8.1
cs_property.h File Reference
#include "cs_flag.h"
#include "cs_param_types.h"
#include "cs_xdef.h"
#include "cs_xdef_cw_eval.h"
#include "cs_xdef_eval.h"
+ Include dependency graph for cs_property.h:
Data Structures
struct  cs_property_t
struct  cs_property_data_t
 Structure storing the evaluation of a property and its related data. More...
Macros
#define CS_PROPERTY_MASS_DENSITY   "mass_density"
#define CS_PROPERTY_POST_FOURIER   (1 << 0)
#define CS_PROPERTY_ISO   (1 << 0)
#define CS_PROPERTY_ORTHO   (1 << 1)
#define CS_PROPERTY_ANISO   (1 << 2)
#define CS_PROPERTY_ANISO_SYM   (1 << 3)
#define CS_PROPERTY_BY_PRODUCT   (1 << 4)
#define CS_PROPERTY_SCALED   (1 << 5)
#define CS_PROPERTY_SUBCELL_DEFINITION   (1 << 6)
Typedefs
typedef cs_flag_t cs_property_type_t
Enumerations
enum  cs_property_key_t { CS_PTYKEY_POST_FOURIER , CS_PTYKEY_N_KEYS }
 List of available keys for setting options on a property. More...
static bool cs_property_is_constant (const cs_property_t *pty)
 Returns true if the property is steady and uniform, otherwise false. More...
static bool cs_property_is_steady (const cs_property_t *pty)
 Returns true if the property is steady, otherwise false. More...
static bool cs_property_is_uniform (const cs_property_t *pty)
 Returns true if the property is uniform, otherwise false. More...
static bool cs_property_is_isotropic (const cs_property_t *pty)
 Returns true if the property is isotropic, otherwise false. More...
static bool cs_property_is_subcell (const cs_property_t *pty)
 Returns true if the property is allowed to be evaluated on a sub-partition of a cell. More...
static const char * cs_property_get_name (const cs_property_t *pty)
 Retrieve the name of a property. More...
static cs_property_type_t cs_property_get_type (const cs_property_t *pty)
 Retrieve the type of a property. More...
static int cs_property_get_dim (const cs_property_t *pty)
 Retrieve the dimension of the property. More...
void cs_property_init_sharing (const cs_mesh_t *mesh, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
 Set shared pointers to main domain members. More...
int cs_property_get_n_properties (void)
 Retrieve the number of properties. More...
cs_property_tcs_property_add (const char *name, cs_property_type_t type)
 Create and initialize a new property structure. More...
cs_property_tcs_property_subcell_add (const char *name, cs_property_type_t type)
 Create and initialize a new property structure with an evaluation which can be called on a sub-partition of a cell. This kind of property is not available for all numerical scheme. By default, only one evaluation is performed in each cell. More...
cs_property_tcs_property_add_as_product (const char *name, const cs_property_t *pty_a, const cs_property_t *pty_b)
 Define a cs_property_t structure thanks to the product of two properties The type is infered from that of the related properties The value of the property is given as value_ab = value_a * value_b. More...
cs_property_tcs_property_by_name (const char *name)
 Find the related property definition from its name. More...
cs_property_tcs_property_by_id (int id)
 Find the related property definition from its id. More...
void cs_property_set_option (cs_property_t *pty, cs_property_key_t key)
 Set optional parameters related to a cs_property_t structure. More...
void cs_property_set_reference_value (cs_property_t *pty, double refval)
 Set the reference value associated to a cs_property_t structure This is a real number even whatever the type of property is. More...
void cs_property_set_scaling_factor (cs_property_t *pty, double val)
 Set the scaling factor associated to a cs_property_t structure This is a real number whatever the type of property is. If the property was not defined as CS_PROPERTY_SCALED, then this tag is added. More...
void cs_property_unscale (cs_property_t *pty)
void cs_property_destroy_all (void)
 Free all cs_property_t structures and the array storing all the structures. More...
