8.3
cs_elec_model.h File Reference
#include "cs_domain.h"
+ Include dependency graph for cs_elec_model.h:
Data Structures
struct  cs_data_elec_t
 physical properties for electric model descriptor. More...
struct  cs_data_joule_effect_t
 Structure to read transformer parameters in dp_ELE. More...
struct  cs_elec_option_t
 option for electric model More...
cs_elec_option_tcs_get_glob_elec_option (void)
cs_data_joule_effect_tcs_get_glob_transformer (void)
void cs_electrical_model_initialize (void)
void cs_electrical_model_finalize (void)
void cs_electrical_model_specific_initialization (void)
void cs_electrical_properties_read (void)
void cs_elec_compute_fields (const cs_mesh_t *mesh, int call_id)
void cs_elec_physical_properties (cs_domain_t *domain)
void cs_elec_source_terms (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int f_id, cs_real_t *smbrs)
void cs_elec_source_terms_v (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int f_id, cs_real_3_t *smbrv)
void cs_elec_add_variable_fields (void)
void cs_elec_add_property_fields (void)
void cs_elec_fields_initialize (const cs_mesh_t *mesh)
void cs_elec_scaling_function (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *dt)
void cs_elec_convert_h_to_t_faces (const cs_real_t h[], cs_real_t t[])
 Convert enthalpy to temperature at all boundary faces. More...
cs_real_t cs_elec_convert_h_to_t (const cs_real_t ym[], cs_real_t enthal)
 Convert single enthalpy value to temperature. More...
void cs_elec_convert_t_to_h_cells (const cs_real_t t[], cs_real_t h[])
 Convert temperature to enthalpy at all cells. More...
void cs_elec_convert_t_to_h_faces (const cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t t[], cs_real_t h[])
 Convert temperature to enthalpy at selected boundary faces. More...
cs_real_t cs_elec_convert_t_to_h (const cs_real_t ym[], cs_real_t temp)
 Convert single temperature value to enthalpy. More...
void cs_elec_define_functions (void)
 Create or access function objects specific to electric arcs models. More...
const cs_elec_option_tcs_glob_elec_option
const cs_data_elec_tcs_glob_elec_properties
const cs_data_joule_effect_tcs_glob_transformer
const cs_real_t cs_elec_permvi
const cs_real_t cs_elec_epszer
◆ cs_elec_add_property_fields()
void cs_elec_add_property_fields ( void  )
◆ cs_elec_add_variable_fields()
void cs_elec_add_variable_fields ( void  )
◆ cs_elec_compute_fields()
void cs_elec_compute_fields ( const cs_mesh_t mesh,
int  call_id
◆ cs_elec_convert_h_to_t()
cs_real_t cs_elec_convert_h_to_t ( const cs_real_t  ym[],
cs_real_t  enthal
[in]ymmass fraction for each gas
[in,out]enthalenthlapy value
temperature value
◆ cs_elec_convert_h_to_t_faces()
void cs_elec_convert_h_to_t_faces ( const cs_real_t  h[],
cs_real_t  t[]
This handles both user and model enthalpy conversions, so can be used safely whenever conversion is needed.
[in]henthalpy values
[out]ttemperature values
◆ cs_elec_convert_t_to_h()
cs_real_t cs_elec_convert_t_to_h ( const cs_real_t  ym[],
cs_real_t  temp
[in,out]temptemperature value
enthalpy values
◆ cs_elec_convert_t_to_h_cells()
void cs_elec_convert_t_to_h_cells ( const cs_real_t  t[],
cs_real_t  h[]
This handles both user and model temperature conversions, so can be used safely whenever conversion is needed.
[in]ttemperature values
[out]henthalpy values
◆ cs_elec_convert_t_to_h_faces()
void cs_elec_convert_t_to_h_faces ( const cs_lnum_t  n_faces,
cs_real_t  h[]
[in]n_facesnumber of selected faces
[in]face_idsids of selected faces
[in]ttemperature values (defined on all boundary faces)
[out]henthalpy values (defined on all boundary faces)
◆ cs_elec_define_functions()
void cs_elec_define_functions ( void  )
◆ cs_elec_fields_initialize()
void cs_elec_fields_initialize ( const cs_mesh_t mesh)
◆ cs_elec_physical_properties()
void cs_elec_physical_properties ( cs_domain_t domain)
◆ cs_elec_scaling_function()
void cs_elec_scaling_function ( const cs_mesh_t mesh,
const cs_mesh_quantities_t mesh_quantities,
cs_real_t dt
◆ cs_elec_source_terms()
void cs_elec_source_terms ( const cs_mesh_t mesh,
int  f_id,
cs_real_t smbrs
◆ cs_elec_source_terms_v()
void cs_elec_source_terms_v ( const cs_mesh_t mesh,
int  f_id,
cs_real_3_t smbrv
◆ cs_electrical_model_finalize()
void cs_electrical_model_finalize ( void  )
◆ cs_electrical_model_initialize()
void cs_electrical_model_initialize ( void  )
◆ cs_electrical_model_specific_initialization()
void cs_electrical_model_specific_initialization ( void  )
◆ cs_electrical_properties_read()
void cs_electrical_properties_read ( void  )
◆ cs_get_glob_elec_option()
cs_elec_option_t * cs_get_glob_elec_option ( void  )
◆ cs_get_glob_transformer()
cs_data_joule_effect_t * cs_get_glob_transformer ( void  )
◆ cs_elec_epszer
extern
vacuum permittivity constant (F/m). (= 8.854e-12)
◆ cs_elec_permvi
extern
vacuum magnetic permeability constant (H/m). (= 1.2566e-6)
◆ cs_glob_elec_option
const cs_elec_option_t* cs_glob_elec_option
extern
◆ cs_glob_elec_properties
const cs_data_elec_t* cs_glob_elec_properties
extern
◆ cs_glob_transformer
const cs_data_joule_effect_t* cs_glob_transformer
extern
