8.1
cs_property.h
1 #ifndef __CS_PROPERTY_H__
2 #define __CS_PROPERTY_H__
5  * Manage the definition/setting of properties
31  * Local headers
34 #include "cs_field.h"
35 #include "cs_flag.h"
36 #include "cs_param_types.h"
37 #include "cs_xdef.h"
38 #include "cs_xdef_cw_eval.h"
39 #include "cs_xdef_eval.h"
46  * Macro definitions
48
49 /* Common property names (property which is shared between different module) */
50
51 #define CS_PROPERTY_MASS_DENSITY "mass_density"
52
61 #define CS_PROPERTY_POST_FOURIER (1 << 0)
62
75 #define CS_PROPERTY_ISO (1 << 0)
76
81 #define CS_PROPERTY_ORTHO (1 << 1)
82
88 #define CS_PROPERTY_ANISO (1 << 2)
89
94 #define CS_PROPERTY_ANISO_SYM (1 << 3)
95
100 #define CS_PROPERTY_BY_PRODUCT (1 << 4)
101
106 #define CS_PROPERTY_SCALED (1 << 5)
107
115 #define CS_PROPERTY_SUBCELL_DEFINITION (1 << 6)
116
119 /*============================================================================
120  * Type definitions
121  *============================================================================*/
122
124
132 typedef enum {
133
136
138
139 /* ======================================== */
140 /* Set of parameters attached to a property */
141 /* ======================================== */
142
149 typedef struct _cs_property_t cs_property_t;
150
152
153  char *restrict name;
154  int id;
158
159  /* Reference value wich is used as default when nothing else is set. This
160  * value can also be used to renormalized quantities related to this property
161  * By default, this is set to 1
162  */
163
165
166  /* Value of the scaling factor to apply when a property is defined up to a
167  * scaling factor. By default the value is 1.0 and the property is not
168  * scaled.
169  */
170
172
173  /* Property is up to now only defined on the whole domain (volume) */
174
175  int n_definitions; /* Current number of definitions used */
176  cs_xdef_t **defs; /* List of definitions */
177
178  /* Store the definition id for each cell, NULL if there is only one
179  definition set */
180
181  short int *def_ids;
182
183  /* Function pointers to handle generic tasks related to a property. There
184  is one function related to each definition. Some functions may not be
185  allocated according to the kind of property */
186
187  /* Retrieve the evaluation of the property at the cell center for each
188  definition */
189
191
192  /* Same thing as the previous one but now with the usage of cellwise algo.
193  relying on a cs_cell_mesh_t structure */
194
196
197  /* For properties relying on other properties for their definition, one
198  * stores the pointers to these related properties */
199
202
203  /* Optional: Definition(s) of the property at the boundary. If nothing is
204  set, then one uses the definition on the volume to get information on the
205  boundary. This is the default behavior. */
206
209
210  /* Store the definition id for each boundary face, NULL if there is only one
211  boundary definition set */
212
213  short int *b_def_ids;
214
215 };
216
223 typedef struct {
224
225  const cs_property_t *property; /* shared pointer */
226
227  bool is_iso; /* Detect if this an easier case */
228  bool is_unity; /* Detect if this the simplest case */
229
230  /* Way to evaluate the property and buffer to store the evaluation done
231  on-the-fly */
232
234  cs_real_t tensor[3][3];
236
237  /* Additional metadata */
238
242
244
245 /*============================================================================
246  * Global variables
247  *============================================================================*/
248
249 /*============================================================================
250  * Static inline public function prototypes
251  *============================================================================*/
252
253 /*----------------------------------------------------------------------------*/
261 /*----------------------------------------------------------------------------*/
262
263 static inline bool
265 {
266  if (pty == NULL)
267  return true; /* Treated as the "unity" property */
268
269  if (pty->state_flag & CS_FLAG_STATE_STEADY) {
270  if (pty->state_flag & CS_FLAG_STATE_UNIFORM)
271  return true;
272  else
273  return false;
274  }
275  else
276  return false;
277 }
278
279 /*----------------------------------------------------------------------------*/
287 /*----------------------------------------------------------------------------*/
288
289 static inline bool
291 {
292  if (pty == NULL)
293  return true; /* Treated as the "unity" property */
294
295  if (pty->state_flag & CS_FLAG_STATE_STEADY)
296  return true;
297  else
298  return false;
299 }
300
301 /*----------------------------------------------------------------------------*/
309 /*----------------------------------------------------------------------------*/
310
311 static inline bool
313 {
314  if (pty == NULL)
315  return true; /* Treated as the "unity" property */
316
