another question/issue? on other topic
Sorry for the bad news on a friday!
Jacques Fontaine
By the way could you attach your case here?
ty
ty
laurent
Yes, but next week as i am currently away from the office.
Have a nice day and thanks for the follow-up
laurent
Hi
Here is the case discussed above
- 4forum-20120813-0812.zip
- listing of the calculation
- (122.44 KiB) Downloaded 897 times
- Pipe-Nissan-Alpha-BL-Mesh.zip
- the mesh
- (3.84 MiB) Downloaded 966 times
- SaturneCompressible-xml.txt
- Even if the title mention "compressible", it is NOT a compressible case yet
- (7.04 KiB) Downloaded 1134 times
laurent
Hi
I tried my case again with Code Saturne 2.3.2 and there are no issues anymore with the "least square gradient".
There is still a warning with /_6/run_solver.sh but it doesn't stop the calculation
(_6 being apparently the new folder where Saturne 2.3 stores the post-pro results instead of date-time: is it normal?)
Have a nice day
Have a nice day
Good to know the issue has dissapeared.
But the case directory should be date_time, and not _6 (unless you changed the default behavior in the runcase by adding "--id _6" to the "code_saturne run" command).
Do you always have this behavior ?