void cs_property_finalize_setup (void)
 Last stage of the definition of a property based on several definitions (i.e. definition by subdomains) More...
cs_real_tcs_property_get_array (const cs_property_t *pty)
 Retrieve the array associated to the volume definition for the given property. Available only if there is one definition by array for the volume. More...
cs_property_data_t cs_property_data_define (bool need_tensor, bool need_eigen, const cs_property_t *property)
 Define a cs_property_data_t structure (not a pointer to this structure). If property is NULL then one considers that this is a unitary property. More...
void cs_property_data_init (bool need_tensor, bool need_eigen, const cs_property_t *property, cs_property_data_t *data)
 Initialize a cs_property_data_t structure. If property is NULL then one considers that this is a unitary property. More...
cs_xdef_tcs_property_def_constant_value (cs_property_t *pty, double val)
 Define a single uniform and steady isotropic definition for the given cs_property_t structure. This is a specialized variant of cs_property_def_iso_by_value since several assumptions are satisfied. More...
cs_xdef_tcs_property_def_iso_by_value (cs_property_t *pty, const char *zname, double val)
 Define an isotropic cs_property_t structure by value for entities related to a volume zone. More...
cs_xdef_tcs_property_boundary_def_iso_by_value (cs_property_t *pty, const char *zname, double val)
 Define the value at the boundary for the given (isotropic) property. This value is uniform and steady for all the boundary faces associated to the boundary zone named zname. More...
cs_xdef_tcs_property_def_ortho_by_value (cs_property_t *pty, const char *zname, double val[])
 Define an orthotropic cs_property_t structure by value for entities related to a volume zone. More...
cs_xdef_tcs_property_boundary_def_ortho_by_value (cs_property_t *pty, const char *zname, double vals[])
 Define the value at the boundary for the given (orthotropic) property. This value is uniform and steady for all the boundary faces associated to the boundary zone named zname. More...
cs_xdef_tcs_property_def_aniso_by_value (cs_property_t *pty, const char *zname, cs_real_t tens[3][3])
 Define an anisotropic cs_property_t structure by value for entities related to a volume zone. More...
cs_xdef_tcs_property_boundary_def_aniso_by_value (cs_property_t *pty, const char *zname, double tens[3][3])
 Define the value at the boundary for the given (anisotropic) property. This value is uniform and steady for all the boundary faces associated to the boundary zone named zname. More...
cs_xdef_tcs_property_def_aniso_sym_by_value (cs_property_t *pty, const char *zname, cs_real_t symtens[6])
 Define the value of a cs_property_t structure thanks to a time function for all cells associated to the zone named zname. Optimized case with a symmetric storage. More...
cs_xdef_tcs_property_boundary_def_aniso_sym_by_value (cs_property_t *pty, const char *zname, double tens[6])
 Define the value at the boundary for the given (anisotropic) property. This value is uniform and steady for all the boundary faces associated to the boundary zone named zname Optimized case with a symmetric storage. More...
cs_xdef_tcs_property_def_by_time_func (cs_property_t *pty, const char *zname, cs_time_func_t *func, void *input)
 Define a cs_property_t structure thanks to a time function for all cells associated to the zone named zname. More...
cs_xdef_tcs_property_boundary_def_by_time_func (cs_property_t *pty, const char *zname, cs_time_func_t *func, void *input)
 Define the value of a cs_property_t structure at the boundary thanks to a time function in a subdomain attached to a zone named zname. More...
cs_xdef_tcs_property_def_by_analytic (cs_property_t *pty, const char *zname, cs_analytic_func_t *func, void *input)
 Define the value of a cs_property_t structure thanks to an analytic function for all cells associated to the zone named zname. More...
cs_xdef_tcs_property_boundary_def_by_analytic (cs_property_t *pty, const char *zname, cs_analytic_func_t *func, void *input)
 Define the value of a cs_property_t structure at the boundary thanks to a time function for all boundary faces associated to the zone named zname. More...
