fvm_nodal_priv.h
1#ifndef __FVM_NODAL_PRIV_H__
2#define __FVM_NODAL_PRIV_H__
5 * Main structure for a nodal representation associated with a mesh
30#include "base/cs_defs.h"
33 * Local headers
36#include "mesh/cs_mesh.h"
37#include "fvm/fvm_defs.h"
38#include "fvm/fvm_group.h"
39#include "fvm/fvm_nodal.h"
40#include "fvm/fvm_tesselation.h"
42/*----------------------------------------------------------------------------*/
45
46/*=============================================================================
47 * Macro definitions
49
51 * Type definitions
53
54/*----------------------------------------------------------------------------
55 * Structure defining a mesh section
56 *----------------------------------------------------------------------------*/
57
58typedef struct _fvm_nodal_section_t {
59
60 /* Basic information */
61 /*-------------------*/
62
63 int entity_dim; /* Entity dimension */
64
65 cs_lnum_t n_elements; /* Number of elements */
66
67 fvm_element_t type; /* Element types */
68
69 int boundary_flag; /* Is section on boundary ?
70 -1: does not apply or unspecified;
71 0: no
72 1: yes */
73
74 /* Connectivity */
75 /*--------------*/
76
77 size_t connectivity_size; /* Size of vertex_num array;
78 for strided elements:
79 (n_elements * stride)
80 for polygons:
81 (vertex_index[n_elements])
82 for polyhedra:
83 (vertex_index[n_faces]) */
84
85 int stride; /* Element size for regular elements
86 (0 for polygons and polyhedra) */
87
88 cs_lnum_t n_faces; /* Number of faces defining polyhedra */
89
90 /* Pointers to connectivity arrays, which may be shared */
91
92 const cs_lnum_t *face_index; /* polyhedron -> faces index (O to n-1);
93 size: n_elements + 1 */
94 const cs_lnum_t *face_num; /* polyhedron -> face numbers (1 to n, signed,
95 > 0 for outwards pointing face normal
96 < 0 for inwards pointing face normal);
97 size: face_index[n_elements] */
98
99 const cs_lnum_t *vertex_index; /* polygon face -> vertices index (O to n-1);
100 size: n_faces + 1 */
101
102 const cs_lnum_t *vertex_num; /* vertex numbers (1 to n);
103 size: connectivity_size */
104
105 /* Pointers to local connectivity arrays, if owner */
106
107 cs_lnum_t *_face_index; /* face_index if owner, NULL if shared */
108 cs_lnum_t *_face_num; /* face_num if owner, NULL if shared */
109 cs_lnum_t *_vertex_index; /* vertex_index if owner, NULL if shared */
110 cs_lnum_t *_vertex_num; /* vertex numbers if owner, NULL if shared */
111
112 /* Pointers to group class ids, if present */
113
114 int *gc_id; /* Group class id, NULL if implicit 0 */
115
116 /* Optional tagging */
117
118 int *tag; /* Element tag */
119
120 /* Auxiliary structure used to define subdivision of elements into
121 simpler element types (usually polygons to triangles and
122 polyhedra to tetrahedra and pyramids) */
123
125
126 /* Numbering */
127 /*-----------*/
128
129 const cs_lnum_t *parent_element_id; /* Local ids (0 to n-1) of local
130 elements in the parent mesh,
131 associated with the section's
132 elements.
133
134 This array is necessary to redis-
135 tribute output fields when the
136 section has been either associated
137 with an unsorted mixed mesh,
138 renumbered, or is associated with a
139 subset of a more complete mesh,
140 such as a clip plane. When used for
141 a subset, it also defines the lists
142 of elements of the parent mesh
143 belonging to that subset.
144
145 This array is present only when non
146 "trivial" (i.e. not 0, 1, ..., n-1). */
147
148 cs_lnum_t *_parent_element_id; /* pointer to parent_element_num if
149 owner, NULL otherwise */
150
151 fvm_io_num_t *global_element_num; /* Global element numbers */
152
154
155/*----------------------------------------------------------------------------
156 * Structure defining a mesh in nodal definition
157 *----------------------------------------------------------------------------*/
158
160
161 /* Global indicators */
162 /*-------------------*/
163
164 char *name; /* Mesh name */
165
166 int dim; /* Spatial dimension */
167 int num_dom; /* Local domain number */
168 int n_doms; /* Global number of domains */
169 int n_sections; /* Number of sections */
170
171 /* Local dimensions */
172 /*------------------*/
173
174 /* Total number of cells, faces, edges, and vertices */
179
180 /* Vertex definitions; */
181 /*---------------------*/
182
183 const cs_coord_t *vertex_coords; /* pointer to vertex coordinates
184 (always interlaced:
185 x1, y1, z1, x2, y2, z2, ...) */
186 cs_coord_t *_vertex_coords; /* pointer to vertex coordinates if
187 owner (for use with own algorithms) */
188
189 const cs_lnum_t *parent_vertex_id; /* Local ids (0 to n-1) of local
190 vertices in the parent mesh.