317  if (pty->state_flag & CS_FLAG_STATE_UNIFORM)
318  return true;
319  else
320  return false;
321 }
322
323 /*----------------------------------------------------------------------------*/
331 /*----------------------------------------------------------------------------*/
332
333 static inline bool
335 {
336  if (pty == NULL)
337  return false;
338
339  if (pty->type & CS_PROPERTY_ISO)
340  return true;
341  else
342  return false;
343 }
344
345 /*----------------------------------------------------------------------------*/
354 /*----------------------------------------------------------------------------*/
355
356 static inline bool
358 {
359  if (pty == NULL)
360  return false;
361
362  if (pty->type & CS_PROPERTY_SUBCELL_DEFINITION)
363  return true;
364  else
365  return false;
366 }
367
368 /*----------------------------------------------------------------------------*/
376 /*----------------------------------------------------------------------------*/
377
378 static inline const char *
380 {
381  if (pty == NULL)
382  return NULL;
383
384  return pty->name;
385 }
386
387 /*----------------------------------------------------------------------------*/
395 /*----------------------------------------------------------------------------*/
396
397 static inline cs_property_type_t
399 {
400  if (pty == NULL)
401  return 0; /* means undefined */
402
403  return pty->type;
404 }
405
406 /*----------------------------------------------------------------------------*/
414 /*----------------------------------------------------------------------------*/
415
416 static inline int
418 {
419  if (pty == NULL)
420  return 0; /* means undefined */
421
422  if (pty->type & CS_PROPERTY_ISO)
423  return 1;
424  else if (pty->type & CS_PROPERTY_ORTHO)
425  return 3;
426  else if (pty->type & CS_PROPERTY_ANISO_SYM)
427  return 6;
428  else if (pty->type & CS_PROPERTY_ANISO)
429  return 9;
430  else
431  return 0; /* means undefined */
432 }
433
434 /*============================================================================
435  * Public function prototypes
436  *============================================================================*/
437
438 /*----------------------------------------------------------------------------*/
446 /*----------------------------------------------------------------------------*/
447
448 void
450  const cs_cdo_quantities_t *quant,
451  const cs_cdo_connect_t *connect);
452
453 /*----------------------------------------------------------------------------*/
459 /*----------------------------------------------------------------------------*/
460
461 int
463
464 /*----------------------------------------------------------------------------*/
473 /*----------------------------------------------------------------------------*/
474
476 cs_property_add(const char *name,
477  cs_property_type_t type);
478
479 /*----------------------------------------------------------------------------*/
491 /*----------------------------------------------------------------------------*/
492
494 cs_property_subcell_add(const char *name,
495  cs_property_type_t type);
496
497 /*----------------------------------------------------------------------------*/
510 /*----------------------------------------------------------------------------*/
511
513 cs_property_add_as_product(const char *name,
514  const cs_property_t *pty_a,
515  const cs_property_t *pty_b);
516
517 /*----------------------------------------------------------------------------*/
525 /*----------------------------------------------------------------------------*/
526
528 cs_property_by_name(const char *name);
529
530 /*----------------------------------------------------------------------------*/
538 /*----------------------------------------------------------------------------*/
539
541 cs_property_by_id(int id);
542
543 /*----------------------------------------------------------------------------*/
550 /*----------------------------------------------------------------------------*/
551
552 void
554  cs_property_key_t key);
555
556 /*----------------------------------------------------------------------------*/
564 /*----------------------------------------------------------------------------*/
565
566 void
568  double refval);
569
570 /*----------------------------------------------------------------------------*/
580 /*----------------------------------------------------------------------------*/
581
582 void
584  double val);
585
586 /*----------------------------------------------------------------------------*/
595 /*----------------------------------------------------------------------------*/
596
597 void
599
600 /*----------------------------------------------------------------------------*/
605 /*----------------------------------------------------------------------------*/
606
607 void
609
610 /*----------------------------------------------------------------------------*/
615 /*----------------------------------------------------------------------------*/
