#include "cs_defs.h"#include <assert.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "fvm_writer.h"#include "cs_array.h"#include "cs_cell_to_vertex.h"#include "cs_field_operator.h"#include "cs_field_pointer.h"#include "cs_medcoupling_intersector.h"#include "cs_meg_prototypes.h"#include "cs_mesh_adjacencies.h"#include "cs_parameters.h"#include "cs_post.h"#include "cs_prototypes.h"#include "cs_stl.h"#include "cs_turbomachinery.h"#include "cs_velocity_pressure.h"#include "cs_vertex_to_cell.h"#include "cs_zone.h"#include "cs_ibm.h"
Include dependency graph for cs_ibm.c:Functions | |
| void | cs_f_immersed_boundaries (void) |
| void | cs_f_porosity_ibm_get_pointer (int **ibm_porosity_mode) |
| static cs_real_t | _geom_face_fraction (cs_real_t alphai, cs_real_t alphaj, cs_real_t sizei, cs_real_t sizej) |
| Compute the face porosity depending on the neighbouring cells porosities based on geometry. More... | |
| static cs_real_t | _imm_lgth_cutcell (cs_real_3_t x1, cs_real_3_t x2, cs_real_t t, int num_object) |
| Compute by dichotomy the length of the immersed part of a line between two points (i.e. the distance between the point in the solid and the immersed boundary) based on the cut-cell method. More... | |
| static cs_real_t | _imm_lgth_poro (cs_real_3_t x1, cs_real_t por1, cs_real_3_t x2, cs_real_t por2) |
| Compute by dichotomy the length of the immersed part of a line between two points (i.e. the distance between the point in the solid and the immersed boundary) based on the input porosities. More... | |
| static cs_real_t | _tetra_vol (cs_real_3_t x1, cs_real_3_t x2, cs_real_3_t x3, cs_real_3_t x4) |
| Compute the volume of a tetrahedron described by its vertices (x1,x2,x3,x4). More... | |
| static cs_real_t | _pyram_vol (cs_real_3_t x1, cs_real_3_t x2, cs_real_3_t x3, cs_real_3_t x4, cs_real_3_t x5) |
| Compute the volume of a pyramid with a quadrangle base (x1,x2,x3,x4) and apex (x5). More... | |
| static cs_real_t | _prism_vol (cs_real_3_t x1, cs_real_3_t x2, cs_real_3_t x3, cs_real_3_t x4, cs_real_3_t x5, cs_real_3_t x6) |
| Compute the volume of a prism with a quadrangle base (x3,x4,x5,x6) and edge (x1 x2). More... | |
| static void | _tetra_vol_poro (cs_real_t *vol, cs_real_3_t cog, cs_real_3_t x1, cs_real_t por1, cs_real_3_t x2, cs_real_t por2, cs_real_3_t x3, cs_real_t por3, cs_real_3_t x4, cs_real_t por4, int icut) |
| Compute the volume and center of gravity of a tetrahedron described by its vertices (x1,x2,x3,x4) but truncated due to solid parts identified with porosities, through a recursive approach. More... | |
| static cs_real_t | _tri_surf_trunc (cs_real_3_t x1, cs_real_t por1, cs_real_3_t x2, cs_real_t por2, cs_real_3_t x3, cs_real_t por3, int icut) |
| Compute by dichotomy the area of the immersed part of a triangle (x1,x2,x3) based on the input porosities at its vertices through a recursive approach. More... | |
| static void | _tetra_vol_cutcell (cs_real_t *vol, cs_real_3_t x1, cs_real_3_t x2, cs_real_3_t x3, cs_real_3_t x4, cs_real_t t, int icut, int num_object) |
| Compute (using bisection) the volume of the immersed part of a tetrahedron described by its vertices (x1,x2,x3,x4) based on the cut-cell method and recursive approach. More... | |
| static int | _penal_glob (const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, const int num_object) |
| Call to user function to know whether we are in the solid or not. More... | |
| static void | _compute_cell_cut_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, int *comp_cell) |
| Compute cell porosity using the cut cell method. More... | |
| static void | _compute_cell_cog (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *v_poro, cs_real_t *por_init, int *comp_cell) |
| Compute cell cog (and cell porosity from porosity at vertices) Cut method into sub-tetras. More... | |
