8.2
cs_xdef_cw_eval.c File Reference
#include <ctype.h>
#include <bft_mem.h>
#include "cs_mesh_location.h"
#include "cs_reco.h"
#include "cs_reco_cw.h"
#include "cs_xdef_cw_eval.h"
+ Include dependency graph for cs_xdef_cw_eval.c:
void cs_xdef_cw_eval_f_int_by_analytic (const cs_cell_mesh_t *cm, double t_eval, short int f, cs_analytic_func_t *ana, void *input, cs_quadrature_tria_integral_t *qfunc, cs_real_t *eval)
 Integrate an analytic function over a face. More...
void cs_xdef_cw_eval_c_int_by_analytic (const cs_cell_mesh_t *cm, double t_eval, cs_analytic_func_t *ana, void *input, cs_quadrature_tetra_integral_t *qfunc, cs_real_t *eval)
 Integrate an analytic function over a cell. More...
void cs_xdef_cw_eval_fc_int_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_analytic_func_t *ana, void *input, const short int dim, cs_quadrature_tetra_integral_t *q_tet, cs_quadrature_tria_integral_t *q_tri, cs_real_t *c_int, cs_real_t *f_int)
 Routine to integrate an analytic function over a cell and its faces. More...
void cs_xdef_cw_eval_scalar_face_avg_by_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating the average on a face of a scalar function defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure) More...
void cs_xdef_cw_eval_vector_face_avg_by_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating the average on a face of a vector function defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure) More...
void cs_xdef_cw_eval_tensor_face_avg_by_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating the average on a face of a tensor function defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure) More...
void cs_xdef_cw_eval_scalar_avg_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure). This evaluation hinges on the computation of integrals. More...
void cs_xdef_cw_eval_vector_avg_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure). This evaluation hinges on the computation of integrals Vector-valued case. More...
void cs_xdef_cw_eval_tensor_avg_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a cellwise process (usage of a cs_cell_mesh_t structure). This evaluation hinges on the computation of integrals Tensor-valued case. More...
void cs_xdef_cw_eval_by_time_func (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity by a cellwise process using a definition by time function. More...
void cs_xdef_cw_eval_by_analytic (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity at the cell center defined using an analytic function by a cellwise process (usage of a cs_cell_mesh_t structure) More...
void cs_xdef_cw_eval_by_array (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity at cells defined by an array. Array is assumed to be interlaced. Variation using a cs_cell_mesh_t structure. More...
void cs_xdef_cw_eval_by_field (const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
 Evaluate a quantity inside a cell defined using a field Variation using a cs_cell_mesh_t structure. More...
void cs_xdef_cw_eval_at_xyz_by_analytic (const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval)
 Function pointer for evaluating a quantity defined by analytic function at a precise location (x, y, z) inside a cell Use of a cs_cell_mesh_t structure. More...
void cs_xdef_cw_eval_vector_at_xyz_by_array (const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval)
 Function pointer for evaluating a quantity defined by analytic function at a precise location inside a cell Use of a cs_cell_mesh_t structure. Vector-valued case. More...
void cs_xdef_cw_eval_vector_at_xyz_by_field (const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval)
 Function pointer for evaluating a quantity defined by a field at a precise location inside a cell Use of a cs_cell_mesh_t structure. Vector-valued case. More...
void cs_xdef_cw_eval_flux_v_by_scalar_val (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_real_t *eval)
 Function pointer for evaluating the normal flux defined by scalar-valued quantities. The normal flux is then added to each portion of face related to a vertex. Use of a cs_cell_mesh_t structure. More...
void cs_xdef_cw_eval_flux_v_by_vector_val (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_real_t *eval)
 Function pointer for evaluating the normal flux defined by vector-valued quantities. The normal flux is then added to each portion of face related to a vertex. Use of a cs_cell_mesh_t structure. More...
void cs_xdef_cw_eval_flux_v_by_scalar_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating the normal flux defined by a scalar-valued quantities and relying on an analytic function. The normal flux is then added to each portion of face related to a vertex. Use of a cs_cell_mesh_t structure. More...
void cs_xdef_cw_eval_flux_v_by_vector_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating the normal flux defined by a vector-valued quantities and relying on an analytic function. The normal flux is then added to each portion of face related to a vertex. Use of a cs_cell_mesh_t structure. More...
