fvm_to_histogram.h
1#ifndef __FVM_TO_HISTOGRAM_H__
2#define __FVM_TO_HISTOGRAM_H__
5 * Write a nodal representation associated with a mesh and associated
6 * variables to histogram (whitepace-separated or csv) files
7 *============================================================================*/
8
9/*
10 This file is part of code_saturne, a general-purpose CFD tool.
11
12 Copyright (C) 1998-2025 EDF S.A.
13
14 This program is free software; you can redistribute it and/or modify it under
15 the terms of the GNU General Public License as published by the Free Software
16 Foundation; either version 2 of the License, or (at your option) any later
17 version.
18
19 This program is distributed in the hope that it will be useful, but WITHOUT
20 ANY WARRANTY; without even the implied warranty of MERCHANTABILITY or FITNESS
21 FOR A PARTICULAR PURPOSE. See the GNU General Public License for more
22 details.
23
24 You should have received a copy of the GNU General Public License along with
25 this program; if not, write to the Free Software Foundation, Inc., 51 Franklin
26 Street, Fifth Floor, Boston, MA 02110-1301, USA.
27*/
28
29/*----------------------------------------------------------------------------*/
30
31#include "base/cs_defs.h"
32
33/*----------------------------------------------------------------------------
34 * Local headers
35 *----------------------------------------------------------------------------*/
36
37#include "fvm/fvm_defs.h"
38#include "fvm/fvm_nodal.h"
39#include "fvm/fvm_writer.h"
45/*=============================================================================
46 * Macro definitions
48
50 * Type definitions
52
53/* Type of histogram file format */
54
55typedef enum {
56 CS_HISTOGRAM_TXT, /* .txt file */
57 CS_HISTOGRAM_TEX, /* .tex file */
58 CS_HISTOGRAM_PNG /* .png file */
60
61/*----------------------------------------------------------------------------
62 * Histogram writer structure
63 *----------------------------------------------------------------------------*/
64
65typedef struct {
66
67 char *name; /* Writer name */
68 char *path; /* Path prefix */
69
70 int rank; /* Rank of current process in communicator */
71 int n_ranks; /* Number of processes in communicator */
72
73 cs_histogram_format_t format; /* Histogram format */
74
75 int nt; /* Time step */
76 double t; /* Time value */
77
78 cs_real_t *buffer; /* Values buffer */
79
80 char *file_name; /* File name */
81 FILE *f; /* Associated histograms */
82
83 int n_sub; /* Number of subdivisions */
84
85#if defined(HAVE_MPI)
86 MPI_Comm comm; /* Associated MPI communicator */
87#endif
88
90
91/*----------------------------------------------------------------------------*/
101/*----------------------------------------------------------------------------*/
102
103typedef void
105 cs_real_t var_max,
106 cs_gnum_t count[],
108 char *var_name);
109
110/*=============================================================================
111 * Public function prototypes
112 *============================================================================*/
113
114/*----------------------------------------------------------------------------
115 * Initialize FVM to histogram file writer.
116 *
117 * Options are:
118 * txt output txt (space-separated) files
119 * tex output TeX (TixZ) files
120 * png output PNG files
121 * [n_sub] number of subdivisions
122 *
123 * parameters:
124 * name <-- base output case name.
125 * options <-- whitespace separated, lowercase options list
126 * time_dependecy <-- indicates if and how meshes will change with time
127 * comm <-- associated MPI communicator.
128 *
129 * returns:
130 * pointer to opaque histogram writer structure.
131 *----------------------------------------------------------------------------*/
132
133#if defined(HAVE_MPI)
134
135void *
136fvm_to_histogram_init_writer(const char *name,
137 const char *path,
138 const char *options,
139 fvm_writer_time_dep_t time_dependency,
140 MPI_Comm comm);
141
142#else
143
144void *
145fvm_to_histogram_init_writer(const char *name,
146 const char *path,
147 const char *options,
148 fvm_writer_time_dep_t time_dependency);
149
150#endif
151
152/*----------------------------------------------------------------------------
153 * Finalize FVM to histogram file writer.
154 *
155 * parameters:
156 * writer <-- pointer to opaque histogram writer structure.
157 *
158 * returns:
159 * null pointer.
160 *----------------------------------------------------------------------------*/
161
162void *
164
165/*----------------------------------------------------------------------------
166 * Associate new time step with a histogram geometry.
