#include "cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <string.h>#include <assert.h>#include <float.h>#include <bft_mem.h>#include "cs_basis_func.h"#include "cs_evaluate.h"#include "cs_hho_builder.h"#include "cs_hodge.h"#include "cs_log.h"#include "cs_math.h"#include "cs_scheme_geometry.h"#include "cs_volume_zone.h"#include "cs_source_term.h"
Include dependency graph for cs_source_term.c:Macros | |
| #define | CS_SOURCE_TERM_DBG 0 |
| void | cs_source_term_init_sharing (const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect) |
| void | cs_source_term_set_default_flag (cs_param_space_scheme_t scheme, cs_flag_t *state_flag, cs_flag_t *meta_flag) |
| Set the default flag related to a source term according to the numerical scheme chosen for discretizing an equation. More... | |
| void | cs_source_term_set_reduction (cs_xdef_t *st, cs_flag_t flag) |
| Set advanced parameters which are defined by default in a source term structure. More... | |
| cs_flag_t | cs_source_term_get_flag (const cs_xdef_t *st) |
| Get metadata related to the given source term structure. More... | |
| cs_eflag_t | cs_source_term_init (cs_param_space_scheme_t space_scheme, const int n_source_terms, cs_xdef_t *const *source_terms, cs_source_term_cellwise_t *compute_source[], cs_flag_t *sys_flag, cs_mask_t *source_mask[]) |
| Initialize data to build the source terms. More... | |
| void | cs_source_term_compute_cellwise (const int n_source_terms, cs_xdef_t *const *source_terms, const cs_cell_mesh_t *cm, const cs_mask_t *source_mask, cs_source_term_cellwise_t *compute_source[], cs_real_t time_eval, void *input, cs_cell_builder_t *cb, cs_real_t *result) |
| Compute the local contributions of source terms in a cell. More... | |
| void | cs_source_term_pvsp_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar potential defined at primal vertices by a constant value. A discrete Hodge operator has to be computed before this call and given as input parameter. More... | |
| void | cs_source_term_pvsp_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar potential defined at primal vertices by an analytical function. A discrete Hodge operator has to be computed before this call and given as input parameter. More... | |
| void | cs_source_term_pvsp_by_array (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar potential defined at primal vertices by an array. A discrete Hodge operator has to be computed before this call and given as an input parameter. More... | |
| void | cs_source_term_pvsp_by_c2v_array (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| void | cs_source_term_dcsd_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by a value. More... | |
| void | cs_source_term_dcvd_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a vector-valued density defined at dual cells by a value. More... | |
| void | cs_source_term_dcsd_by_pv_array (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an array defined at (primal) vertices or dual cells. More... | |
| void | cs_source_term_dcvd_by_pv_array (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a vector-valued density defined at dual cells by an array defined at (primal) vertices or dual cells. More... | |
| void | cs_source_term_dcsd_by_c2v_array (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution of a source term in a cell and add it to the given array of values. Case of a scalar density defined at dual cells by an array relying on the c2v connectivity to access the values. More... | |
| void | cs_source_term_dcsd_by_pc_array (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an array defined at (primal) cells. More... | |
| void | cs_source_term_dcsd_by_dof_func (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by a DoF function. More... | |
| void | cs_source_term_dcsd_none_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an analytic function without any quadrature rule. More... | |
| void | cs_source_term_dcsd_bary_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an analytical function. Use the barycentric approximation as quadrature to evaluate the integral. Exact for linear function. More... | |
| void | cs_source_term_dcsd_q1o1_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an analytical function. Use a the barycentric approximation as quadrature to evaluate the integral. Exact for linear function. More... | |
| void | cs_source_term_dcsd_q10o2_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an analytical function. Use a ten-point quadrature rule to evaluate the integral. Exact for quadratic function. More... | |
| void | cs_source_term_dcsd_q5o3_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by an analytical function. Use a five-point quadrature rule to evaluate the integral. Exact for cubic function. This function may be expensive since many evaluations are needed. Please use it with care. More... | |
| void | cs_source_term_vcsp_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar potential defined at primal vertices and cells by a constant value. A discrete Hodge operator has to be computed before this call and given as input parameter. More... | |
| void | cs_source_term_vcsp_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar potential defined at primal vertices and cells by an analytical function. A discrete Hodge operator has to be computed before this call and given as input parameter. More... | |