void cs_xdef_cw_eval_flux_by_scalar_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating the normal flux of a quantity defined by analytic function (scalar-valued) at the face f. Use of a cs_cell_mesh_t structure. More...
void cs_xdef_cw_eval_flux_by_vector_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating the (scalar-valued) normal flux of a quantity defined by an analytic function. Use of a cs_cell_mesh_t structure. More...
void cs_xdef_cw_eval_vector_flux_by_analytic (const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating the normal vector-valued flux of a quantity defined by analytic function for the face f Use of a cs_cell_mesh_t structure. Case of a vector-valued quantities. More...
void cs_xdef_cw_eval_scal_avg_reduction_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating the reduction by averages of a analytic function by a cellwise process (usage of a cs_cell_mesh_t structure). This evaluation hinges on the computation of integrals (faces first, then cell) Scalar-valued case. More...
void cs_xdef_cw_eval_vect_avg_reduction_by_analytic (const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
 Function pointer for evaluating the reduction by averages of a analytic function by a cellwise process (usage of a cs_cell_mesh_t structure). This evaluation hinges on the computation of integrals (faces first, then cell) Vector-valued case. More...
◆ cs_xdef_cw_eval_at_xyz_by_analytic()
void cs_xdef_cw_eval_at_xyz_by_analytic ( const cs_cell_mesh_t cm,
cs_lnum_t  n_points,
const cs_real_t xyz,
void *  context,
cs_real_t eval
[in]n_pointsnumber of points where to compute the evaluation
[in]xyzwhere to compute the evaluation
[in]contextpointer to a context structure
[in,out]evalresult of the evaluation
◆ cs_xdef_cw_eval_by_analytic()
void cs_xdef_cw_eval_by_analytic ( const cs_cell_mesh_t cm,
void *  context,
cs_real_t eval
[in,out]evalresult of the evaluation at cell center
◆ cs_xdef_cw_eval_by_array()
void cs_xdef_cw_eval_by_array ( const cs_cell_mesh_t cm,
void *  context,
cs_real_t eval
◆ cs_xdef_cw_eval_by_field()
void cs_xdef_cw_eval_by_field ( const cs_cell_mesh_t cm,
void *  context,
cs_real_t eval
[in,out]evalvalue of the property at the cell center
◆ cs_xdef_cw_eval_by_time_func()
void cs_xdef_cw_eval_by_time_func ( const cs_cell_mesh_t cm,
void *  context,
cs_real_t eval
[out]evalresult of the evaluation
◆ cs_xdef_cw_eval_c_int_by_analytic()
void cs_xdef_cw_eval_c_int_by_analytic ( const cs_cell_mesh_t cm,
double  t_eval,
cs_analytic_func_t ana,
void *  input,
cs_quadrature_tetra_integral_t qfunc,
cs_real_t eval
[in]t_evaltime at which the function is evaluated
[in]anaanalytic function to integrate
[in]inputpointer to an input structure
[in]qfuncquadrature function to use
◆ cs_xdef_cw_eval_f_int_by_analytic()
void cs_xdef_cw_eval_f_int_by_analytic ( const cs_cell_mesh_t cm,
double  t_eval,
short int  f,
void *  input,
cs_quadrature_tria_integral_t qfunc,
cs_real_t eval
DOXYGEN_SHOULD_SKIP_THIS
[in]fface id in the local cell numbering
◆ cs_xdef_cw_eval_fc_int_by_analytic()
void cs_xdef_cw_eval_fc_int_by_analytic ( const cs_cell_mesh_t cm,
cs_real_t  t_eval,
void *  input,
cs_quadrature_tetra_integral_t q_tet,
cs_quadrature_tria_integral_t q_tri,
cs_real_t c_int,
cs_real_t f_int
[in]t_evalphysical time at which one evaluates the term
[in]dimdimension of the function
[in]q_tetquadrature function to use on tetrahedra
