1#ifndef __FVM_IO_NUM_H__
2#define __FVM_IO_NUM_H__
120 const size_t n_entities,
121 const int share_parent_global);
144 int share_parent_global);
Definition cs_defs.h:542
Definition cs_defs.h:342
double cs_coord_t
Definition cs_defs.h:340
unsigned cs_gnum_t
global mesh entity number
Definition cs_defs.h:327
Definition cs_defs.h:543
Definition cs_defs.h:335
fvm_io_num_t * fvm_io_num_create_from_adj_i(const cs_lnum_t parent_entity_id[], const cs_lnum_t index[], const cs_gnum_t adjacency[], cs_lnum_t n_entities)
Definition fvm_io_num.cpp:2228
fvm_io_num_t * fvm_io_num_create_from_sfc(const cs_coord_t coords[], int dim, size_t n_entities, fvm_io_num_sfc_t sfc_type)
Definition fvm_io_num.cpp:2362
fvm_io_num_t * fvm_io_num_create_from_scan(size_t n_entities)
Definition fvm_io_num.cpp:2598
const cs_gnum_t * fvm_io_num_get_global_num(const fvm_io_num_t *const this_io_num)
Definition fvm_io_num.cpp:2738
fvm_io_num_t * fvm_io_num_create_from_sub(const fvm_io_num_t *base_io_num, const cs_lnum_t n_sub_entities[])
Definition fvm_io_num.cpp:2080
fvm_io_num_t * fvm_io_num_create_from_real(const cs_real_t val[], size_t n_entities)
Definition fvm_io_num.cpp:2406
fvm_io_num_t * fvm_io_num_create_from_adj_s(const cs_lnum_t parent_entity_id[], const cs_gnum_t adjacency[], size_t n_entities, size_t stride)
Definition fvm_io_num.cpp:2145
cs_lnum_t fvm_io_num_get_local_count(const fvm_io_num_t *const this_io_num)
Definition fvm_io_num.cpp:2700
fvm_io_num_sfc_t
Definition fvm_io_num.h:76
@ FVM_IO_NUM_SFC_HILBERT_BOX
Definition fvm_io_num.h:80
@ FVM_IO_NUM_SFC_HILBERT_CUBE
Definition fvm_io_num.h:81
@ FVM_IO_NUM_SFC_MORTON_BOX
Definition fvm_io_num.h:78
@ FVM_IO_NUM_SFC_MORTON_CUBE
Definition fvm_io_num.h:79
fvm_io_num_t * fvm_io_num_create_from_select(const cs_lnum_t parent_entity_id[], const cs_gnum_t parent_global_number[], size_t n_entities, int share_parent_global)
Definition fvm_io_num.cpp:1942
fvm_io_num_t * fvm_io_num_create(const cs_lnum_t parent_entity_number[], const cs_gnum_t parent_global_number[], const size_t n_entities, const int share_parent_global)
Definition fvm_io_num.cpp:1900
fvm_io_num_t * fvm_io_num_create_shared(const cs_gnum_t global_number[], cs_gnum_t global_count, size_t n_entities)
Definition fvm_io_num.cpp:2045
struct _fvm_io_num_t fvm_io_num_t
Definition fvm_io_num.h:72
const char * fvm_io_num_sfc_type_name[]
cs_gnum_t fvm_io_num_global_sub_size(const fvm_io_num_t *this_io_num, const cs_lnum_t n_sub_entities[])
Definition fvm_io_num.cpp:2760
void fvm_io_num_dump(const fvm_io_num_t *const this_io_num)
Definition fvm_io_num.cpp:2805
cs_gnum_t * fvm_io_num_transfer_global_num(fvm_io_num_t *this_io_num)
Definition fvm_io_num.cpp:2676
cs_gnum_t fvm_io_num_get_global_count(const fvm_io_num_t *const this_io_num)
Definition fvm_io_num.cpp:2719
fvm_io_num_t * fvm_io_num_destroy(fvm_io_num_t *this_io_num)
Definition fvm_io_num.cpp:2655