616
617 void
619
620 /*----------------------------------------------------------------------------*/
630 /*----------------------------------------------------------------------------*/
631
632 cs_real_t *
634
635 /*----------------------------------------------------------------------------*/
647 /*----------------------------------------------------------------------------*/
648
650 cs_property_data_define(bool need_tensor,
651  bool need_eigen,
652  const cs_property_t *property);
653
654 /*----------------------------------------------------------------------------*/
664 /*----------------------------------------------------------------------------*/
665
666 void
667 cs_property_data_init(bool need_tensor,
668  bool need_eigen,
669  const cs_property_t *property,
670  cs_property_data_t *data);
671
672 /*----------------------------------------------------------------------------*/
684 /*----------------------------------------------------------------------------*/
685
686 cs_xdef_t *
688  double val);
689
690 /*----------------------------------------------------------------------------*/
702 /*----------------------------------------------------------------------------*/
703
704 cs_xdef_t *
706  const char *zname,
707  double val);
708
709 /*----------------------------------------------------------------------------*/
722 /*----------------------------------------------------------------------------*/
723
724 cs_xdef_t *
726  const char *zname,
727  double val);
728
729 /*----------------------------------------------------------------------------*/
741 /*----------------------------------------------------------------------------*/
742
743 cs_xdef_t *
745  const char *zname,
746  double val[]);
747
748 /*----------------------------------------------------------------------------*/
761 /*----------------------------------------------------------------------------*/
762
763 cs_xdef_t *
765  const char *zname,
766  double vals[]);
767
768 /*----------------------------------------------------------------------------*/
780 /*----------------------------------------------------------------------------*/
781
782 cs_xdef_t *
784  const char *zname,
785  cs_real_t tens[3][3]);
786
787 /*----------------------------------------------------------------------------*/
800 /*----------------------------------------------------------------------------*/
801
802 cs_xdef_t *
804  const char *zname,
805  double tens[3][3]);
806
807 /*----------------------------------------------------------------------------*/
820 /*----------------------------------------------------------------------------*/
821
822 cs_xdef_t *
824  const char *zname,
825  cs_real_t symtens[6]);
826
827 /*----------------------------------------------------------------------------*/
841 /*----------------------------------------------------------------------------*/
842
843 cs_xdef_t *
845  const char *zname,
846  double tens[6]);
847
848 /*----------------------------------------------------------------------------*/
861 /*----------------------------------------------------------------------------*/
862
863 cs_xdef_t *
865  const char *zname,
866  cs_time_func_t *func,
867  void *input);
868
869 /*----------------------------------------------------------------------------*/
882 /*----------------------------------------------------------------------------*/
883
884 cs_xdef_t *
886  const char *zname,
887  cs_time_func_t *func,
888  void *input);
889
890 /*----------------------------------------------------------------------------*/
903 /*----------------------------------------------------------------------------*/
904
905 cs_xdef_t *
907  const char *zname,
908  cs_analytic_func_t *func,
909  void *input);
910
911 /*----------------------------------------------------------------------------*/
925 /*----------------------------------------------------------------------------*/
926
927 cs_xdef_t *
929  const char *zname,
930  cs_analytic_func_t *func,
931  void *input);
932
933 /*----------------------------------------------------------------------------*/
949 /*----------------------------------------------------------------------------*/
950
951 cs_xdef_t *
953  const char *zname,
954  void *context,
955  cs_xdef_eval_t *get_eval_at_cell,
956  cs_xdef_cw_eval_t *get_eval_at_cell_cw);
957
958 /*----------------------------------------------------------------------------*/
979 /*----------------------------------------------------------------------------*/
980
981 cs_xdef_t *
983  const char *zname,
984  cs_flag_t val_location,
985  cs_real_t *array,
986  bool is_owner,
987  bool full_length);
988
989 /*----------------------------------------------------------------------------*/
1010 /*----------------------------------------------------------------------------*/
1011
1012 cs_xdef_t *
1014  const char *zname,
1015  cs_flag_t val_loc,
1016  cs_real_t *array,
1017  bool is_owner,
1018  bool full_length);
