#include "base/cs_defs.h"#include <assert.h>#include <ctype.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft/bft_error.h"#include "bft/bft_printf.h"#include "fvm/fvm_nodal.h"#include "fvm/fvm_nodal_priv.h"#include "base/cs_base.h"#include "base/cs_file.h"#include "base/cs_fp_exception.h"#include "base/cs_mem.h"#include "base/cs_timer.h"#include "fvm/fvm_writer.h"#include "fvm/fvm_writer_priv.h"#include "fvm/fvm_to_ccm.h"#include "fvm/fvm_to_cgns.h"#include "fvm/fvm_to_med.h"#include "fvm/fvm_to_ensight.h"#include "fvm/fvm_to_histogram.h"#include "fvm/fvm_to_plot.h"#include "fvm/fvm_to_time_plot.h"Functions | |
| int | fvm_writer_get_format_id (const char *format_name) |
| int | fvm_writer_n_formats (void) |
| const char * | fvm_writer_format_name (int format_index) |
| int | fvm_writer_format_available (int format_index) |
| int | fvm_writer_n_version_strings (int format_index) |
| const char * | fvm_writer_version_string (int format_index, int string_index, int compile_time_version) |
| void | fvm_writer_filter_option (char *format_options, const char *exclude_option) |
| fvm_writer_t * | fvm_writer_init (const char *name, const char *path, const char *format_name, const char *format_options, fvm_writer_time_dep_t time_dependency) |
| fvm_writer_t * | fvm_writer_finalize (fvm_writer_t *this_writer) |
| const char * | fvm_writer_get_name (const fvm_writer_t *this_writer) |
| const char * | fvm_writer_get_format (const fvm_writer_t *this_writer) |
| const char * | fvm_writer_get_options (const fvm_writer_t *this_writer) |
| const char * | fvm_writer_get_path (const fvm_writer_t *this_writer) |
| fvm_writer_time_dep_t | fvm_writer_get_time_dep (const fvm_writer_t *this_writer) |
| void | fvm_writer_set_mesh_time (fvm_writer_t *this_writer, int time_step, double time_value) |
| int | fvm_writer_needs_tesselation (fvm_writer_t *this_writer, const fvm_nodal_t *mesh, fvm_element_t element_type) |
| void | fvm_writer_export_nodal (fvm_writer_t *this_writer, const fvm_nodal_t *mesh) |
| void | fvm_writer_export_field (fvm_writer_t *this_writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[]) |
| void | fvm_writer_flush (fvm_writer_t *this_writer) |
| void | fvm_writer_get_times (fvm_writer_t *this_writer, cs_timer_counter_t *mesh_time, cs_timer_counter_t *field_time, cs_timer_counter_t *flush_time) |
| const char * | fvm_writer_time_dep_name [] |
| const char | _empty_string [] = "" |
| void fvm_writer_export_field | ( | fvm_writer_t * | this_writer, |
| const fvm_nodal_t * | mesh, | ||
| const char * | name, | ||
| fvm_writer_var_loc_t | location, | ||
| int | dimension, | ||
| cs_interlace_t | interlace, | ||
| int | n_parent_lists, | ||
| const cs_lnum_t | parent_num_shift[], | ||
| int | time_step, | ||
| double | time_value, | ||
| const void *const | field_values[] ) |
| void fvm_writer_export_nodal | ( | fvm_writer_t * | this_writer, |
| const fvm_nodal_t * | mesh ) |
| void fvm_writer_filter_option | ( | char * | format_options, |
| const char * | exclude_option ) |
| fvm_writer_t * fvm_writer_finalize | ( | fvm_writer_t * | this_writer | ) |
| void fvm_writer_flush | ( | fvm_writer_t * | this_writer | ) |
| int fvm_writer_format_available | ( | int | format_index | ) |
| const char * fvm_writer_format_name | ( | int | format_index | ) |
| const char * fvm_writer_get_format | ( | const fvm_writer_t * | this_writer | ) |
| int fvm_writer_get_format_id | ( | const char * | format_name | ) |
| const char * fvm_writer_get_name | ( | const fvm_writer_t * | this_writer | ) |
| const char * fvm_writer_get_options | ( | const fvm_writer_t * | this_writer | ) |
| const char * fvm_writer_get_path | ( | const fvm_writer_t * | this_writer | ) |
| fvm_writer_time_dep_t fvm_writer_get_time_dep | ( | const fvm_writer_t * | this_writer | ) |
| void fvm_writer_get_times | ( | fvm_writer_t * | this_writer, |
| cs_timer_counter_t * | mesh_time, | ||
| cs_timer_counter_t * | field_time, | ||
| cs_timer_counter_t * | flush_time ) |
| fvm_writer_t * fvm_writer_init | ( | const char * | name, |
| const char * | path, | ||
| const char * | format_name, | ||
| const char * | format_options, | ||
| fvm_writer_time_dep_t | time_dependency ) |
| int fvm_writer_n_formats | ( | void | ) |
| int fvm_writer_n_version_strings | ( | int | format_index | ) |
| int fvm_writer_needs_tesselation | ( | fvm_writer_t * | this_writer, |
| fvm_element_t | element_type ) |
| void fvm_writer_set_mesh_time | ( | fvm_writer_t * | this_writer, |
| double | time_value ) |
| const char * fvm_writer_version_string | ( | int | format_index, |
| int | string_index, | ||
| int | compile_time_version ) |
| const char _empty_string[] = "" |