cs_xdef_tcs_property_def_by_func (cs_property_t *pty, const char *zname, void *context, cs_xdef_eval_t *get_eval_at_cell, cs_xdef_cw_eval_t *get_eval_at_cell_cw)
 Define the value of a cs_property_t structure thanks to low-level functions specifying how to evaluate the property in each cell (with cell-wise structures or not). This definition applies to all cells associated to the zone named zname. More...
cs_xdef_tcs_property_def_by_array (cs_property_t *pty, const char *zname, cs_flag_t val_location, cs_real_t *array, bool is_owner, bool full_length)
 Define a cs_property_t structure thanks to an array of values. If an advanced usage of the definition by array is needed, then call cs_xdef_array_set_adjacency and/or cs_xdef_array_set_sublist. More...
cs_xdef_tcs_property_boundary_def_by_array (cs_property_t *pty, const char *zname, cs_flag_t val_loc, cs_real_t *array, bool is_owner, bool full_length)
 Define the values of a property at the boundary thanks to an array. If an advanced usage of the definition by array is needed, then call cs_xdef_array_set_adjacency and/or cs_xdef_array_set_sublist. More...
cs_xdef_tcs_property_def_by_field (cs_property_t *pty, cs_field_t *field)
 Define a cs_property_t structure thanks to a field structure. One assumes that all cells are defined using this array. More...
cs_xdef_tcs_property_boundary_def_by_field (cs_property_t *pty, cs_field_t *field)
 Define the values of a property at the boundary thanks to a field structure. One assumes that all boundary faces are defined using this array. More...
void cs_property_evaluate_def (const cs_property_t *pty, int def_id, bool dense_output, double t_eval, cs_real_t *eval)
 Evaluate the values of the property at cells from the given definition. According to the parameter "dense_ouput", the "eval" array should be allocated with a size equal to pty->dim*n_cells (where "dim" depends on the type of property to handle) when no dense ouput is requested. Otherwise, an allocation size equal to pty->dim * the number of cells associated to the definition "def" is enough. More...
void cs_property_evaluate_boundary_def (const cs_property_t *pty, int def_id, bool dense_output, double t_eval, cs_real_t *array)
 Evaluate the values of a property at boundary faces from the given boundary definition. If a dense ouput is not requested, then the size of the resulting array should be allocated at least to pty->dim * n_b_faces. Otherwise, n_b_faces can be replaced by the number of boundary faces associated to the current definition. More...
void cs_property_iso_get_cell_values (cs_real_t t_eval, const cs_property_t *pty, int *pty_stride, cs_real_t **p_pty_vals)
 Evaluate the value of the property at each cell. Store the evaluation in the given array. More...
void cs_property_eval_at_cells (cs_real_t t_eval, const cs_property_t *pty, cs_real_t *array)
void cs_property_eval_at_boundary_faces (cs_real_t t_eval, const cs_property_t *pty, cs_real_t *array)
 Evaluate the value of the property at each boundary face. Store the result of the evaluation in the given array. More...
void cs_property_get_cell_tensor (cs_lnum_t c_id, cs_real_t t_eval, const cs_property_t *pty, bool do_inversion, cs_real_t tensor[3][3])
 Compute the value of the tensor attached to a property at the cell center. More...
cs_real_t cs_property_get_cell_value (cs_lnum_t c_id, cs_real_t t_eval, const cs_property_t *pty)
 Compute the value of a property at the cell center. More...
void cs_property_tensor_in_cell (const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval, bool do_inversion, cs_real_t tensor[3][3])
 Compute the value of the tensor attached to a property at the cell center Version using a cs_cell_mesh_t structure. More...
cs_real_t cs_property_value_in_cell (const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval)
 Compute the value of a property at the cell center Version using a cs_cell_mesh_t structure. More...
void cs_property_c2v_values (const cs_cell_mesh_t *cm, const cs_property_t *pty, cs_real_t t_eval, cs_real_t *eval)
 Compute the values of an isotropic property in each portion of dual cell in a (primal) cell. This relies on the c2v connectivity. More...
void cs_property_get_fourier (const cs_property_t *pty, cs_real_t t_eval, double dt, cs_real_t fourier[])
 Compute the Fourier number in each cell. More...
void cs_property_log_setup (void)
 Print a summary of the settings for all defined cs_property_t structures. More...