1019
1020 /*----------------------------------------------------------------------------*/
1030 /*----------------------------------------------------------------------------*/
1031
1032 cs_xdef_t *
1034  cs_field_t *field);
1035
1036 /*----------------------------------------------------------------------------*/
1047 /*----------------------------------------------------------------------------*/
1048
1049 cs_xdef_t *
1051  cs_field_t *field);
1052
1053 /*----------------------------------------------------------------------------*/
1072 /*----------------------------------------------------------------------------*/
1073
1074 void
1076  int def_id,
1077  bool dense_output,
1078  double t_eval,
1079  cs_real_t *eval);
1080
1081 /*----------------------------------------------------------------------------*/
1098 /*----------------------------------------------------------------------------*/
1099
1100 void
1102  int def_id,
1103  bool dense_output,
1104  double t_eval,
1105  cs_real_t *array);
1106
1107 /*----------------------------------------------------------------------------*/
1119 /*----------------------------------------------------------------------------*/
1120
1121 void
1123  const cs_property_t *pty,
1124  int *pty_stride,
1125  cs_real_t **p_pty_vals);
1126
1127 /*----------------------------------------------------------------------------*/
1136 /*----------------------------------------------------------------------------*/
1137
1138 void
1140  const cs_property_t *pty,
1141  cs_real_t *array);
1142
1143 /*----------------------------------------------------------------------------*/
1152 /*----------------------------------------------------------------------------*/
1153
1154 void
1156  const cs_property_t *pty,
1157  cs_real_t *array);
1158
1159 /*----------------------------------------------------------------------------*/
1170 /*----------------------------------------------------------------------------*/
1171
1172 void
1174  cs_real_t t_eval,
1175  const cs_property_t *pty,
1176  bool do_inversion,
1177  cs_real_t tensor[3][3]);
1178
1179 /*----------------------------------------------------------------------------*/
1189 /*----------------------------------------------------------------------------*/
1190
1191 cs_real_t
1193  cs_real_t t_eval,
1194  const cs_property_t *pty);
1195
1196 /*----------------------------------------------------------------------------*/
1208 /*----------------------------------------------------------------------------*/
1209
1210 void
1212  const cs_property_t *pty,
1213  cs_real_t t_eval,
1214  bool do_inversion,
1215  cs_real_t tensor[3][3]);
1216
1217 /*----------------------------------------------------------------------------*/
1228 /*----------------------------------------------------------------------------*/
1229
1230 cs_real_t
1232  const cs_property_t *pty,
1233  cs_real_t t_eval);
1234
1235 /*----------------------------------------------------------------------------*/
1245 /*----------------------------------------------------------------------------*/
1246
1247 void
1249  const cs_property_t *pty,
1250  cs_real_t t_eval,
1251  cs_real_t *eval);
1252
1253 /*----------------------------------------------------------------------------*/
1262 /*----------------------------------------------------------------------------*/
1263
1264 void
1266  cs_real_t t_eval,
1267  double dt,
1268  cs_real_t fourier[]);
1269
1270 /*----------------------------------------------------------------------------*/
1275 /*----------------------------------------------------------------------------*/
1276
1277 void
1278 cs_property_log_setup(void);
1279
1280 /*----------------------------------------------------------------------------*/
1281
1283
1284 #endif /* __CS_PROPERTY_H__ */
#define restrict
Definition: cs_defs.h:139
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
Definition: cs_defs.h:313
unsigned short int cs_flag_t
Definition: cs_defs.h:321
@ dt
#define CS_FLAG_STATE_UNIFORM
Definition: cs_flag.h:103
#define CS_FLAG_STATE_STEADY
Definition: cs_flag.h:106
void() cs_time_func_t(double time, void *input, cs_real_t *retval)
Function which defines the evolution of a quantity according to the current time and any structure gi...
Definition: cs_param_types.h:172
cs_xdef_t * cs_property_def_by_analytic(cs_property_t *pty, const char *zname, cs_analytic_func_t *func, void *input)
Define the value of a cs_property_t structure thanks to an analytic function for all cells associated...
Definition: cs_property.c:2225
void cs_property_data_init(bool need_tensor, bool need_eigen, const cs_property_t *property, cs_property_data_t *data)
Initialize a cs_property_data_t structure. If property is NULL then one considers that this is a unit...
Definition: cs_property.c:1567
void cs_property_set_scaling_factor(cs_property_t *pty, double val)
Set the scaling factor associated to a cs_property_t structure This is a real number whatever the typ...
