User function for input of radiative transfer parameters: absorption coefficient and net radiation flux. More...
#include "cs_defs.h"#include <assert.h>#include <string.h>#include <math.h>#include "cs_headers.h"
Include dependency graph for cs_user_radiative_transfer.c:Functions | |
| void | cs_user_radiative_transfer_parameters (void) |
| User function for input of radiative transfer module options. More... | |
| void | cs_user_rad_transfer_absorption (const int bc_type[], cs_real_t ck[]) |
| Absorption coefficient for radiative module. More... | |
| void | cs_user_rad_transfer_net_flux (const int bc_type[], const cs_real_t coefap[], const cs_real_t coefbp[], const cs_real_t cofafp[], const cs_real_t cofbfp[], const cs_real_t twall[], const cs_real_t qincid[], const cs_real_t xlam[], const cs_real_t epa[], const cs_real_t eps[], const cs_real_t ck[], cs_real_t net_flux[]) |
| Compute the net radiation flux. More... | |
See Examples of data settings for radiative transfers for examples.
| void cs_user_rad_transfer_absorption | ( | const int | bc_type[], |
| cs_real_t | ck[] | ||
It is necessary to define the value of the fluid's absorption coefficient Ck.
This value is defined automatically for specific physical models, such as gas and coal combustion, so this function is not used by these models.
For a transparent medium, the coefficient should be set to 0.
In the case of the P-1 model, we check that the optical length is at least of the order of 1.
| [in] | bc_type | boundary face types |
| [out] | ck | medium's absorption coefficient (zero if transparent) |
| void cs_user_rad_transfer_net_flux | ( | const int | bc_type[], |
| const cs_real_t | coefap[], | ||
| const cs_real_t | coefbp[], | ||
| const cs_real_t | cofafp[], | ||
| const cs_real_t | cofbfp[], | ||
| const cs_real_t | twall[], | ||
| const cs_real_t | qincid[], | ||
| const cs_real_t | xlam[], | ||
| const cs_real_t | epa[], | ||
| const cs_real_t | eps[], | ||
| const cs_real_t | ck[], | ||
| cs_real_t | net_flux[] | ||
The density of net radiation flux must be calculated consistently with the boundary conditions of the intensity. The density of net flux is the balance between the radiative emiting part of a boundary face (and not the reflecting one) and the radiative absorbing part.
| [in] | coefap | boundary condition work array for the radiance (explicit part) |
| [in] | coefbp | boundary condition work array for the radiance (implicit part) |
| [in] | cofafp | boundary condition work array for the diffusion of the radiance (explicit part) |
| [in] | cofbfp | boundary condition work array for the diffusion of the radiance (implicit part) |
| [in] | twall | inside current wall temperature (K) |
| [in] | qincid | radiative incident flux (W/m2) |
| [in] | xlam | conductivity (W/m/K) |
| [in] | epa | thickness (m) |
| [in] | eps | emissivity (>0) |
| [in] | ck | absorption coefficient |
| [out] | net_flux | net flux (W/m2) |
| void cs_user_radiative_transfer_parameters | ( | void | ) |
