8.2
cs_sys_coupling.c File Reference
#include <stdarg.h>
#include <mpi.h>
#include <ple_defs.h>
#include <ple_coupling.h>
#include <ple_locator.h>
#include "cs_coupling.h"
#include "cs_field_pointer.h"
#include "cs_prototypes.h"
#include "cs_thermal_model.h"
#include "cs_zone.h"
#include "cs_sys_coupling.h"
+ Include dependency graph for cs_sys_coupling.c:
cs_sys_cpl_tcs_sys_coupling_by_id (const int cpl_id)
 Get a cfd<-->sys coupling structure by its id. More...
cs_sys_cpl_tcs_sys_coupling_by_name_try (const char *sys_name)
 Try getting a cfd<-->sys coupling structure by its name. More...
cs_sys_cpl_tcs_sys_coupling_by_name (const char *sys_name)
 Get a cfd<-->sys coupling structure by its name. More...
void cs_sys_cplbc_add_field_to_send (cs_cfd_sys_cplbc_t *cplbc, const int field_id)
 Add a field to send during coupling to a given coupled BC. More...
void cs_sys_cplbc_add_field_to_recv (cs_cfd_sys_cplbc_t *cplbc, const int field_id)
 Add a field to recieve during coupling to a given coupled BC. More...
void cs_sys_cplbc_define_surf_coeff (cs_cfd_sys_cplbc_t *cplbc, const cs_real_t coeff)
 Define a surface coefficient to a given coupled BC. More...
void cs_sys_cplbc_inverse_bnd_dir (cs_cfd_sys_cplbc_t *cplbc)
 Define a flowrate inversion between CFD and System codes if signs are inversed for a given coupled BC. More...
void cs_sys_cplbc_add_exchanged_field (cs_cfd_sys_cplbc_t *cplbc, const int dir, const int field_id)
 Add a field to send/recv during coupling to a given coupled BC. More...
void cs_sys_coupling_add_cplbc (cs_sys_cpl_t *sys_coupling, cs_syscpl_bc_type_t type, const cs_zone_t *z_input, const char *sel_criteria_output, const char *element_name, const int c0, const int c1, const int n_sys_elts)
 Add a coupled condition to a cfd<-->sys coupling. More...
int cs_sys_coupling_add (const char *sys_name, const int n_cpl_phases)
 Add a cfd<->sys coupling. More...
void cs_sys_coupling_send_data (cs_sys_cpl_t *cpl)
 send data to system code More...
void cs_sys_coupling_recv_data (cs_sys_cpl_t *cpl)
 recieve data from system code More...
void cs_sys_coupling_all_init (void)
 Initialize cfd<->system coupling once all couplings are defined. More...
void cs_sys_coupling_all_finalize (void)
 Finalize all cfd<->sys couplings. More...
◆ cs_sys_coupling_add()
int cs_sys_coupling_add ( const char *  sys_name,
[in]sys_namename of the new coupling
[in]n_cpl_phasesnumber of phases to coupled
id of the newly created coupling
◆ cs_sys_coupling_add_cplbc()
void cs_sys_coupling_add_cplbc ( cs_sys_cpl_t sys_coupling,
const cs_zone_t z_input,
const char *  sel_criteria_output,
const char *  element_name,
const int  c0,
const int  c1,
[in]sys_couplingpointer to cfd<->sys coupling
[in]typetype of coupled condition
[in]z_inputcoupled zone (boundary or volume)
[in]sel_criteria_outputselection criteria for cfd->sys data selection
[in]element_namename of coupled sys element
[in]c0first sys cell index
[in]c1second sys cell index
[in]n_sys_eltsnumber of coupled cells in the system code
◆ cs_sys_coupling_all_finalize()
void cs_sys_coupling_all_finalize ( void  )
◆ cs_sys_coupling_all_init()
void cs_sys_coupling_all_init ( void  )
◆ cs_sys_coupling_by_id()
cs_sys_cpl_t* cs_sys_coupling_by_id ( const int  cpl_id)
[in]cpl_idid of the requested coupling
pointer to coupling structure if found, raises an error otherwise.
◆ cs_sys_coupling_by_name()
cs_sys_cpl_t* cs_sys_coupling_by_name ( const char *  sys_name)
[in]sys_namename of the requested coupling
pointer to coupling structure if found, raises and error if not found.
◆ cs_sys_coupling_by_name_try()
cs_sys_cpl_t* cs_sys_coupling_by_name_try ( const char *  sys_name)
pointer to coupling structure if found, NULL if not found.
◆ cs_sys_coupling_recv_data()
void cs_sys_coupling_recv_data ( cs_sys_cpl_t cpl)
[in]cplpointer to coupling structure.
◆ cs_sys_coupling_send_data()
void cs_sys_coupling_send_data ( cs_sys_cpl_t cpl)
◆ cs_sys_cplbc_add_exchanged_field()
void cs_sys_cplbc_add_exchanged_field ( cs_cfd_sys_cplbc_t cplbc,
const int  dir,
const int  field_id
[in]cplbcpointer to coupled condition
[in]dir0 send; 1 recv
[in]field_idid of the field to exchange
◆ cs_sys_cplbc_add_field_to_recv()
void cs_sys_cplbc_add_field_to_recv ( cs_cfd_sys_cplbc_t cplbc,
const int  field_id
[in]field_idid of the field to recieve
◆ cs_sys_cplbc_add_field_to_send()
void cs_sys_cplbc_add_field_to_send ( cs_cfd_sys_cplbc_t cplbc,
const int  field_id
[in]field_idid of the field to send
◆ cs_sys_cplbc_define_surf_coeff()
void cs_sys_cplbc_define_surf_coeff ( cs_cfd_sys_cplbc_t cplbc,
[in]coeffsurface coefficient to apply
◆ cs_sys_cplbc_inverse_bnd_dir()
void cs_sys_cplbc_inverse_bnd_dir ( cs_cfd_sys_cplbc_t cplbc)