191
192 This array is necessary to redis-
193 tribute output fields when a nodal
194 mesh has been renumbered or is
195 associated with a subset of a more
196 complete mesh, such as a clip plane
197 (in which case it also defines the
198 lists of vertices of the parent
199 mesh in that subset).
200
201 This array is present only when non
202 "trivial" (i.e. not 0, 1, ..., n-1). */
203
204 cs_lnum_t *_parent_vertex_id; /* pointer to parent_vertex_id if
205 owner, NULL otherwise */
206
207 fvm_io_num_t *global_vertex_num; /* Global vertex numbering */
208
209 /* Mesh connectivity */
210 /*-------------------*/
211
212 fvm_nodal_section_t **sections; /* Array of section descriptions */
213
214 /* Metadata */
215 /*----------*/
216
217 /* Group class descriptions if present */
218
219 fvm_group_class_set_t *gc_set; /* Pointer to group class set, or NULL */
220
221 /* Optional global vertex labels.
222 As these are expected to be used only for small sets (i.e. probes)
223 where the point set is built from a global definition and data movement
224 would adds complexity and overhead, the labels refer to a global view
225 on rank 0; for the same reason, only shared labels are needed */
226
227 char **global_vertex_labels; /* Pointer to vertex labels, or NULL */
228
229 /* Pointer to parent mesh, if defined */
230
232
233};
234
235/*=============================================================================
236 * Semi-private function prototypes
237 *============================================================================*/
238
239/*----------------------------------------------------------------------------
240 * Creation of a nodal mesh section representation structure.
241 *
242 * parameters:
243 * type <-- type of element defined by this section
244 *
245 * returns:
246 * pointer to created nodal mesh section representation structure
247 *----------------------------------------------------------------------------*/
248
251
252/*----------------------------------------------------------------------------
253 * Destruction of a nodal mesh section representation structure.
254 *
255 * parameters:
256 * this_section <-> pointer to structure that should be destroyed
257 *
258 * returns:
259 * null pointer
260 *----------------------------------------------------------------------------*/
261
264
265/*----------------------------------------------------------------------------
266 * Copy selected shared connectivity information to private connectivity
267 * for a nodal mesh section .
268 *
269 * parameters:
270 * this_section <-> pointer to section structure
271 * copy_face_index <-- copy face index (polyhedra only) ?
272 * copy_face_num <-- copy face numbers (polyhedra only) ?
273 * copy_vertex_index <-- copy vertex index (polyhedra/polygons only) ?
274 * copy_vertex_num <-- copy vertex numbers ?
275 *----------------------------------------------------------------------------*/
276
277void
279 bool copy_face_index,
280 bool copy_face_num,
281 bool copy_vertex_index,
282 bool copy_vertex_num);
283
284/*----------------------------------------------------------------------------
285 * Return global number of elements associated with section.
286 *
287 * parameters:
288 * this_section <-- pointer to section structure
289 *
290 * returns:
291 * global number of elements associated with section
292 *----------------------------------------------------------------------------*/
293
296
297/*----------------------------------------------------------------------------
298 * Return global number of vertices associated with nodal mesh.
299 *
300 * parameters:
301 * this_nodal <-- pointer to nodal mesh structure
302 *
303 * returns:
304 * global number of vertices associated with nodal mesh
305 *----------------------------------------------------------------------------*/
306
308fvm_nodal_n_g_vertices(const fvm_nodal_t *this_nodal);
309
310/*----------------------------------------------------------------------------
311 * Define cell->face connectivity for strided cell types.