[in]q_triquadrature function to use on triangles
[out]c_intresult of the evaluation on the cell
[out]f_intresult of the evaluation on the faces
◆ cs_xdef_cw_eval_flux_by_scalar_analytic()
void cs_xdef_cw_eval_flux_by_scalar_analytic ( const cs_cell_mesh_t cm,
short int  f,
void *  context,
cs_real_t eval
[in]flocal face id
[in]qtypelevel of quadrature to use
[in,out]evalarray of values at DoFs
◆ cs_xdef_cw_eval_flux_by_vector_analytic()
void cs_xdef_cw_eval_flux_by_vector_analytic ( const cs_cell_mesh_t cm,
short int  f,
void *  context,
cs_real_t eval
[in]flocal face id
[in,out]evalarray of evaluations at DoFs
◆ cs_xdef_cw_eval_flux_v_by_scalar_analytic()
void cs_xdef_cw_eval_flux_v_by_scalar_analytic ( const cs_cell_mesh_t cm,
short int  f,
void *  context,
cs_real_t eval
[in]flocal face id
[in,out]evalarray of Neumann fluxes at DoFs
◆ cs_xdef_cw_eval_flux_v_by_scalar_val()
void cs_xdef_cw_eval_flux_v_by_scalar_val ( const cs_cell_mesh_t cm,
short int  f,
void *  context,
cs_real_t eval
[in]flocal face id
◆ cs_xdef_cw_eval_flux_v_by_vector_analytic()
void cs_xdef_cw_eval_flux_v_by_vector_analytic ( const cs_cell_mesh_t cm,
short int  f,
void *  context,
cs_real_t eval
[in]flocal face id
◆ cs_xdef_cw_eval_flux_v_by_vector_val()
void cs_xdef_cw_eval_flux_v_by_vector_val ( const cs_cell_mesh_t cm,
short int  f,
void *  context,
cs_real_t eval
[in]flocal face id
◆ cs_xdef_cw_eval_scal_avg_reduction_by_analytic()
void cs_xdef_cw_eval_scal_avg_reduction_by_analytic ( const cs_cell_mesh_t cm,
cs_real_t  t_eval,
void *  context,
cs_real_t eval
[in]qtypequadrature type
◆ cs_xdef_cw_eval_scalar_avg_by_analytic()
void cs_xdef_cw_eval_scalar_avg_by_analytic ( const cs_cell_mesh_t cm,
cs_real_t  t_eval,
void *  context,
cs_real_t eval
◆ cs_xdef_cw_eval_scalar_face_avg_by_analytic()
void cs_xdef_cw_eval_scalar_face_avg_by_analytic ( const cs_cell_mesh_t cm,
short int  f,
void *  context,
cs_real_t eval
[in]flocal face id
◆ cs_xdef_cw_eval_tensor_avg_by_analytic()
void cs_xdef_cw_eval_tensor_avg_by_analytic ( const cs_cell_mesh_t cm,
cs_real_t  t_eval,
void *  context,
cs_real_t eval
◆ cs_xdef_cw_eval_tensor_face_avg_by_analytic()
void cs_xdef_cw_eval_tensor_face_avg_by_analytic ( const cs_cell_mesh_t cm,
short int  f,
cs_real_t  t_eval,
void *  context,
cs_real_t eval
[in]flocal face id
◆ cs_xdef_cw_eval_vect_avg_reduction_by_analytic()
void cs_xdef_cw_eval_vect_avg_reduction_by_analytic ( const cs_cell_mesh_t cm,
cs_real_t  t_eval,
void *  context,
cs_real_t eval
◆ cs_xdef_cw_eval_vector_at_xyz_by_array()
void cs_xdef_cw_eval_vector_at_xyz_by_array ( const cs_cell_mesh_t cm,
cs_lnum_t  n_points,
void *  context,
cs_real_t eval
◆ cs_xdef_cw_eval_vector_at_xyz_by_field()
void cs_xdef_cw_eval_vector_at_xyz_by_field ( const cs_cell_mesh_t cm,
cs_lnum_t  n_points,
void *  context,
cs_real_t eval
◆ cs_xdef_cw_eval_vector_avg_by_analytic()
void cs_xdef_cw_eval_vector_avg_by_analytic ( const cs_cell_mesh_t cm,
cs_real_t  t_eval,
void *  context,
cs_real_t eval
◆ cs_xdef_cw_eval_vector_face_avg_by_analytic()
void cs_xdef_cw_eval_vector_face_avg_by_analytic ( const cs_cell_mesh_t cm,
short int  f,
cs_real_t  t_eval,
void *  context,
cs_real_t eval
[in]flocal face id
◆ cs_xdef_cw_eval_vector_flux_by_analytic()
void cs_xdef_cw_eval_vector_flux_by_analytic ( const cs_cell_mesh_t cm,
short int  f,
void *  context,
cs_real_t eval
[in]flocal face id