Definition: cs_property.c:1188
void cs_property_eval_at_boundary_faces(cs_real_t t_eval, const cs_property_t *pty, cs_real_t *array)
Evaluate the value of the property at each boundary face. Store the result of the evaluation in the g...
Definition: cs_property.c:3171
int cs_property_get_n_properties(void)
Retrieve the number of properties.
Definition: cs_property.c:939
static const char * cs_property_get_name(const cs_property_t *pty)
Retrieve the name of a property.
Definition: cs_property.h:379
cs_xdef_t * cs_property_boundary_def_by_array(cs_property_t *pty, const char *zname, cs_flag_t val_loc, cs_real_t *array, bool is_owner, bool full_length)
Define the values of a property at the boundary thanks to an array. If an advanced usage of the defin...
Definition: cs_property.c:2480
cs_property_key_t
List of available keys for setting options on a property.
Definition: cs_property.h:132
@ CS_PTYKEY_POST_FOURIER
Definition: cs_property.h:134
@ CS_PTYKEY_N_KEYS
Definition: cs_property.h:135
void cs_property_destroy_all(void)
Free all cs_property_t structures and the array storing all the structures.
Definition: cs_property.c:1228
cs_xdef_t * cs_property_boundary_def_aniso_by_value(cs_property_t *pty, const char *zname, double tens[3][3])
Define the value at the boundary for the given (anisotropic) property. This value is uniform and stea...
Definition: cs_property.c:1944
cs_xdef_t * cs_property_boundary_def_by_field(cs_property_t *pty, cs_field_t *field)
Define the values of a property at the boundary thanks to a field structure. One assumes that all bou...
Definition: cs_property.c:2617
cs_real_t cs_property_get_cell_value(cs_lnum_t c_id, cs_real_t t_eval, const cs_property_t *pty)
Compute the value of a property at the cell center.
Definition: cs_property.c:3524
cs_property_t * cs_property_add(const char *name, cs_property_type_t type)
Create and initialize a new property structure.
Definition: cs_property.c:956
cs_property_t * cs_property_by_name(const char *name)
Find the related property definition from its name.
Definition: cs_property.c:1088
void cs_property_c2v_values(const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval, cs_real_t *eval)
Compute the values of an isotropic property in each portion of dual cell in a (primal) cell....
Definition: cs_property.c:3706
void cs_property_finalize_setup(void)
Last stage of the definition of a property based on several definitions (i.e. definition by subdomain...
Definition: cs_property.c:1278
void cs_property_evaluate_boundary_def(const cs_property_t *pty, int def_id, bool dense_output, double t_eval, cs_real_t *array)
Evaluate the values of a property at boundary faces from the given boundary definition....
Definition: cs_property.c:2749
void cs_property_iso_get_cell_values(cs_real_t t_eval, const cs_property_t *pty, int *pty_stride, cs_real_t **p_pty_vals)
Evaluate the value of the property at each cell. Store the evaluation in the given array.
Definition: cs_property.c:2945
static bool cs_property_is_constant(const cs_property_t *pty)
Returns true if the property is steady and uniform, otherwise false.
Definition: cs_property.h:264
cs_xdef_t * cs_property_boundary_def_by_time_func(cs_property_t *pty, const char *zname, cs_time_func_t *func, void *input)
Define the value of a cs_property_t structure at the boundary thanks to a time function in a subdomai...
Definition: cs_property.c:2171
void cs_property_init_sharing(const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
Definition: cs_property.c:921
void cs_property_set_option(cs_property_t *pty, cs_property_key_t key)
Set optional parameters related to a cs_property_t structure.
Definition: cs_property.c:1135
cs_property_t * cs_property_add_as_product(const char *name, const cs_property_t *pty_a, const cs_property_t *pty_b)
Define a cs_property_t structure thanks to the product of two properties The type is infered from tha...
Definition: cs_property.c:1025
cs_xdef_t * cs_property_def_ortho_by_value(cs_property_t *pty, const char *zname, double val[])
Define an orthotropic cs_property_t structure by value for entities related to a volume zone.
Definition: cs_property.c:1788
cs_xdef_t * cs_property_boundary_def_iso_by_value(cs_property_t *pty, const char *zname, double val)
Define the value at the boundary for the given (isotropic) property. This value is uniform and steady...
