Definition of physical variable laws. More...
Functions/Subroutines | |
| subroutine | usphyv (nvar, nscal, mbrom, dt) |
| Definition of physical variable laws. More... | |
See of 1-D thermal conduction Equation for examples.
| subroutine usphyv | ( | integer | nvar, |
| integer | nscal, | ||
| integer | mbrom, | ||
| double precision, dimension(ncelet) | dt | ||
It is forbidden to modify turbulent viscosity visct here (a specific subroutine is dedicated to that: cs_user_physical_properties_turb_viscosity)
viscls.ro0)viscl0)Warning: if the scalar is the temperature, cpro_vscalt corresponds to its conductivity (Lambda) in W/(m K)
The types of boundary faces at the previous time step are available (except at the first time step, where arrays itypfb and itrifb have not been initialized yet)
It is recommended to keep only the minimum necessary in this file (i.e. remove all unused example code)
Cells may be identified using the getcel subroutine. The syntax of this subroutine is described in the cs_user_boundary_conditions subroutine, but a more thorough description can be found in the user guide.
| [in] | nscal | total number of scalars |
| [in] | mbrom | indicator of filling of romb array |
