8.1
cs_basis_func.h
1 #ifndef __CS_BASIS_FUNC_H__
2 #define __CS_BASIS_FUNC_H__
5  * Build a set of basis functions for cells and faces and cell gradients
31  * Local headers
34 #include "cs_cdo_local.h"
35 #include "cs_quadrature.h"
36
38
42  * Macro definitions
45 /* Default basis function are rescale and modified according to the
46  geometrical inertia tensor of the related entity unless a flag "monomial"
47  is set */
48
49 #define CS_BASIS_FUNC_MONOMIAL (1 << 0) /* 1: Use mononial basis functions */
50 #define CS_BASIS_FUNC_GRADIENT (1 << 1) /* 2: Basis functions for gradient */
51
53  * Type definitions
55
56 /*----------------------------------------------------------------------------*/
65 /*----------------------------------------------------------------------------*/
66
67 typedef void
68 (cs_basis_func_eval_all_at_point_t) (const void *bf,
69  const cs_real_t coords[3],
70  cs_real_t *eval);
71
83 /*----------------------------------------------------------------------------*/
84
85 typedef void
86 (cs_basis_func_eval_at_point_t) (const void *bf,
87  const cs_real_t coords[3],
88  short int start,
89  short int end,
90  cs_real_t *eval);
91
92 /*----------------------------------------------------------------------------*/
103
104 typedef void
105 (cs_basis_func_setup_t) (void *pbf,
106  const cs_cell_mesh_t *cm,
107  const short int id,
108  const cs_real_t center[3],
109  cs_cell_builder_t *cb);
110
111 /*----------------------------------------------------------------------------*/
120 /*----------------------------------------------------------------------------*/
121
122 typedef void
123 (cs_basis_func_compute_proj_t) (void *pbf,
124  const cs_cell_mesh_t *cm,
125  const short int id);
126
135
136 typedef void
137 (cs_basis_func_compute_facto_t) (void *pbf);
138
139 /*----------------------------------------------------------------------------*/
151 /*----------------------------------------------------------------------------*/
152
153 typedef void
154 (cs_basis_func_project_t) (const void *pbf,
155  const cs_real_t *array,
156  cs_real_t *dof);
157
158 /*----------------------------------------------------------------------------*/
166
167 typedef void
168 (cs_basis_func_dump_proj_t) (const void *pbf);
169
170
171 /* Structure storing information to build and use a set of basis functions
172  *
173  * - When dealing with volumetric basis fucntions (eg cell- or grad-basis),
174  * the functions are ordered as follows:
175  * 1, x, y, z, xx, xy, xz, yy, yz, zz
176  * - When dealing with face-basis fucntions the functions are ordered as
177  * follows:
178  * 1, x, y, xx, xy, yy
179  */
180
181 typedef struct {
182
183  cs_flag_t flag; // metadata
184  short int poly_order; // max. polynomial order of the basis
185  short int dim; // 2D or 3D associated geometrical entities
186  int size; // number of elementary basis functions
187
188  cs_real_t phi0; // constant basis function
189  cs_nvec3_t *axis; // over_diam * main axis of the entity
190  cs_real_3_t center; // center used for rescaling
191
192  /* For poly_order > 1 we store the degree related to each monone for
193  each basis function */
195  short int *deg; /* size = n_deg_elts * dim */
196
197  /* Function used for setting up the quantities used for defining
198  the set of basis functions */
200
201  /* Function used for evaluating basis functions on a set of points */
204
205  /* Projector is a mass matrix related to the basis function */
206  cs_sdm_t *projector;
209
210  /* Modified Cholesky factorization. To perform the inversion agains a set
211  of right-hand sides */
216
217  /* Quadrature function to use for computing integral over o volume (tet) or
218  on a surface (tria) */
223
225
226 /*============================================================================
227  * Static inline public function prototypes
228  *============================================================================*/
229
230 /*----------------------------------------------------------------------------*/
238 /*----------------------------------------------------------------------------*/
239
240 static inline short int
242 {
243  if (bf == NULL)
244  return -1;
245  else
246  return bf->poly_order;
247 }
248
249 /*============================================================================
250  * Public function prototypes
251  *============================================================================*/
252
253 /*----------------------------------------------------------------------------*/
263 /*----------------------------------------------------------------------------*/
264
267  short int k,
268  short int dim);
269
270 /*----------------------------------------------------------------------------*/
282 /*----------------------------------------------------------------------------*/
283
286
287 /*----------------------------------------------------------------------------*/
295 /*----------------------------------------------------------------------------*/
296
297 void
299  cs_basis_func_t *rcv);
300
301 /*----------------------------------------------------------------------------*/
309 /*----------------------------------------------------------------------------*/
310
313
314 /*----------------------------------------------------------------------------*/
321 /*----------------------------------------------------------------------------*/
322
323 void
325  cs_flag_t cell_flag);
326
327 /*----------------------------------------------------------------------------*/
334 /*----------------------------------------------------------------------------*/
335
336 void
338  cs_flag_t *cell_flag);
339
340 /*----------------------------------------------------------------------------*/
346 /*----------------------------------------------------------------------------*/
347
348 void
350
351 /*----------------------------------------------------------------------------*/
361 /*----------------------------------------------------------------------------*/
362
363 void
364 cs_basis_func_fprintf(FILE *fp,
365  const char *fname,
366  const cs_basis_func_t *pbf);
367
368 /*----------------------------------------------------------------------------*/
369
371
372 #endif /* __CS_BASIS_FUNC_H__ */
void cs_basis_func_set_hho_flag(cs_flag_t face_flag, cs_flag_t cell_flag)
Set options for basis functions when using HHO schemes.