◆ CS_PROPERTY_MASS_DENSITY
Typedef Documentation
◆ cs_property_type_t
◆ cs_property_key_t
Enumerator
Perform the computation (and post-processing) of the Fourier number
CS_PTYKEY_N_KEYS
◆ cs_property_add()
cs_property_t* cs_property_add ( const char *  name,
[in]namename of the property
[in]typetype of property
a pointer to a new allocated cs_property_t structure
◆ cs_property_add_as_product()
cs_property_t* cs_property_add_as_product ( const char *  name,
const cs_property_t pty_a,
const cs_property_t pty_b
[in]pty_apointer to a cs_property_t structure
[in]pty_bpointer to a cs_property_t structure
◆ cs_property_boundary_def_aniso_by_value()
cs_xdef_t* cs_property_boundary_def_aniso_by_value ( cs_property_t pty,
const char *  zname,
double  tens[3][3]
[in,out]ptypointer to a cs_property_t structure
[in]znamename of the associated zone (if NULL or "" all boundary faces are considered)
[in]tensvalues to set given as a 3x3 tensor
a pointer to the resulting cs_xdef_t structure
◆ cs_property_boundary_def_aniso_sym_by_value()
cs_xdef_t* cs_property_boundary_def_aniso_sym_by_value ( cs_property_t pty,
const char *  zname,
double  tens[6]
[in]tenstensor to set given as an array of 6 values
◆ cs_property_boundary_def_by_analytic()
cs_xdef_t* cs_property_boundary_def_by_analytic ( cs_property_t pty,
const char *  zname,
cs_analytic_func_t func,
void *  input
[in]funcpointer to a cs_analytic_func_t function
◆ cs_property_boundary_def_by_array()
cs_xdef_t* cs_property_boundary_def_by_array ( cs_property_t pty,
const char *  zname,
cs_flag_t  val_loc,
cs_real_t array,
bool  is_owner,
bool  full_length
[in]znameNULL or name of the boundary zone
[in]val_locinformation to know where are located values
[in]arraypointer to an array
[in]is_ownertransfer the lifecycle to the cs_xdef_t struct. (true or false)
[in]full_lengthif true, the size of "array" should be allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection.
◆ cs_property_boundary_def_by_field()
cs_xdef_t* cs_property_boundary_def_by_field ( cs_property_t pty,
cs_field_t field
[in]fieldpointer to a cs_field_t structure
◆ cs_property_boundary_def_by_time_func()
cs_xdef_t* cs_property_boundary_def_by_time_func ( cs_property_t pty,
const char *  zname,
cs_time_func_t func,
void *  input
[in]funcpointer to a cs_time_func_t function
◆ cs_property_boundary_def_iso_by_value()
cs_xdef_t* cs_property_boundary_def_iso_by_value ( cs_property_t pty,
const char *  zname,
double  val
[in]valvalue to set
◆ cs_property_boundary_def_ortho_by_value()
cs_xdef_t* cs_property_boundary_def_ortho_by_value ( cs_property_t pty,
const char *  zname,
double  vals[]
[in]valsvalues to set
◆ cs_property_by_id()
cs_property_t* cs_property_by_id ( int  id)
[in]idid of the property to find
NULL if not found otherwise the associated pointer
◆ cs_property_by_name()
cs_property_t* cs_property_by_name ( const char *  name)
[in]namename of the property to find
◆ cs_property_c2v_values()
void cs_property_c2v_values ( const cs_cell_mesh_t cm,
const cs_property_t pty,
cs_real_t  t_eval,
cs_real_t eval
[in]ptypointer to a cs_property_t structure
[in]t_evalphysical time at which one evaluates the term
[in,out]evalarray of values storing the evaluation
◆ cs_property_data_define()
cs_property_data_t cs_property_data_define ( bool  need_tensor,
bool  need_eigen,
const cs_property_t property
[in]need_tensortrue if one needs a tensor-valued evaluation