312 *
313 * parameters:
314 * element_type <-- type of strided element
315 * n_faces --> number of element faces
316 * n_face_vertices --> number of vertices of each face
317 * face_vertices --> face -> vertex base connectivity (0 to n-1)
318 *----------------------------------------------------------------------------*/
319
320void
322 int *n_faces,
323 int n_face_vertices[6],
324 int face_vertices[6][4]);
325
326/*----------------------------------------------------------------------------*/
327
329
330#endif /* __FVM_NODAL_PRIV_H__ */
Definition cs_defs.h:542
double cs_coord_t
Definition cs_defs.h:340
unsigned cs_gnum_t
global mesh entity number
Definition cs_defs.h:327
Definition cs_defs.h:543
Definition cs_defs.h:335
fvm_element_t
Definition fvm_defs.h:48
Definition fvm_group.h:60
struct _fvm_io_num_t fvm_io_num_t
Definition fvm_io_num.h:72
void fvm_nodal_cell_face_connect(fvm_element_t element_type, int *n_faces, int n_face_vertices[6], int face_vertices[6][4])
cs_gnum_t fvm_nodal_section_n_g_elements(const fvm_nodal_section_t *this_section)
fvm_nodal_section_t * fvm_nodal_section_destroy(fvm_nodal_section_t *this_section)
fvm_nodal_section_t * fvm_nodal_section_create(const fvm_element_t type)
cs_gnum_t fvm_nodal_n_g_vertices(const fvm_nodal_t *this_nodal)
void fvm_nodal_section_copy_on_write(fvm_nodal_section_t *this_section, bool copy_face_index, bool copy_face_num, bool copy_vertex_index, bool copy_vertex_num)
struct _fvm_tesselation_t fvm_tesselation_t
Definition fvm_tesselation.h:65
Definition fvm_nodal_priv.h:159
cs_coord_t * _vertex_coords
Definition fvm_nodal_priv.h:186
int n_sections
Definition fvm_nodal_priv.h:169
cs_lnum_t n_faces
Definition fvm_nodal_priv.h:176
cs_lnum_t * _parent_vertex_id
Definition fvm_nodal_priv.h:204
const cs_coord_t * vertex_coords
Definition fvm_nodal_priv.h:183
char * name
Definition fvm_nodal_priv.h:164
int dim
Definition fvm_nodal_priv.h:166
fvm_io_num_t * global_vertex_num
Definition fvm_nodal_priv.h:207
const cs_mesh_t * parent
Definition fvm_nodal_priv.h:231
fvm_group_class_set_t * gc_set
Definition fvm_nodal_priv.h:219
int num_dom
Definition fvm_nodal_priv.h:167
cs_lnum_t n_cells
Definition fvm_nodal_priv.h:175
fvm_nodal_section_t ** sections
Definition fvm_nodal_priv.h:212
const cs_lnum_t * parent_vertex_id
Definition fvm_nodal_priv.h:189
cs_lnum_t n_vertices
Definition fvm_nodal_priv.h:178
char ** global_vertex_labels
Definition fvm_nodal_priv.h:227
cs_lnum_t n_edges
Definition fvm_nodal_priv.h:177
int n_doms
Definition fvm_nodal_priv.h:168
Definition cs_mesh.h:85
Definition fvm_nodal_priv.h:58
int stride
Definition fvm_nodal_priv.h:85
const cs_lnum_t * vertex_index
Definition fvm_nodal_priv.h:99
cs_lnum_t * _face_num
Definition fvm_nodal_priv.h:108
const cs_lnum_t * face_num
Definition fvm_nodal_priv.h:94
fvm_element_t type
Definition fvm_nodal_priv.h:67
int * tag
Definition fvm_nodal_priv.h:118
cs_lnum_t * _vertex_index
Definition fvm_nodal_priv.h:109
cs_lnum_t n_faces
Definition fvm_nodal_priv.h:88
fvm_io_num_t * global_element_num
Definition fvm_nodal_priv.h:151
cs_lnum_t * _face_index
Definition fvm_nodal_priv.h:107
int * gc_id
Definition fvm_nodal_priv.h:114
Definition fvm_nodal_priv.h:65
fvm_tesselation_t * tesselation
Definition fvm_nodal_priv.h:124
int entity_dim
Definition fvm_nodal_priv.h:63
Definition fvm_nodal_priv.h:77
cs_lnum_t * _vertex_num
Definition fvm_nodal_priv.h:110
const cs_lnum_t * vertex_num
Definition fvm_nodal_priv.h:102
int boundary_flag
Definition fvm_nodal_priv.h:69
const cs_lnum_t * face_index
Definition fvm_nodal_priv.h:92
cs_lnum_t * _parent_element_id
Definition fvm_nodal_priv.h:148
const cs_lnum_t * parent_element_id
Definition fvm_nodal_priv.h:129