Definition: cs_basis_func.c:2696
void cs_basis_func_dump(const cs_basis_func_t *pbf)
Dump a cs_basis_func_t structure.
Definition: cs_basis_func.c:2729
static short int cs_basis_func_get_poly_order(const cs_basis_func_t *bf)
Get the polynomial order of the given basis.
Definition: cs_basis_func.h:241
void() cs_basis_func_project_t(const void *pbf, const cs_real_t *array, cs_real_t *dof)
Generic prototype for projecting an array on the polynomial basis function. This results from the app...
Definition: cs_basis_func.h:154
void() cs_basis_func_dump_proj_t(const void *pbf)
Generic prototype for printing the projector matrix related to the given basis function.
Definition: cs_basis_func.h:168
void cs_basis_func_copy_setup(const cs_basis_func_t *ref, cs_basis_func_t *rcv)
Copy the center and the different axis from the reference basis Up to now, only cell basis functions ...
Definition: cs_basis_func.c:2642
void cs_basis_func_get_hho_flag(cs_flag_t *face_flag, cs_flag_t *cell_flag)
Get options for basis functions when using HHO schemes.
Definition: cs_basis_func.c:2713
cs_basis_func_t * cs_basis_func_free(cs_basis_func_t *pbf)
Free a cs_basis_func_t structure.
Definition: cs_basis_func.c:2668
void() cs_basis_func_compute_proj_t(void *pbf, const cs_cell_mesh_t *cm, const short int id)
Generic prototype for computing the projector to the space spanned by the basis functions.
Definition: cs_basis_func.h:123
void() cs_basis_func_eval_all_at_point_t(const void *bf, const cs_real_t coords[3], cs_real_t *eval)
Generic prototype for evaluating all basis functions at a given point.
Definition: cs_basis_func.h:68
void() cs_basis_func_compute_facto_t(void *pbf)
Generic prototype for computing the Modified Choloesky factorization of the projection matrix (mass m...
Definition: cs_basis_func.h:137
cs_basis_func_t * cs_basis_func_create(cs_flag_t flag, short int k, short int dim)
Allocate a cs_basis_func_t structure.
Definition: cs_basis_func.c:2360
void cs_basis_func_fprintf(FILE *fp, const char *fname, const cs_basis_func_t *pbf)
Print a cs_basis_func_t structure Print into the file f if given otherwise open a new file named fnam...
Definition: cs_basis_func.c:2771
void() cs_basis_func_eval_at_point_t(const void *bf, const cs_real_t coords[3], short int start, short int end, cs_real_t *eval)
Generic prototype for evaluating a set of basis functions at a given point.
Definition: cs_basis_func.h:86
void() cs_basis_func_setup_t(void *pbf, const cs_cell_mesh_t *cm, const short int id, const cs_real_t center[3], cs_cell_builder_t *cb)
Generic prototype for setting up a set of basis functions.
Definition: cs_basis_func.h:105
cs_basis_func_t * cs_basis_func_grad_create(const cs_basis_func_t *ref)
Allocate a cs_basis_func_t structure which is associated to an existing set of basis functions....
Definition: cs_basis_func.c:2557
Definition: cs_defs.h:514
Definition: cs_defs.h:319
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:334
Definition: cs_defs.h:515
unsigned short int cs_flag_t
Definition: cs_defs.h:321
@ k
void() cs_quadrature_tria_t(const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, double area, cs_real_3_t gpts[], double *weights)
Generic functoin pointer to compute the quadrature points for a triangle.
Definition: cs_quadrature.h:98
void() cs_quadrature_tet_t(const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, const cs_real_3_t v4, double vol, cs_real_3_t gpts[], double weights[])
Generic function to compute the quadrature points in a tetrehedra.
Definition: cs_quadrature.h:120
Definition: cs_basis_func.h:181
cs_nvec3_t * axis
Definition: cs_basis_func.h:189
cs_basis_func_compute_facto_t * compute_factorization
Definition: cs_basis_func.h:212
cs_basis_func_dump_proj_t * dump_projector
Definition: cs_basis_func.h:208
int size
Definition: cs_basis_func.h:186
short int * deg
Definition: cs_basis_func.h:195
int n_deg_elts
Definition: cs_basis_func.h:194
cs_basis_func_setup_t * setup
Definition: cs_basis_func.h:199
cs_basis_func_eval_all_at_point_t * eval_all_at_point
Definition: cs_basis_func.h:202
cs_basis_func_compute_proj_t * compute_projector
Definition: cs_basis_func.h:207
cs_basis_func_project_t * project
Definition: cs_basis_func.h:213
cs_real_t * facto
Definition: cs_basis_func.h:214
int n_gpts_tria
Definition: cs_basis_func.h:219
cs_flag_t flag
Definition: cs_basis_func.h:183
Definition: cs_basis_func.h:184
cs_real_t phi0
Definition: cs_basis_func.h:188
short int dim
Definition: cs_basis_func.h:185
cs_basis_func_eval_at_point_t * eval_at_point
Definition: cs_basis_func.h:203
int n_gpts_tetra
Definition: cs_basis_func.h:221
cs_sdm_t * projector
Definition: cs_basis_func.h:206
cs_real_3_t center
Definition: cs_basis_func.h:190
cs_quadrature_tria_t * quadrature_tria
Definition: cs_basis_func.h:220
int facto_max_size
Definition: cs_basis_func.h:215
cs_quadrature_tet_t * quadrature_tetra
Definition: cs_basis_func.h:222
Definition: cs_cdo_local.h:60
Definition: cs_defs.h:372
