Files | |
| file | cs_user_1d_wall_thermal.c |
| Data Entry of the 1D wall thermal module. | |
| file | cs_user_atmospheric_model.f90 |
| User subroutines dedicated to the atmospheric model. | |
| file | cs_user_boundary_conditions.c |
| User functions for boundary condition definitions. | |
| file | cs_user_boundary_conditions.f90 |
User subroutine which fills boundary conditions arrays (icodcl, rcodcl) for solved variables. | |
| file | cs_user_coupling.c |
| Code couplings definition with SYRTHES and code_saturne. | |
| file | cs_user_electric_scaling.c |
| Define scaling parameter for electric model. | |
| file | cs_user_extra_operations.c |
| This function is called at the end of each time step, and has a very general purpose (i.e. anything that does not have another dedicated user function) | |
| file | cs_user_extra_operations.f90 |
| This function is called at the end of each time step, and has a very general purpose (i.e. anything that does not have another dedicated user subroutine) | |
| file | cs_user_fluid_structure_interaction.c |
| User-defined functions dedicated to Fluid-Structure interaction modeling. | |
| file | cs_user_head_losses.c |
| User head loss definitions. | |
| file | cs_user_hgn.c |
| Define user properties for two-phase homogeneous compressible model. | |
| file | cs_user_ibm.c |
| User function. Define immersed boundaries in time and space. | |
| file | cs_user_ibm_modify.c |
| User function. Locally modify a given porosity to take into account erosion effect (for instance). | |
| file | cs_user_initialization.c |
| Initialization prior to solving time steps. | |
| file | cs_user_initialization.f90 |
| Initialize variables. | |
| file | cs_user_lagr_boundary_conditions.c |
| file | cs_user_lagr_model.c |
| file | cs_user_lagr_particle.c |
| file | cs_user_lagr_volume_conditions.c |
| file | cs_user_les_inflow.c |
| Generation of synthetic turbulence at LES inlets initialization. | |
| file | cs_user_mesh.c |
| Definition and modification of the calculation mesh. | |
| file | cs_user_modules.f90 |
| User-defined module: it allows to create any user array. | |
| file | cs_user_paramedmem_coupling.c |
| User functions for input of ParaMEDMEM coupling parameters. | |
| file | cs_user_parameters.c |
| User functions for input of calculation parameters. | |
| file | cs_user_parameters.f90 |
| User subroutines for input of calculation parameters (Fortran modules). These subroutines are called in all cases. | |
| file | cs_user_performance_tuning.c |
| Definition of advanced options relative to parallelism. | |
| file | cs_user_physical_properties.c |
| User definition of physical properties. | |
| file | cs_user_physical_properties.f90 |
| Definition of physical variable laws. | |
| file | cs_user_porosity.c |
| User definitions of porous media. | |
| file | cs_user_postprocess.c |
| file | cs_user_radiative_transfer.c |
| User function for input of radiative transfer parameters: absorption coefficient and net radiation flux. | |
| file | cs_user_radiative_transfer_bcs.c |
| file | cs_user_solver.c |
| User solver setting and implementation. | |
| file | cs_user_source_terms.c |
| Additional source terms for variable equations. | |
| file | cs_user_source_terms.f90 |
| User subroutines for additional right-hand side source terms. | |
| file | cs_user_time_table.c |
| User definitions of time tables. | |
| file | cs_user_turbomachinery.c |
| Definition of turbomachinery related options. | |
| file | cs_user_wall_condensation.c |
| Source terms associated at the boundary faces and the neighboring cells with surface condensation. | |
| file | cs_user_zones.c |
| file | usatch.f90 |
| Routines for user defined atmospheric chemical scheme. | |