[in]need_eigentrue if one needs an evaluation of eigen values
[in]propertypointer to the cs_property_t structure
an initialized structure
◆ cs_property_data_init()
void cs_property_data_init ( bool  need_tensor,
bool  need_eigen,
const cs_property_t property,
cs_property_data_t data
[in,out]datastructure to initialize (already allocated)
◆ cs_property_def_aniso_by_value()
cs_xdef_t* cs_property_def_aniso_by_value ( cs_property_t pty,
const char *  zname,
[in]znamename of the associated zone (if NULL or "" all cells are considered)
[in]tensvalues to set (3x3 tensor)
◆ cs_property_def_aniso_sym_by_value()
cs_xdef_t* cs_property_def_aniso_sym_by_value ( cs_property_t pty,
const char *  zname,
[in]symtenssymmetric tensor given as an array of 6 values
◆ cs_property_def_by_analytic()
cs_xdef_t* cs_property_def_by_analytic ( cs_property_t pty,
const char *  zname,
void *  input
◆ cs_property_def_by_array()
cs_xdef_t* cs_property_def_by_array ( cs_property_t pty,
const char *  zname,
cs_real_t array,
bool  is_owner,
bool  full_length
[in]znamename of the zone (if NULL or "" then all cells are selected)
[in]val_locationinformation to know where are located values
[in]is_ownertransfer the lifecycle to the cs_xdef_t struc. (true or false)
[in]full_lengthif true, the size of "array" is allocated to the total numbers of entities related to the given location. If false, a new list is allocated and filled with the related subset indirection.
◆ cs_property_def_by_field()
cs_xdef_t* cs_property_def_by_field ( cs_property_t pty,
cs_field_t field
◆ cs_property_def_by_func()
cs_xdef_t* cs_property_def_by_func ( cs_property_t pty,
const char *  zname,
void *  context,
cs_xdef_eval_t get_eval_at_cell,
cs_xdef_cw_eval_t get_eval_at_cell_cw
[in]contextpointer to a structure (may be NULL)
[in]get_eval_at_cellpointer to a function
[in]get_eval_at_cell_cwpointer to a function
◆ cs_property_def_by_time_func()
cs_xdef_t* cs_property_def_by_time_func ( cs_property_t pty,
const char *  zname,
void *  input
◆ cs_property_def_constant_value()
cs_xdef_t* cs_property_def_constant_value ( cs_property_t pty,
double  val
[in]valvalue to set
◆ cs_property_def_iso_by_value()
cs_xdef_t* cs_property_def_iso_by_value ( cs_property_t pty,
const char *  zname,
double  val
[in]valvalue to set
◆ cs_property_def_ortho_by_value()
cs_xdef_t* cs_property_def_ortho_by_value ( cs_property_t pty,
const char *  zname,
double  val[]
[in]valvalues to set (vector of size 3)
◆ cs_property_destroy_all()
void cs_property_destroy_all ( void  )
◆ cs_property_eval_at_boundary_faces()
void cs_property_eval_at_boundary_faces ( cs_real_t  t_eval,
cs_real_t array
[in,out]arraypointer to an array of values (must be allocated)
◆ cs_property_eval_at_cells()
void cs_property_eval_at_cells ( cs_real_t  t_eval,
cs_real_t array
◆ cs_property_evaluate_boundary_def()
void cs_property_evaluate_boundary_def ( const cs_property_t pty,
int  def_id,
bool  dense_output,
double  t_eval,
cs_real_t array
No scaling is applied to the value. This should be done with a higher level function like cs_property_eval_at_boundary_faces
[in]def_idid associated to the definition
[in]dense_outputtrue/false
[in,out]arrayarray storing the result of the evaluation(s)
◆ cs_property_evaluate_def()
void cs_property_evaluate_def ( const cs_property_t pty,
int  def_id,
bool  dense_output,
double  t_eval,
cs_real_t eval
No scaling is applied to the value. This should be done with a higher level function like cs_property_eval_at_cells or cs_property_get_cell_tensor
