[SOLVED] Code Saturne 2.3.1: issues /gradient calculation
laurent
Post by laurent »
Hi
Following the installation of Code Saturne 2.3.1, i re-ran a test that used to run well on Saturne 2.0.4
I may have found 1 issue:
-> everything runs fine when using "iterative handling of non-orthogonalities" for the gradient calculation method (albeit a message reading "run_solver.sh[10]: module: not found [No such file or directory]") but the calculation can not run when using all the methods with "least squares method"
I have this message in the listing:
"/tmp/saturne-2.3.1/installer/code_saturne-2.3.1/src/mesh/cs_mesh_quantities.c:1663: Fatal error.
The option selection indicator for the cocg computation
for vector gradients can take the following values:
0: do not compute cocg dimensionless matrices
1: compute cocg matrices
and not 0."
I am attaching the listing of a calculation that runs OK (***-1312) and calculations that doesn't run (***-1401)
Have a nice day
Saturne 2.3.1 gui picture of the gradient calculation method selection
listing-20120730-1312.txt
Listing of a calculation running OK with "iterative handling of non-orthogonalities" for gradient calculation method
(930.62 KiB) Downloaded 630 times
listing-20120730-1401.txt
Listing of a calculation running NOK with "least squares method" for gradient calculation method
(4.72 KiB) Downloaded 624 times
Jacques Fontaine
Re: Code Saturne 2.3.1: small issues with gradient calculati
Post by Jacques Fontaine »
I attached a fix, you can recompile Code_Saturne with it or add this files onto your SRC folder.
Could you tell me if the fix works on your test case?
Thanks for the feedback.
(77.55 KiB) Downloaded 644 times
iniusi.f90
(14.25 KiB) Downloaded 609 times
laurent
Post by laurent »
Hi
I tried the fix, it didn't seem to work BUT i was a bit in a hurry so i would prefer to take sometime to do things properly before saying it doesn't work.
Could have a closer look in about 1week and sadly i have another question/issue? on other topic
Sorry for the bad news on a friday!
Jacques Fontaine
By the way could you attach your case here?
ty
laurent
Post by laurent »
Yes, but next week as i am currently away from the office.
Have a nice day and thanks for the follow-up
laurent
Post by laurent »
Hi
Here is the case discussed above
4forum-20120813-0812.zip
listing of the calculation
(122.44 KiB) Downloaded 597 times
Pipe-Nissan-Alpha-BL-Mesh.zip
the mesh
(3.84 MiB) Downloaded 620 times
SaturneCompressible-xml.txt
Even if the title mention "compressible", it is NOT a compressible case yet
(7.04 KiB) Downloaded 802 times
laurent
Post by laurent »
Hi
I tried my case again with Code Saturne 2.3.2 and there are no issues anymore with the "least square gradient".
There is still a warning with /_6/run_solver.sh but it doesn't stop the calculation
(_6 being apparently the new folder where Saturne 2.3 stores the post-pro results instead of date-time: is it normal?)
Have a nice day
Good to know the issue has dissapeared.
But the case directory should be date_time, and not _6 (unless you changed the default behavior in the runcase by adding "--id _6" to the "code_saturne run" command).
Do you always have this behavior ?
