#include "base/cs_base.h"#include "base/cs_field.h"#include "base/cs_volume_zone.h"#include "base/cs_boundary_zone.h"#include "base/cs_ibm.h"Go to the source code of this file.
| typedef void | cs_ibm_volume_func_t(const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, cs_real_t *retval) |
| typedef void | cs_ibm_fsi_func_t(cs_real_t *retval) |
| void | cs_meg_boundary_function (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *field_name, const char *condition, cs_real_t *retvals) |
| This function is used to compute user defined values for fields over a given boundary zone. The mathematical expression is defined in the GUI. | |
| void | cs_meg_volume_function (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *fields_names, cs_real_t *fvals[]) |
| This function is used to compute user defined values for fields over a given volume zone. The mathematical expression is defined in the GUI. | |
| void | cs_meg_initialization (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *field_name, cs_real_t *retvals) |
| This function is used for the initalization of fields over a given volume zone. The mathematical expression is defined in the GUI. | |
| void | cs_meg_source_terms (const char *zone_name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], const char *name, const char *source_type, cs_real_t *retvals) |
| This function is used to compute source terms over a volume zone. The mathematical expression is defined in the GUI. | |
| void | cs_meg_fsi_struct (const char *object_type, const char *name, const cs_real_t fluid_f[], cs_real_t val[]) |
| This function is used to query FSI internal coupling structure values for a given boundary and structure. | |
| void | cs_meg_post_activate (void) |
| This function is used to activate postprocessing writers. | |
| void | cs_meg_post_profiles (const char *name, int n_coords, cs_real_t coords[][3]) |
| This function is used to define profile coordinates. | |
| void | cs_meg_post_calculator (const char *name, const cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t xyz[][3], cs_real_t *retvals) |
| This function is used to compute user defined calculator formulae. The mathematical expression is defined in the GUI. | |
| cs_cutcell_func_t * | cs_meg_ibm_func_by_name (const char *object_name) |
| This function is used to get the cs_cutcell_func_t pointer for a given object. | |
| cs_ibm_volume_func_t * | cs_meg_ibm_volume_func_by_name (const char *object_name, const char *gui_var_name) |
| This function is used to get the cs_ibm_volume_func_t pointer for a given object. | |
| cs_ibm_fsi_func_t * | cs_meg_ibm_fsi_func_by_name (const char *object_name, const char *gui_var_name) |
| This function is used to get the cs_ibm_fsi_func_t pointer for a given object. | |
| typedef void cs_ibm_fsi_func_t(cs_real_t *retval) |
| typedef void cs_ibm_volume_func_t(const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, cs_real_t *retval) |
| void cs_meg_boundary_function | ( | const char * | zone_name, |
| const cs_lnum_t | n_elts, | ||
| const cs_real_t | xyz[][3], | ||
| const char * | field_name, | ||
| const char * | condition, | ||
| cs_real_t * | retvals ) |
| [in] | zone_name | name of a boundary zone |
| [in] | n_elts | number of elements related to the zone |
| [in] | elt_ids | list of element ids related to the zone |
| [in] | xyz | list of coordinates related to the zone |
| [in] | field_name | name of the variable field |
| [in] | condition | condition type defined as a string |
| [out] | retvals | array of computed values |
| void cs_meg_fsi_struct | ( | const char * | object_type, |
| const char * | name, | ||
| const cs_real_t | fluid_f[], | ||
| cs_real_t | val[] ) |
| [in] | object_type | name of object type |
| [in] | name | name of matching boundary |
| [in] | fluid_f | array of fluid forces on the object |
| [in,out] | val[] | matrix or vector coefficients |
| cs_ibm_fsi_func_t * cs_meg_ibm_fsi_func_by_name | ( | const char * | object_name, |
| const char * | gui_var_name ) |
| [in] | object_name | Name of the immersed object |
| [in] | var_name | Name of the variable |
| cs_cutcell_func_t * cs_meg_ibm_func_by_name | ( | const char * | object_name | ) |
| [in] | object_name | name of the object |
| cs_ibm_volume_func_t * cs_meg_ibm_volume_func_by_name | ( | const char * | object_name, |
| void cs_meg_initialization | ( | const char * | zone_name, |
The caller is responsible for freeing the associated array.
| [in] | zone_name | name of a volume zone |
| [in] | field_name | associated variable field name |
| void cs_meg_post_activate | ( | void | ) |
| void cs_meg_post_calculator | ( | const char * | name, |
| [in] | field_name | function name |
| void cs_meg_post_profiles | ( | const char * | name, |
| int | n_coords, | ||
| cs_real_t | coords[][3] ) |
| [in] | name | name of matching profile |
| [in] | n_coords | number of point coordinates |
| [in,out] | coords | point coordinates |
| void cs_meg_source_terms | ( | const char * | zone_name, |
| const char * | source_type, | ||
The caller is responsible for freeing the returned array.
| [in] | field_name | variable field name |
| [in] | source_type | source term type |
| void cs_meg_volume_function | ( | const char * | zone_name, |
| const char * | fields_names, | ||
| cs_real_t * | fvals[] ) |
| [in,out] | f | array of pointers to cs_field_t structures |