| static void | _compute_b_fac_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *c_poro, cs_real_t *v_poro, cs_real_t *bfpro_poro) |
| Compute boundary faces porosity. More... | |
| static void | _compute_i_fac_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *c_poro, cs_real_t *v_poro, cs_real_t *ifpro_poro) |
| Compute internal faces porosity. More... | |
| static void | _compute_iso_vol_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *c_poro, int *comp_cell) |
| Iso-volume porosity check. More... | |
| static void | _compute_solid_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *c_poro, int *comp_cell) |
| Take into account internal solid porosity. More... | |
| static void | _compute_cell_list_porosity (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_lnum_t *comp_cell) |
| Compute list of cells for porosity computing. More... | |
| static void | _compute_solid_surface_vector (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *i_poro, cs_real_t *b_poro) |
| Compute porosity solid surface. More... | |
| static void | _compute_solid_surface_cog (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities, cs_real_t *c_poro, cs_real_t *v_poro, cs_real_t *i_poro, cs_real_t *b_poro) |
| Compute porosity solid surface cog (dist and ponderation coeff) More... | |
| static cs_ibm_object_t * | _create_ibm_object (const char *name, cs_ibm_algo_type_t method) |
| Create a new immersed boundary object with a given name and method. More... | |
| static int | _add_ibm_object (const char *name, cs_ibm_algo_type_t method) |
| Adds a new immersed boundary object with a given name and method. More... | |
| static void | _free_ibm_object (cs_ibm_object_t *obj) |
| Free a cs_ibm_object_t structure. More... | |
| static void | _ibm_object_define_property_def (cs_ibm_object_t *obj, cs_ibm_object_property_type_t ppty_id, int n_vals, cs_real_t *vals) |
| Define a new property definition for an object. More... | |
| static void | _ibm_object_define_initial_val_def (cs_ibm_object_t *obj, cs_ibm_object_init_param_t p_id, int n_vals, cs_real_t *vals) |
| Set initial value xdef for an object. More... | |
| static cs_real_t | _get_xdef_val_at_object_elt (const cs_xdef_t *def, const int elt_id) |
| Get xdef value at object element. More... | |
| cs_ibm_object_t * | cs_ibm_object_by_id (int obj_id) |
| Get an object based on its id. More... | |
| cs_ibm_object_t * | cs_ibm_object_by_name_try (const char *name) |
| Try to get an object based on its name. Returns NULL if not found. More... | |
| cs_ibm_object_t * | cs_ibm_object_by_name (const char *name) |
| Get an object based on its name. Error if not found. More... | |
| cs_ibm_t * | cs_ibm_create (void) |
| void | cs_ibm_finalize (void) |
| void | cs_immersed_boundaries (const cs_mesh_t *mesh, const cs_mesh_quantities_t *mesh_quantities) |
| Define immersed boundaries in time and space (solid(s) interior part). More... | |
| int | cs_ibm_object_compute_cut_porosity (const cs_lnum_t c_id, const cs_real_3_t xyz, const cs_real_t t, const int num_object) |
| Check if a point is solid or fluid based on the cut-cell method. More... | |
| void | cs_ibm_add_object_from_file (const char *name, cs_ibm_algo_type_t method, const char *file_name, bool solve_fsi) |
| Define an object from a file using STL or MED formats. More... | |
| void | cs_ibm_add_object_from_func (const char *name, cs_cutcell_func_t *cutcell_func, bool solve_fsi, int n_nodes) |
| Define an object from a function used in the cutcell algorithm. More... | |
| void | cs_ibm_stl_define_ext_points (const char *name, const int n_pts, cs_real_t *pts_coords) |
| Define exterior points for an stl object. More... | |
| void | cs_ibm_object_rotate (const char *name, cs_real_t angle, cs_real_t axis[3], cs_real_t center[3]) |
| Rotate an object based on the STL or MED algorithms. More... | |
