8.3
cs_elec_option_t Struct Reference
option for electric model More...
#include <cs_elec_model.h>
+ Collaboration diagram for cs_elec_option_t:
Data Fields
int ixkabe
int ntdcla
int irestrike
cs_real_t restrike_point [3]
cs_real_t crit_reca [5]
int ielcor
int modrec
int idreca
int * izreca
cs_real_t couimp
cs_real_t pot_diff
cs_real_t puisim
cs_real_t coejou
cs_real_t elcou
cs_real_t srrom
Field Documentation
◆ coejou
coejou
scaling coefficient
coefficient for scaling
◆ couimp
couimp
Imposed current.
With the electric arcs module, couimp is the target current intensity ( $A$) for the calculations with boundary condition tuning for the potential.
The target intensity will be reached if the boundary conditions are expressed using the variable pot_diff or if the initial boundary conditions are multiplied by the variable coejou.
Useful with the electric arcs module if ielcor = 1.
◆ crit_reca
crit_reca
Defines plane coordinates component used to calculate current in a plane.
Useful if modrec = 2.
◆ elcou
elcou
electrical current
current in scaling plane
◆ idreca
idreca
Defines the current density component used to calculate current in a plane.
◆ ielcor
ielcor
0 : electric arc scaling desactivate 1 : electric arc scaling activate
Indicate if scaling or not.
When ielcor = 1, the boundary conditions for the potential will be tuned at each time step in order to reach a user-specified target dissipated power puisim (Joule effect) or a user-specified target current intensity couimp (electric arcs).
The boundary condition tuning is controlled by subroutines elreca or Scaling parameters definition for electric model (cs_user_electric_scaling.cpp).
◆ irestrike
irestrike
Indicate if restrike or not
◆ ixkabe
ixkabe
Model for radiative properties
  • 0: last column read but not use
  • 1: last column : absorption coefficient
  • 2: last column : radiative ST
◆ izreca
izreca
Indicator for faces for scaling
◆ modrec
modrec
Model for scaling
  • 1: volumic power for boundary conditions tuning,
  • 2: by plane for boundary conditions tuning,
  • 3: user function for boundary conditions tuning. In this case, we need to define the plane and the current density component used.
◆ ntdcla
ntdcla
First iteration to take into account restrike model
◆ pot_diff
pot_diff
potential between electrodes
Potential difference.
pot_diff is the potential difference ( $V$) which generates the current (and the Joule effect) for the calculations with boundary conditions tuning for the potential. This value is initialised set by the user (cs_user_parameters). It is then automatically tuned depending on the value of dissipated power (Joule effect module) or the intensity of current (electric arcs module). In order for the correct power or intensity to be reached, the boundary conditions for the potential must be expressed with pot_diff . The tuning can be controlled in cs_user_electric_scaling.
Useful if ielcor = 1.
◆ puisim
puisim
Imposed power.
With the Joule effect module, puisim is the target dissipated power ($W$) for the calculations with boundary condition tuning for the potential.
The target power will be reached if the boundary conditions are expressed using the variable pot_diff or if the initial boundary conditions are multiplied by the variable coejou . Useful with the Joule effect module if ielcor = 1.
◆ restrike_point
restrike_point
Coordinates for restrike point
◆ srrom
srrom
Sub-relaxation coefficient for the density, following the formula: $\rho^{n+1}$\,=\,srrom\,$\rho^n$+(1-srrom)\,$\rho^{n+1}$ Hence, with a zero value, there is no sub-relaxation.