Definition: cs_property.c:1745
static bool cs_property_is_uniform(const cs_property_t *pty)
Returns true if the property is uniform, otherwise false.
Definition: cs_property.h:312
cs_property_data_t cs_property_data_define(bool need_tensor, bool need_eigen, const cs_property_t *property)
Define a cs_property_data_t structure (not a pointer to this structure). If property is NULL then one...
Definition: cs_property.c:1508
void cs_property_unscale(cs_property_t *pty)
Definition: cs_property.c:1210
cs_real_t cs_property_value_in_cell(const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval)
Compute the value of a property at the cell center Version using a cs_cell_mesh_t structure.
Definition: cs_property.c:3649
void cs_property_set_reference_value(cs_property_t *pty, double refval)
Set the reference value associated to a cs_property_t structure This is a real number even whatever t...
Definition: cs_property.c:1166
cs_xdef_t * cs_property_def_by_array(cs_property_t *pty, const char *zname, cs_flag_t val_location, cs_real_t *array, bool is_owner, bool full_length)
Define a cs_property_t structure thanks to an array of values. If an advanced usage of the definition...
Definition: cs_property.c:2379
void cs_property_evaluate_def(const cs_property_t *pty, int def_id, bool dense_output, double t_eval, cs_real_t *eval)
Evaluate the values of the property at cells from the given definition. According to the parameter "d...
Definition: cs_property.c:2685
cs_xdef_t * cs_property_def_by_func(cs_property_t *pty, const char *zname, void *context, cs_xdef_eval_t *get_eval_at_cell, cs_xdef_cw_eval_t *get_eval_at_cell_cw)
Define the value of a cs_property_t structure thanks to low-level functions specifying how to evaluat...
Definition: cs_property.c:2325
static cs_property_type_t cs_property_get_type(const cs_property_t *pty)
Retrieve the type of a property.
Definition: cs_property.h:398
cs_xdef_t * cs_property_boundary_def_by_analytic(cs_property_t *pty, const char *zname, cs_analytic_func_t *func, void *input)
Define the value of a cs_property_t structure at the boundary thanks to a time function for all bound...
Definition: cs_property.c:2274
cs_xdef_t * cs_property_boundary_def_ortho_by_value(cs_property_t *pty, const char *zname, double vals[])
Define the value at the boundary for the given (orthotropic) property. This value is uniform and stea...
Definition: cs_property.c:1840
void cs_property_eval_at_cells(cs_real_t t_eval, const cs_property_t *pty, cs_real_t *array)
Definition: cs_property.c:3000
cs_xdef_t * cs_property_def_by_field(cs_property_t *pty, cs_field_t *field)
Define a cs_property_t structure thanks to a field structure. One assumes that all cells are defined ...
Definition: cs_property.c:2555
cs_xdef_t * cs_property_def_constant_value(cs_property_t *pty, double val)
Define a single uniform and steady isotropic definition for the given cs_property_t structure....
Definition: cs_property.c:1629
static bool cs_property_is_isotropic(const cs_property_t *pty)
Returns true if the property is isotropic, otherwise false.
Definition: cs_property.h:334
cs_xdef_t * cs_property_def_aniso_by_value(cs_property_t *pty, const char *zname, cs_real_t tens[3][3])
Define an anisotropic cs_property_t structure by value for entities related to a volume zone.
Definition: cs_property.c:1883
void cs_property_tensor_in_cell(const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval, bool do_inversion, cs_real_t tensor[3][3])
Compute the value of the tensor attached to a property at the cell center Version using a cs_cell_mes...
Definition: cs_property.c:3583
static int cs_property_get_dim(const cs_property_t *pty)
Retrieve the dimension of the property.
Definition: cs_property.h:417
cs_property_t * cs_property_by_id(int id)
Find the related property definition from its id.
Definition: cs_property.c:1115
void cs_property_log_setup(void)
Print a summary of the settings for all defined cs_property_t structures.
Definition: cs_property.c:3903
cs_xdef_t * cs_property_def_aniso_sym_by_value(cs_property_t *pty, const char *zname, cs_real_t symtens[6])
Define the value of a cs_property_t structure thanks to a time function for all cells associated to t...