167 *
168 * parameters:
169 * writer <-- pointer to associated writer
170 * time_step <-- time step number
171 * time_value <-- time_value number
172 *----------------------------------------------------------------------------*/
173
174void
176 const int time_step,
177 const double time_value);
178
179/*----------------------------------------------------------------------------
180 * Write field associated with a nodal mesh to a histogram file.
181 *
182 * Assigning a negative value to the time step indicates a time-independent
183 * field (in which case the time_value argument is unused).
184 *
185 * parameters:
186 * writer <-- pointer to associated writer
187 * mesh <-- pointer to associated nodal mesh structure
188 * name <-- variable name
189 * location <-- variable definition location (nodes or elements)
190 * dimension <-- variable dimension (0: constant, 1: scalar,
191 * 3: vector, 6: sym. tensor, 9: asym. tensor)
192 * interlace <-- indicates if variable in memory is interlaced
193 * n_parent_lists <-- indicates if variable values are to be obtained
194 * directly through the local entity index (when 0) or
195 * through the parent entity numbers (when 1 or more)
196 * parent_num_shift <-- parent number to value array index shifts;
197 * size: n_parent_lists
198 * datatype <-- indicates the data type of (source) field values
199 * time_step <-- number of the current time step
200 * time_value <-- associated time value
201 * field_values <-- array of associated field value arrays
202 *----------------------------------------------------------------------------*/
203
204void
206 const fvm_nodal_t *mesh,
207 const char *name,
208 fvm_writer_var_loc_t location,
209 int dimension,
210 cs_interlace_t interlace,
211 int n_parent_lists,
212 const cs_lnum_t parent_num_shift[],
213 cs_datatype_t datatype,
214 int time_step,
215 double time_value,
216 const void *const field_values[]);
217
218/*----------------------------------------------------------------------------
219 * Flush files associated with a given writer.
220 *
221 * In this case, the effective writing to file is done.
222 *
223 * parameters:
224 * writer <-- pointer to associated writer
225 *----------------------------------------------------------------------------*/
226
227void
228fvm_to_histogram_flush(void *writer);
229
230/*----------------------------------------------------------------------------*/
231
233
234#endif /* __FVM_TO_HISTOGRAM_H__ */
cs_datatype_t
Definition cs_defs.h:300
Definition cs_defs.h:542
Definition cs_defs.h:342
cs_interlace_t
Definition cs_defs.h:514
unsigned cs_gnum_t
global mesh entity number
Definition cs_defs.h:327
Definition cs_defs.h:543
Definition cs_defs.h:335
void fvm_to_histogram_set_mesh_time(void *writer, const int time_step, const double time_value)
Definition fvm_to_histogram.cpp:699
Definition fvm_to_histogram.h:55
@ CS_HISTOGRAM_PNG
Definition fvm_to_histogram.h:58
@ CS_HISTOGRAM_TXT
Definition fvm_to_histogram.h:56
@ CS_HISTOGRAM_TEX
Definition fvm_to_histogram.h:57
void fvm_to_histogram_export_field(void *writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
Definition fvm_to_histogram.cpp:737
void * fvm_to_histogram_init_writer(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency)
Definition fvm_to_histogram.cpp:550
void * fvm_to_histogram_finalize_writer(void *writer)
Definition fvm_to_histogram.cpp:666
void fvm_to_histogram_flush(void *writer)
Definition fvm_to_histogram.cpp:827
void fvm_to_histogram_display_t(cs_real_t var_min, cs_real_t var_max, cs_gnum_t count[], fvm_to_histogram_writer_t *w, char *var_name)
Definition fvm_to_histogram.h:104
Definition fvm_writer.h:57
Definition fvm_writer.h:69
Definition mesh.f90:26
Definition fvm_to_histogram.h:65
int n_sub
Definition fvm_to_histogram.h:83
int n_ranks
Definition fvm_to_histogram.h:71
FILE * f
Definition fvm_to_histogram.h:81
Definition fvm_to_histogram.h:73
char * path
Definition fvm_to_histogram.h:68
char * name
Definition fvm_to_histogram.h:67
int rank
Definition fvm_to_histogram.h:70
char * file_name
Definition fvm_to_histogram.h:80
double t
Definition fvm_to_histogram.h:76
int nt
Definition fvm_to_histogram.h:75
cs_real_t * buffer
Definition fvm_to_histogram.h:78
