8.1
cs_domain.c File Reference
Manage a computational domain. More...
#include <ctype.h>
#include <errno.h>
#include <float.h>
#include <locale.h>
#include <bft_mem.h>
#include "cs_boundary_zone.h"
#include "cs_coupling.h"
#include "cs_math.h"
#include "cs_mesh_location.h"
#include "cs_property.h"
#include "cs_prototypes.h"
#include "cs_quadrature.h"
#include "cs_restart.h"
#include "cs_time_step.h"
#include "cs_domain.h"
+ Include dependency graph for cs_domain.c:
cs_domain_tcs_domain_create (void)
 Create and initialize by default a cs_domain_t structure. More...
void cs_domain_free (cs_domain_t **p_domain)
 Free a cs_domain_t structure. More...
void cs_domain_set_cdo_mode (cs_domain_t *domain, int mode)
 Set the global variable storing the mode of activation to apply to CDO/HHO schemes. Deprecated way to set the CDO mode. More...
int cs_domain_get_cdo_mode (const cs_domain_t *domain)
 Get the mode of activation for the CDO/HHO schemes. Deprecated way to retrieve the CDO mode. More...
void cs_domain_set_stage (cs_domain_t *domain, cs_domain_stage_t stage)
 Set the computation stage in the domain structure. More...
cs_domain_stage_t cs_domain_get_stage (const cs_domain_t *domain)
 Retrieve the computation stage from the domain structure. More...
bool cs_domain_needs_iteration (cs_domain_t *domain)
 Check if one needs to continue iterations in time. More...
bool cs_domain_needs_log (const cs_domain_t *domain, bool oneplus)
 Check if an output is requested according to the domain setting. More...
void cs_domain_increment_time (cs_domain_t *domain)
 Update the simulated time after one temporal iteration. More...
cs_domain_tcs_glob_domain = NULL
static double cs_domain_kahan_time_compensation = 0.0
  • Settings, fields, connectivities and geometrical quantities
  • Properties and advection fields attached to this domain
  • Equations to solve on this domain
◆ cs_domain_create()
cs_domain_t* cs_domain_create ( void  )
a pointer to a cs_domain_t structure
◆ cs_domain_free()
void cs_domain_free ( cs_domain_t **  p_domain)
[in,out]p_domainpointer of pointer to a cs_domain_t structure
◆ cs_domain_get_cdo_mode()
int cs_domain_get_cdo_mode ( const cs_domain_t domain)
[in]domainpointer to a cs_domain_t structure
the mode of activation for the CDO/HHO module
◆ cs_domain_get_stage()
cs_domain_stage_t cs_domain_get_stage ( const cs_domain_t domain)
the current stage in the computation run
◆ cs_domain_increment_time()
void cs_domain_increment_time ( cs_domain_t domain)
Update time step after one temporal iteration.
◆ cs_domain_needs_iteration()
bool cs_domain_needs_iteration ( cs_domain_t domain)
true or false
◆ cs_domain_needs_log()
bool cs_domain_needs_log ( const cs_domain_t domain,
bool  oneplus
[in]oneplusadd or not plus one to the current time step
true or false
◆ cs_domain_set_cdo_mode()
void cs_domain_set_cdo_mode ( cs_domain_t domain,
int  mode
[in]modetype of activation for the CDO/HHO module
◆ cs_domain_set_stage()
void cs_domain_set_stage ( cs_domain_t domain,
[in]stagestage in the computation run
◆ cs_domain_kahan_time_compensation
static
◆ cs_glob_domain
cs_domain_t* cs_glob_domain = NULL