| void | cs_ibm_object_set_property_const (cs_ibm_object_t *obj, cs_ibm_object_property_type_t ppty_id, cs_real_t val) |
| Define a new constant property definition for an object. More... | |
| void | cs_ibm_object_translate (const char *name, cs_real_t vector[3]) |
| Translate an object based on the STL or MED algorithms. More... | |
| void | cs_ibm_object_scale (const char *name, cs_real_t factor) |
| Scale an object based on a factor. More... | |
| void | cs_ibm_user_parameters (void) |
| Apply user parameters. More... | |
| void | cs_ibm_init_writer (void) |
| Init writers for STL or MED objects. More... | |
| void | cs_ibm_object_transform_from_init (cs_ibm_object_t *obj, cs_real_34_t matrix) |
| Transform an object from its initial state using a transformation matrix. More... | |
| void | cs_ibm_object_compute_intersect_vol (cs_ibm_object_t *obj, const cs_mesh_t *m, const cs_real_t *cell_vol, cs_real_t *obj_frac_tot, int *indic) |
| Compute the volume fraction of an object over all cells. More... | |
| void | cs_ibm_volumic_zone (const cs_mesh_quantities_t *mesh_quantities) |
| Define space immersed boundaries on a set of zones defined by the user in the GUI. More... | |
| static cs_porosity_ibm_opt_t | _porosity_ibm_opt |
| cs_porosity_ibm_opt_t * | cs_glob_porosity_ibm_opt = &(_porosity_ibm_opt) |
| cs_ibm_t * | cs_ibm = NULL |
| const char * | _ibm_algo_names [] |
| const char * | _ibm_obj_property_names [] |
| const char * | _ibm_obj_init_vals_names [] |
Define immersed boundaries based on user inputs (experimental). Cloud of points are dealt with porosity from scan files.
static |
| [in] | name | name of the new object |
| [in] | method | method used to compute the object porosity |
static |
| [in] | mesh | pointer to associated mesh structure |
| [in] | mesh_quantities | pointer to associated mesh quantities |
| [in] | c_poro | cell porosity |
| [in] | v_poro | vertex porosity |
| [out] | bfpro_poro | boundary face porosity |
static |
| [in] | por_vtx | vertex porosity |
| [in] | por_init | initialization porosity |
| [in] | comp_cell | list of cells to recompute porosity |
static |
static |
| [out] | comp_cell | list of cells to recompute porosity |
static |
| [out] | ifpro_poro | internal face porosity |
static |
static |
static |
| [in] | i_poro | internal face porosity |
| [in] | b_poro | boundary face porosity |
static |
static |
static |
| [in] | obj | pointer to structure to free |
static |
| [in] | alphai | value at neighbouring cell i |
| [in] | alphaj | value at neighbouring cell j |
| [in] | sizei | distance face - center of gravity cell i |
| [in] | sizej | distance face - center of gravity cell j |
inlinestatic |
| [in] | def | Pointer to cs_xdef_t definition |
| [in] | elt_id | Element id (int) |
static |
| [in] | obj | Pointer to object |
| [in] | p_id | Property id (enum) |
| [in] | n_vals | Number of values (array size) |
| [in] | vals | Values array (size n_vals) |
static |
| [in] | obj | pointer to object |
| [in] | ppty_id | property id (si enum for list) |
| [in] | n_vals | number of values (array size) |
| [in] | vals | array of values |
static |
| [in] | x1 | point 1 |
| [in] | x2 | point 2 |
| [in] | t | time value for the current time step |
| [in] | num_object | num of fsi object (if fsi activated) |
inlinestatic |
| [in] | por1 | porosity at 1 |
| [in] | por2 | porosity at 2 |
static |
| [in] | c_id | local cell number |
| [in] | xyz | x, y, z coordinates of the current position |
static |
| [in] | x3 | point 3 |
| [in] | x4 | point 4 |
| [in] | x5 | point 5 |
| [in] | x6 | point 6 |
static |
| [in] | x5 | point 5 (apex) |
inlinestatic |
static |
| [out] | vol | volume |
| [in] | icut | number of bisections |
static |
| [out] | cog | center of gravity |
| [in] | por1 | porosity at point 1 |
| [in] | por2 | porosity at point 2 |
| [in] | por3 | porosity at point 3 |
