#include "cs_headers.h"
void | cs_user_radiative_transfer_bcs (cs_domain_t *domain, const int bc_type[], int isothp[], cs_real_t *tmin, cs_real_t *tmax, cs_real_t *tx, const cs_real_t dt[], const cs_real_t thwall[], const cs_real_t qincid[], cs_real_t hfcnvp[], cs_real_t flcnvp[], cs_real_t xlamp[], cs_real_t epap[], cs_real_t epsp[], cs_real_t textp[]) |
User definition of radiative transfer boundary conditions. More... | |
void cs_user_radiative_transfer_bcs | ( | cs_domain_t * | domain, |
const int | bc_type[], | ||
int | isothp[], | ||
cs_real_t * | tmin, | ||
cs_real_t * | tmax, | ||
cs_real_t * | tx, | ||
const cs_real_t | dt[], | ||
const cs_real_t | thwall[], | ||
const cs_real_t | qincid[], | ||
cs_real_t | hfcnvp[], | ||
cs_real_t | flcnvp[], | ||
cs_real_t | xlamp[], | ||
cs_real_t | epap[], | ||
cs_real_t | epsp[], | ||
cs_real_t | textp[] | ||
See Examples of data settings for radiative transfers for examples.
For each boundary face face_id, a specific output (logging and postprocessing) class id may be assigned. This allows realizing balance sheets by treating them separately for each zone. By default, the output class id is set to the general (input) zone id associated to a face.
To access output class ids (both for reading and modifying), use the cs_boundary_zone_face_class_id function. The zone id values are arbitrarily chosen by the user, but must be positive integers; very high numbers may also lead to higher memory consumption.
The following face characteristics must be set:
Depending on the value of isothp, other values may also need to be set:
[in,out] | domain | pointer to a cs_domain_t structure |
[in] | bc_type | boundary face types |
[in] | isothp | boundary face type for radiative transfer |
[out] | tmin | min allowed value of the wall temperature |
[out] | tmax | max allowed value of the wall temperature |
[in] | tx | relaxation coefficient (0 < tx < 1) |
[in] | dt | time step (per cell) |
[in] | thwall | inside current wall temperature (K) |
[in] | qincid | radiative incident flux (W/m2) |
[in] | hfcnvp | convective exchange coefficient (W/m2/K) |
[in] | flcnvp | convective flux (W/m2) |
[out] | xlamp | conductivity (W/m/K) |
[out] | epap | thickness (m) |
[out] | epsp | emissivity (>0) |
[out] | textp | outside temperature (K) |