[in]ptypointer to a property structure
[in,out]evalarray storing the result of the evaluations
◆ cs_property_finalize_setup()
void cs_property_finalize_setup ( void  )
◆ cs_property_get_array()
cs_real_t* cs_property_get_array ( const cs_property_t pty)
[in]ptypointer to the property structure
a pointer to the array or NULL
◆ cs_property_get_cell_tensor()
void cs_property_get_cell_tensor ( cs_lnum_t  c_id,
cs_real_t  t_eval,
bool  do_inversion,
[in]c_idid of the current cell
[in]do_inversiontrue or false
[in,out]tensor3x3 matrix
◆ cs_property_get_cell_value()
cs_real_t cs_property_get_cell_value ( cs_lnum_t  c_id,
cs_real_t  t_eval,
the value of the property for the given cell
◆ cs_property_get_dim()
static int cs_property_get_dim ( const cs_property_t pty)
inlinestatic
the value of the dimension
◆ cs_property_get_fourier()
void cs_property_get_fourier ( const cs_property_t pty,
cs_real_t  t_eval,
double  dt,
cs_real_t  fourier[]
[in]ptypointer to the diffusive property struct.
[in]dtvalue of the current time step
[in,out]fourierpointer to an array storing Fourier numbers
◆ cs_property_get_n_properties()
int cs_property_get_n_properties ( void  )
◆ cs_property_get_name()
static const char* cs_property_get_name ( const cs_property_t pty)
inlinestatic
the name of the related property
◆ cs_property_get_type()
static cs_property_type_t cs_property_get_type ( const cs_property_t pty)
inlinestatic
the type of the related property
◆ cs_property_init_sharing()
void cs_property_init_sharing ( const cs_mesh_t mesh,
const cs_cdo_connect_t connect
[in]meshmesh structure shared between FV and CDO
◆ cs_property_is_constant()
static bool cs_property_is_constant ( const cs_property_t pty)
inlinestatic
[in]ptypointer to a property to test
true or false
◆ cs_property_is_isotropic()
static bool cs_property_is_isotropic ( const cs_property_t pty)
inlinestatic
true or false
◆ cs_property_is_steady()
static bool cs_property_is_steady ( const cs_property_t pty)
inlinestatic
true or false
◆ cs_property_is_subcell()
static bool cs_property_is_subcell ( const cs_property_t pty)
inlinestatic
true or false
◆ cs_property_is_uniform()
static bool cs_property_is_uniform ( const cs_property_t pty)
inlinestatic
true or false
◆ cs_property_iso_get_cell_values()
void cs_property_iso_get_cell_values ( cs_real_t  t_eval,
int *  pty_stride,
cs_real_t **  p_pty_vals
[out]pty_stride= 0 if uniform, =1 otherwise
[in,out]p_pty_valspointer to an array of values. Allocated if not The size of the allocation depends on the value of the pty_stride
◆ cs_property_log_setup()
void cs_property_log_setup ( void  )
◆ cs_property_set_option()
void cs_property_set_option ( cs_property_t pty,
[in]keykey related to a setting option
◆ cs_property_set_reference_value()
void cs_property_set_reference_value ( cs_property_t pty,
double  refval
[in]refvalvalue to set
◆ cs_property_set_scaling_factor()
void cs_property_set_scaling_factor ( cs_property_t pty,
double  val
[in]valvalue to set
◆ cs_property_subcell_add()
cs_property_t* cs_property_subcell_add ( const char *  name,
◆ cs_property_tensor_in_cell()
void cs_property_tensor_in_cell ( const cs_cell_mesh_t cm,
cs_real_t  t_eval,
bool  do_inversion,
◆ cs_property_unscale()
void cs_property_unscale ( cs_property_t pty)
◆ cs_property_value_in_cell()
cs_real_t cs_property_value_in_cell ( const cs_cell_mesh_t cm,
cs_real_t  t_eval