| [in] | por4 | porosity at point 4 |
| [in] | icut | number of sub-cut for cells in cut-cells algorithm |
static |
| [in] | por3 | porosity at 3 |
| void cs_f_immersed_boundaries | ( | void | ) |
| void cs_f_porosity_ibm_get_pointer | ( | int ** | ibm_porosity_mode | ) |
| void cs_ibm_add_object_from_file | ( | const char * | name, |
| cs_ibm_algo_type_t | method, | ||
| const char * | file_name, | ||
| bool | solve_fsi | ||
| [in] | name | name of the object |
| [in] | method | Porosity computation method |
| [in] | file_name | file name |
| [in] | solve_fsi | Is the object used in the FSI resolution ? (currently ignored) |
| void cs_ibm_add_object_from_func | ( | const char * | name, |
| cs_cutcell_func_t * | cutcell_func, | ||
| bool | solve_fsi, | ||
| int | n_nodes | ||
| [in] | cutcell_func | pointer to the cutcell function of the object |
| [in] | n_nodes | Number of nodes if the object is deformable (currently ignored) |
| cs_ibm_t* cs_ibm_create | ( | void | ) |
| void cs_ibm_finalize | ( | void | ) |
| void cs_ibm_init_writer | ( | void | ) |
| cs_ibm_object_t * cs_ibm_object_by_id | ( | int | obj_id | ) |
| [in] | obj_id | id of the object |
| cs_ibm_object_t* cs_ibm_object_by_name | ( | const char * | name | ) |
| [in] | name | name of the object to get |
| cs_ibm_object_t * cs_ibm_object_by_name_try | ( | const char * | name | ) |
| int cs_ibm_object_compute_cut_porosity | ( | const cs_lnum_t | c_id, |
| const cs_real_3_t | xyz, | ||
| const cs_real_t | t, | ||
| const int | num_object | ||
| void cs_ibm_object_compute_intersect_vol | ( | cs_ibm_object_t * | obj, |
| const cs_mesh_t * | m, | ||
| const cs_real_t * | cell_vol, | ||
| cs_real_t * | obj_frac_tot, | ||
| int * | indic | ||
| [in] | obj | pointer to object structure |
| [in] | m | pointer to mesh structure |
| [in] | cell_vol | pointer to cell volume array |
| [out] | obj_frac_tot | array containing the total vol fraction of solids |
| [in] | indic | indicator array (currently ignored) |
| void cs_ibm_object_rotate | ( | const char * | name, |
| cs_real_t | angle, | ||
| cs_real_t | axis[3], | ||
| cs_real_t | center[3] | ||
| [in] | angle | angle of rotation |
| [in] | axis | axis of rotation |
| [in] | center | center of rotation |
| void cs_ibm_object_scale | ( | const char * | name, |
| cs_real_t | factor | ||
| [in] | factor | scaling factor |
| void cs_ibm_object_set_property_const | ( | cs_ibm_object_t * | obj, |
| cs_ibm_object_property_type_t | ppty_id, | ||
| cs_real_t | val | ||
| [in] | val | property constant value |
| void cs_ibm_object_transform_from_init | ( | cs_ibm_object_t * | obj, |
| cs_real_34_t | matrix | ||
| [in] | matrix | transformation matrix |
| void cs_ibm_object_translate | ( | const char * | name, |
| cs_real_t | vector[3] | ||
| [in] | vector | translation vector |
| void cs_ibm_stl_define_ext_points | ( | const char * | name, |
| const int | n_pts, | ||
| cs_real_t * | pts_coords | ||
Define exterior points for an STL object.
| [in] | n_pts | number of points |
| [in] | pts_coords | coordinates of the points |
| void cs_ibm_user_parameters | ( | void | ) |
| void cs_ibm_volumic_zone | ( | const cs_mesh_quantities_t * | mesh_quantities | ) |
| [in] | mesh_quantities | pointer to associated mesh quantities structure |
| void cs_immersed_boundaries | ( | const cs_mesh_t * | mesh, |
| const cs_mesh_quantities_t * | mesh_quantities | ||
This function is called several times during each time step.
Ipenal: 1 means only solid and 0 only fluid.
Warning, porosity values have to be 0 or 1.
The solid(s) velocities and porosity are prescirbed within the user function (cs_user_ibm).
| const char* _ibm_algo_names[] |
| const char* _ibm_obj_init_vals_names[] |
| const char* _ibm_obj_property_names[] |
static |
| cs_porosity_ibm_opt_t* cs_glob_porosity_ibm_opt = &(_porosity_ibm_opt) |
| cs_ibm_t* cs_ibm = NULL |