| void | cs_source_term_fcb_pcsd_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density (sd) defined on primal cells by a value. Case of face-based/cell-based schemes. More... | |
| void | cs_source_term_fcb_pcsd_by_dof_func (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a density defined on primal cells by a DoF function. Case of scalar-valued face-based schemes. Case of face-based and cell-based schemes. More... | |
| void | cs_source_term_fb_pcvd_by_dof_func (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a density defined on primal cells by a DoF function. Case of vector-valued face-based schemes. More... | |
| void | cs_source_term_fb_pcvd_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it the given array of values. Case of a vector-valued density (vd) defined on primal cells by a value. Case of face-based schemes. More... | |
| void | cs_source_term_fcb_pcsd_bary_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at primal cells by an analytical function. Use the barycentric approximation as quadrature to evaluate the integral. Exact for linear function. Case of face-based and cell-based schemes. More... | |
| void | cs_source_term_fcb_pcsd_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution of a source term for a cell and add it to the given array of values. Case of a scalar density (sd) defined on primal cells by an analytic function. Case of face-based and cell-based schemes. More... | |
| void | cs_source_term_fcb_pcsd_by_array (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at primal cells by an array. Case of face-based and cell-based schemes. More... | |
| void | cs_source_term_fb_pcvd_bary_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a vector-valued density defined at primal cells by an analytical function. Use the barycentric approximation as quadrature to evaluate the integral. Exact for linear function. Case of face-based schemes. More... | |
| void | cs_source_term_fb_pcvd_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution of a source term for a cell and add it to the given array of values. Case of a vector density (vd) defined on primal cells by an analytic function. Case of face-based schemes. More... | |
| void | cs_source_term_fb_pcvd_by_array (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution of a source term for a cell and add it to the given array of values. Case of a vector density (vd) defined on primal cells by an array Case of CDO face-based schemes. More... | |
| void | cs_source_term_hhosd_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution of a source term for a cell and add it to the given array of values. Case of a scalar density (sd) defined on primal cells by a value. Case of HHO schemes. More... | |
| void | cs_source_term_hhosd_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution of a source term for a cell and add it to the given array of values. Case of a scalar density (sd) defined on primal cells by an analytic function. Case of HHO schemes. More... | |
| void | cs_source_term_hhovd_by_analytic (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution of a source term for a cell and add it to the given array of values. Case of a vector field (vd) defined on primal cells by an analytic function. Case of HHO schemes. More... | |
| void | cs_source_term_dfsf_by_value (const cs_xdef_t *source, const cs_cell_mesh_t *cm, cs_real_t time_eval, cs_cell_builder_t *cb, void *input, double *values) |
| Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar flux defined at dual faces by a constant value. More... | |
| static const char | _err_empty_st [] |
| static const cs_cdo_quantities_t * | cs_cdo_quant |
| static const cs_cdo_connect_t * | cs_cdo_connect |
| #define CS_SOURCE_TERM_DBG 0 |
| void cs_source_term_compute_cellwise | ( | const int | n_source_terms, |
| cs_xdef_t *const * | source_terms, | ||
| const cs_mask_t * | source_mask, | ||
| cs_source_term_cellwise_t * | compute_source[], | ||
| cs_real_t | time_eval, | ||
| void * | input, | ||
| cs_real_t * | result | ||
| [in] | n_source_terms | number of source terms |
| [in] | source_terms | pointer to the definitions of source terms |
| [in] | source_mask | array storing in a compact way which source term is defined in a given cell |
| [in] | compute_source | array of function pointers |
| [in,out] | input | pointer to an element cast on-the-fly |
| [in,out] | result | array storing the result of the evaluation |
| void cs_source_term_dcsd_bary_by_analytic | ( | const cs_xdef_t * | source, |
| double * | values | ||
| [in] | source | pointer to a cs_xdef_t structure |
| [in,out] | input | pointer to an element cast on-the-fly (or NULL) |
| [in,out] | values | pointer to the computed values |
| void cs_source_term_dcsd_by_c2v_array | ( | const cs_xdef_t * | source, |
| void cs_source_term_dcsd_by_dof_func | ( | const cs_xdef_t * | source, |
| void cs_source_term_dcsd_by_pc_array | ( | const cs_xdef_t * | source, |
| void cs_source_term_dcsd_by_pv_array | ( | const cs_xdef_t * | source, |
| void cs_source_term_dcsd_by_value | ( | const cs_xdef_t * | source, |
Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a scalar density defined at dual cells by value.
