1#ifndef __CS_ELEC_MODEL_H__
2#define __CS_ELEC_MODEL_H__
Definition: cs_defs.h:542
Definition: cs_defs.h:342
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:359
Definition: cs_defs.h:543
Definition: cs_defs.h:335
void cs_elec_fields_initialize(const cs_mesh_t *mesh)
Definition: cs_elec_model.cpp:1980
void cs_elec_add_property_fields(void)
Definition: cs_elec_model.cpp:1856
cs_elec_option_t * cs_get_glob_elec_option(void)
Definition: cs_elec_model.cpp:685
void cs_elec_source_terms(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int f_id, cs_real_t *smbrs)
Definition: cs_elec_model.cpp:1671
void cs_electrical_properties_read(void)
Definition: cs_elec_model.cpp:871
const cs_real_t cs_elec_epszer
Definition: cs_elec_model.cpp:279
cs_real_t cs_elec_convert_t_to_h(const cs_real_t ym[], cs_real_t temp)
Convert single temperature value to enthalpy.
Definition: cs_elec_model.cpp:2438
const cs_data_elec_t * cs_glob_elec_properties
void cs_electrical_model_initialize(void)
Definition: cs_elec_model.cpp:705
void cs_elec_add_variable_fields(void)
Definition: cs_elec_model.cpp:1764
void cs_elec_convert_t_to_h_cells(const cs_real_t t[], cs_real_t h[])
Convert temperature to enthalpy at all cells.
Definition: cs_elec_model.cpp:2327
const cs_data_joule_effect_t * cs_glob_transformer
void cs_elec_define_functions(void)
Create or access function objects specific to electric arcs models.
Definition: cs_elec_model.cpp:2486
void cs_electrical_model_finalize(void)
Definition: cs_elec_model.cpp:749
void cs_elec_physical_properties(cs_domain_t *domain)
Definition: cs_elec_model.cpp:1065
void cs_elec_convert_t_to_h_faces(const cs_lnum_t n_faces, const cs_lnum_t face_ids[], const cs_real_t t[], cs_real_t h[])
Convert temperature to enthalpy at selected boundary faces.
Definition: cs_elec_model.cpp:2381
const cs_elec_option_t * cs_glob_elec_option
void cs_elec_compute_fields(const cs_mesh_t *mesh, int call_id)
Definition: cs_elec_model.cpp:1391
cs_real_t cs_elec_convert_h_to_t(const cs_real_t ym[], cs_real_t enthal)
Convert single enthalpy value to temperature.
Definition: cs_elec_model.cpp:2268
void cs_electrical_model_specific_initialization(void)
Definition: cs_elec_model.cpp:786
void cs_elec_convert_h_to_t_faces(const cs_real_t h[], cs_real_t t[])
Convert enthalpy to temperature at all boundary faces.
Definition: cs_elec_model.cpp:2213
cs_data_joule_effect_t * cs_get_glob_transformer(void)
Definition: cs_elec_model.cpp:695
const cs_real_t cs_elec_permvi
Definition: cs_elec_model.cpp:273
void cs_elec_scaling_function(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *dt)
Definition: cs_elec_model.cpp:2026
void cs_elec_source_terms_v(const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int f_id, cs_real_3_t *smbrv)
Definition: cs_elec_model.cpp:1732
@ t
Definition: cs_field_pointer.h:94
@ h
Definition: cs_field_pointer.h:93
@ dt
physical properties for electric model descriptor.
Definition: cs_elec_model.h:56
cs_real_t * sigel
Definition: cs_elec_model.h:64
int ngaz
Definition: cs_elec_model.h:58
cs_real_t * th
Definition: cs_elec_model.h:60
int npoint
Definition: cs_elec_model.h:59
cs_real_t * cpel
Definition: cs_elec_model.h:63
cs_real_t * xkabel
Definition: cs_elec_model.h:67
cs_real_t * xlabel
Definition: cs_elec_model.h:66
cs_real_t * rhoel
Definition: cs_elec_model.h:62
cs_real_t * ehgaz
Definition: cs_elec_model.h:61
cs_real_t * visel
Definition: cs_elec_model.h:65
Structure to read transformer parameters in dp_ELE.
Definition: cs_elec_model.h:75
int nbtrf
Definition: cs_elec_model.h:81
cs_real_t * uioff
Definition: cs_elec_model.h:90
cs_real_t * zi
Definition: cs_elec_model.h:88
int nbelec
Definition: cs_elec_model.h:77
cs_real_t * rnbs
Definition: cs_elec_model.h:86
int ntfref
Definition: cs_elec_model.h:82
int * ibrpr
Definition: cs_elec_model.h:83
cs_real_t * tenspr
Definition: cs_elec_model.h:85
int * ielect
Definition: cs_elec_model.h:79
cs_real_t * zr
Definition: cs_elec_model.h:87
int * ielecc
Definition: cs_elec_model.h:78
int * ielecb
Definition: cs_elec_model.h:80
cs_real_t * uroff
Definition: cs_elec_model.h:89
int * ibrsec
Definition: cs_elec_model.h:84
Definition: cs_domain.h:129
option for electric model
Definition: cs_elec_model.h:98
cs_real_t pot_diff
Definition: cs_elec_model.h:114
cs_real_t srrom
Definition: cs_elec_model.h:120
int idreca
Definition: cs_elec_model.h:110
int irestrike
Definition: cs_elec_model.h:102
int * izreca
Definition: cs_elec_model.h:111
int ixkabe
Definition: cs_elec_model.h:100
cs_real_t couimp
Definition: cs_elec_model.h:112
cs_real_t puisim
Definition: cs_elec_model.h:115
cs_real_t coejou
Definition: cs_elec_model.h:117
cs_real_t elcou
Definition: cs_elec_model.h:119
int ielcor
Definition: cs_elec_model.h:108
int modrec
Definition: cs_elec_model.h:109
int ntdcla
Definition: cs_elec_model.h:101
