fvm_tesselation.h File Reference
#include "fvm/fvm_defs.h"
#include "fvm/fvm_io_num.h"
Include dependency graph for fvm_tesselation.h:
Macros
#define FVM_TESSELATION_N_SUB_TYPES_MAX   2
Typedefs
typedef struct _fvm_tesselation_t fvm_tesselation_t
fvm_tesselation_tfvm_tesselation_create (fvm_element_t element_type, cs_lnum_t n_elements, const cs_lnum_t face_index[], const cs_lnum_t face_num[], const cs_lnum_t vertex_index[], const cs_lnum_t vertex_num[], const fvm_io_num_t *global_element_num)
fvm_tesselation_tfvm_tesselation_destroy (fvm_tesselation_t *this_tesselation)
void fvm_tesselation_init (fvm_tesselation_t *this_tesselation, int dim, const cs_coord_t vertex_coords[], const cs_lnum_t parent_vertex_id[], cs_lnum_t *error_count)
void fvm_tesselation_reduce (fvm_tesselation_t *this_tesselation)
cs_lnum_t fvm_tesselation_n_elements (const fvm_tesselation_t *this_tesselation)
cs_gnum_t fvm_tesselation_n_g_vertices_add (const fvm_tesselation_t *this_tesselation)
cs_lnum_t fvm_tesselation_n_vertices_add (const fvm_tesselation_t *this_tesselation)
int fvm_tesselation_n_sub_types (const fvm_tesselation_t *this_tesselation)
fvm_element_t fvm_tesselation_sub_type (const fvm_tesselation_t *this_tesselation, int sub_type_id)
cs_lnum_t fvm_tesselation_n_sub_elements (const fvm_tesselation_t *this_tesselation, fvm_element_t sub_type)
void fvm_tesselation_get_global_size (const fvm_tesselation_t *this_tesselation, fvm_element_t sub_type, cs_gnum_t *n_sub_elements_glob, cs_lnum_t *n_sub_elements_max)
const fvm_io_num_tfvm_tesselation_global_vertex_num (const fvm_tesselation_t *this_tesselation)
void fvm_tesselation_vertex_coords (const fvm_tesselation_t *this_tesselation, cs_coord_t vertex_coords[])
const cs_lnum_tfvm_tesselation_sub_elt_index (const fvm_tesselation_t *this_tesselation, fvm_element_t sub_type)
cs_lnum_t fvm_tesselation_decode (const fvm_tesselation_t *this_tesselation, fvm_element_t connect_type, cs_lnum_t start_id, cs_lnum_t buffer_limit, cs_lnum_t extra_vertex_base, cs_lnum_t vertex_num[])
void fvm_tesselation_distribute (const fvm_tesselation_t *this_tesselation, fvm_element_t connect_type, cs_lnum_t start_id, cs_lnum_t end_id, size_t size, void *data)
void fvm_tesselation_vertex_values (const fvm_tesselation_t *this_tesselation, int src_dim, int src_dim_shift, int dest_dim, cs_lnum_t start_id, cs_lnum_t end_id, cs_interlace_t src_interlace, cs_datatype_t src_datatype, cs_datatype_t dest_datatype, int n_parent_lists, const cs_lnum_t parent_num_shift[], const cs_lnum_t parent_num[], const void *const src_data[], void *const dest_data)
void fvm_tesselation_dump (const fvm_tesselation_t *this_tesselation)
◆ FVM_TESSELATION_N_SUB_TYPES_MAX
Typedef Documentation
◆ fvm_tesselation_t
◆ fvm_tesselation_create()
fvm_tesselation_t * fvm_tesselation_create ( fvm_element_t element_type,
const fvm_io_num_t * global_element_num )
◆ fvm_tesselation_decode()
cs_lnum_t fvm_tesselation_decode ( const fvm_tesselation_t * this_tesselation,
cs_lnum_t start_id,
cs_lnum_t vertex_num[] )
◆ fvm_tesselation_destroy()
fvm_tesselation_t * fvm_tesselation_destroy ( fvm_tesselation_t * this_tesselation)
◆ fvm_tesselation_distribute()
void fvm_tesselation_distribute ( const fvm_tesselation_t * this_tesselation,
cs_lnum_t start_id,
cs_lnum_t end_id,
size_t size,
void * data )
◆ fvm_tesselation_dump()
void fvm_tesselation_dump ( const fvm_tesselation_t * this_tesselation)
◆ fvm_tesselation_get_global_size()
void fvm_tesselation_get_global_size ( const fvm_tesselation_t * this_tesselation,
cs_gnum_t * n_sub_elements_glob,
cs_lnum_t * n_sub_elements_max )
◆ fvm_tesselation_global_vertex_num()
const fvm_io_num_t * fvm_tesselation_global_vertex_num ( const fvm_tesselation_t * this_tesselation)
◆ fvm_tesselation_init()
void fvm_tesselation_init ( fvm_tesselation_t * this_tesselation,
int dim,
cs_lnum_t * error_count )
◆ fvm_tesselation_n_elements()
cs_lnum_t fvm_tesselation_n_elements ( const fvm_tesselation_t * this_tesselation)
◆ fvm_tesselation_n_g_vertices_add()
cs_gnum_t fvm_tesselation_n_g_vertices_add ( const fvm_tesselation_t * this_tesselation)
◆ fvm_tesselation_n_sub_elements()
cs_lnum_t fvm_tesselation_n_sub_elements ( const fvm_tesselation_t * this_tesselation,
fvm_element_t sub_type )
◆ fvm_tesselation_n_sub_types()
int fvm_tesselation_n_sub_types ( const fvm_tesselation_t * this_tesselation)
◆ fvm_tesselation_n_vertices_add()
cs_lnum_t fvm_tesselation_n_vertices_add ( const fvm_tesselation_t * this_tesselation)
◆ fvm_tesselation_reduce()
void fvm_tesselation_reduce ( fvm_tesselation_t * this_tesselation)
◆ fvm_tesselation_sub_elt_index()
const cs_lnum_t * fvm_tesselation_sub_elt_index ( const fvm_tesselation_t * this_tesselation,
◆ fvm_tesselation_sub_type()
fvm_element_t fvm_tesselation_sub_type ( const fvm_tesselation_t * this_tesselation,
int sub_type_id )
◆ fvm_tesselation_vertex_coords()
void fvm_tesselation_vertex_coords ( const fvm_tesselation_t * this_tesselation,
cs_coord_t vertex_coords[] )
◆ fvm_tesselation_vertex_values()
void fvm_tesselation_vertex_values ( const fvm_tesselation_t * this_tesselation,
int src_dim,
int src_dim_shift,
int dest_dim,
cs_lnum_t start_id,
cs_lnum_t end_id,
int n_parent_lists,
void *const dest_data )