| void cs_source_term_dcsd_none_by_analytic | ( | const cs_xdef_t * | source, |
| void cs_source_term_dcsd_q10o2_by_analytic | ( | const cs_xdef_t * | source, |
| void cs_source_term_dcsd_q1o1_by_analytic | ( | const cs_xdef_t * | source, |
| void cs_source_term_dcsd_q5o3_by_analytic | ( | const cs_xdef_t * | source, |
| void cs_source_term_dcvd_by_pv_array | ( | const cs_xdef_t * | source, |
| void cs_source_term_dcvd_by_value | ( | const cs_xdef_t * | source, |
| void cs_source_term_dfsf_by_value | ( | const cs_xdef_t * | source, |
| void cs_source_term_fb_pcvd_bary_by_analytic | ( | const cs_xdef_t * | source, |
| void cs_source_term_fb_pcvd_by_analytic | ( | const cs_xdef_t * | source, |
Compute the contribution of a source term for a cell and add it to the given array of values. Case of a vector average (va) defined on primal cells by an analytic function. Case of CDO face-based schemes.
| [in,out] | values | pointer to the computed value |
| void cs_source_term_fb_pcvd_by_array | ( | const cs_xdef_t * | source, |
| void cs_source_term_fb_pcvd_by_dof_func | ( | const cs_xdef_t * | source, |
| void cs_source_term_fb_pcvd_by_value | ( | const cs_xdef_t * | source, |
| void cs_source_term_fcb_pcsd_bary_by_analytic | ( | const cs_xdef_t * | source, |
| void cs_source_term_fcb_pcsd_by_analytic | ( | const cs_xdef_t * | source, |
| void cs_source_term_fcb_pcsd_by_array | ( | const cs_xdef_t * | source, |
| void cs_source_term_fcb_pcsd_by_dof_func | ( | const cs_xdef_t * | source, |
Compute the contribution for a cell related to a source term and add it to the given array of values. Case of a density defined on primal cells by a DoF function. Case of face-based and cell-based schemes.
| void cs_source_term_fcb_pcsd_by_value | ( | const cs_xdef_t * | source, |
| [in,out] | st | pointer to a cs_xdef_t structure |
| void cs_source_term_hhosd_by_analytic | ( | const cs_xdef_t * | source, |
| void cs_source_term_hhosd_by_value | ( | const cs_xdef_t * | source, |
| void cs_source_term_hhovd_by_analytic | ( | const cs_xdef_t * | source, |
| cs_eflag_t cs_source_term_init | ( | cs_param_space_scheme_t | space_scheme, |
| const int | n_source_terms, | ||
| cs_flag_t * | sys_flag, | ||
| cs_mask_t * | source_mask[] | ||
| [in] | space_scheme | scheme used to discretize in space |
| [in,out] | compute_source | array of function pointers |
| [in,out] | sys_flag | metadata about the algebraic system |
| [in,out] | source_mask | pointer to an array storing in a compact way which source term is defined in a given cell |
| void cs_source_term_init_sharing | ( | const cs_cdo_quantities_t * | quant, |
| void cs_source_term_pvsp_by_analytic | ( | const cs_xdef_t * | source, |
| void cs_source_term_pvsp_by_array | ( | const cs_xdef_t * | source, |
| void cs_source_term_pvsp_by_c2v_array | ( | const cs_xdef_t * | source, |
| void cs_source_term_pvsp_by_value | ( | const cs_xdef_t * | source, |
| void cs_source_term_set_default_flag | ( | cs_param_space_scheme_t | scheme, |
| cs_flag_t * | state_flag, | ||
| cs_flag_t * | meta_flag | ||
| [in] | scheme | numerical scheme used for the discretization |
| [out] | state_flag | flag describing the status of the source term |
| [out] | meta_flag | additional flags associated to a source term |
| [in] | flag | CS_FLAG_DUAL or CS_FLAG_PRIMAL |
| void cs_source_term_vcsp_by_analytic | ( | const cs_xdef_t * | source, |
| void cs_source_term_vcsp_by_value | ( | const cs_xdef_t * | source, |
static |
static |
static |