Definition: cs_property.c:1994
cs_flag_t cs_property_type_t
Definition: cs_property.h:123
cs_real_t * cs_property_get_array(const cs_property_t *pty)
Retrieve the array associated to the volume definition for the given property. Available only if ther...
Definition: cs_property.c:1477
cs_property_t * cs_property_subcell_add(const char *name, cs_property_type_t type)
Create and initialize a new property structure with an evaluation which can be called on a sub-partit...
Definition: cs_property.c:1003
void cs_property_get_fourier(const cs_property_t *pty, cs_real_t t_eval, double dt, cs_real_t fourier[])
Compute the Fourier number in each cell.
Definition: cs_property.c:3837
static bool cs_property_is_subcell(const cs_property_t *pty)
Returns true if the property is allowed to be evaluated on a sub-partition of a cell.
Definition: cs_property.h:357
void cs_property_get_cell_tensor(cs_lnum_t c_id, cs_real_t t_eval, const cs_property_t *pty, bool do_inversion, cs_real_t tensor[3][3])
Compute the value of the tensor attached to a property at the cell center.
Definition: cs_property.c:3460
cs_xdef_t * cs_property_boundary_def_aniso_sym_by_value(cs_property_t *pty, const char *zname, double tens[6])
Definition: cs_property.c:2048
static bool cs_property_is_steady(const cs_property_t *pty)
Returns true if the property is steady, otherwise false.
Definition: cs_property.h:290
cs_xdef_t * cs_property_def_by_time_func(cs_property_t *pty, const char *zname, cs_time_func_t *func, void *input)
Define a cs_property_t structure thanks to a time function for all cells associated to the zone named...
Definition: cs_property.c:2093
cs_xdef_t * cs_property_def_iso_by_value(cs_property_t *pty, const char *zname, double val)
Define an isotropic cs_property_t structure by value for entities related to a volume zone.
Definition: cs_property.c:1688
void() cs_xdef_cw_eval_t(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a ce...
Definition: cs_xdef_cw_eval.h:70
void() cs_xdef_eval_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, const cs_mesh_t *mesh, const cs_cdo_connect_t *connect, const cs_cdo_quantities_t *quant, cs_real_t time_eval, void *context, cs_real_t *eval)
Definition: cs_xdef_eval.h:66
Definition: cs_property.h:75
Definition: cs_property.h:81
Definition: cs_property.h:88
Definition: cs_property.h:115
Definition: cs_property.h:94
Definition: field.f90:27
Definition: mesh.f90:26
Definition: cs_property.h:151
cs_flag_t process_flag
Definition: cs_property.h:156
cs_real_t scaling_factor
Definition: cs_property.h:171
short int * b_def_ids
Definition: cs_property.h:213
int n_related_properties
Definition: cs_property.h:200
Definition: cs_property.h:157
cs_xdef_cw_eval_t ** get_eval_at_cell_cw
Definition: cs_property.h:195
int n_definitions
Definition: cs_property.h:175
int id
Definition: cs_property.h:154
cs_xdef_t ** b_defs
Definition: cs_property.h:208
int n_b_definitions
Definition: cs_property.h:207
const cs_property_t ** related_properties
Definition: cs_property.h:201
cs_xdef_eval_t ** get_eval_at_cell
Definition: cs_property.h:190
cs_flag_t state_flag
Definition: cs_property.h:155
short int * def_ids
Definition: cs_property.h:181
char *restrict name
Definition: cs_property.h:153
cs_real_t ref_value
Definition: cs_property.h:164
cs_xdef_t ** defs
Definition: cs_property.h:176
Definition: cs_cdo_quantities.h:137
Definition: cs_field.h:131
Definition: cs_mesh.h:85
Structure storing the evaluation of a property and its related data.
Definition: cs_property.h:223
const cs_property_t * property
Definition: cs_property.h:225
bool need_eigen
Definition: cs_property.h:239
bool need_tensor
Definition: cs_property.h:233
bool is_unity
Definition: cs_property.h:228
cs_real_t eigen_max
Definition: cs_property.h:240
cs_real_t eigen_ratio
Definition: cs_property.h:241
cs_real_t value
Definition: cs_property.h:235
bool is_iso
Definition: cs_property.h:227
Definition: cs_xdef.h:160
