1 #ifndef __CS_XDEF_CW_EVAL_H__
2 #define __CS_XDEF_CW_EVAL_H__
50 #define _dp3 cs_math_3_dot_product
167 *eval = constant_val[0];
192 eval[0] = constant_val[0];
193 eval[1] = constant_val[1];
194 eval[2] = constant_val[2];
219 for (
int k = 0;
k < 6;
k++)
220 eval[
k] = constant_val[
k];
244 for (
int ki = 0; ki < 3; ki++)
245 for (
int kj = 0; kj < 3; kj++)
246 eval[3*ki+kj] = constant_val[ki][kj];
278 for (
int i = 0; i < n_points; i++) {
279 eval[3*i ] = constant_val[0];
280 eval[3*i + 1] = constant_val[1];
281 eval[3*i + 2] = constant_val[2];
342 for (
int k = 0;
k < 3;
k++)
343 eval[3*f+
k] *= fq.
meas;
376 " %s: Array storing the evaluation should be allocated before"
377 " the call to this function.", __func__);
378 assert(input != NULL);
411 " %s: Array storing the evaluation should be allocated before"
412 " the call to this function.", __func__);
416 assert(input != NULL);
483 " %s: Array storing the evaluation should be allocated before"
484 " the call to this function.", __func__);
486 assert(input != NULL);
519 " %s: Array storing the evaluation should be allocated before"
520 " the call to this function.", __func__);
524 assert(input != NULL);
558 assert(input != NULL);
561 " %s: Array storing the evaluation should be allocated before"
562 " the call to this function.", __func__);
565 for (
566 for (
567 eval[3*ki+kj] = constant_val[ki][kj];
598 " %s: Array storing the evaluation should be allocated before"
599 " the call to this function.", __func__);
603 assert(input != NULL);
Definition: bft_error.c:193
Definition: cs_defs.h:514
Definition: cs_defs.h:319
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:334
#define CS_UNUSED(x)
Definition: cs_defs.h:500
Definition: cs_defs.h:515
Definition: cs_defs.h:313
@ k
const cs_flag_t cs_flag_primal_face
Definition: cs_flag.c:57
static bool cs_flag_test(cs_flag_t flag_to_check, cs_flag_t reference)
Check if a two flag share the same pattern Return true if the flag to check has at least the pattern ...
Definition: cs_flag.h:321
static bool cs_eflag_test(cs_eflag_t flag_to_check, cs_eflag_t reference)
Check if a two compute flag share the same pattern Return true if the computed flag to check has at l...
Definition: cs_flag.h:369
@ CS_FLAG_COMP_PFQ
Definition: cs_flag.h:233
static void cs_math_33_3_product(const cs_real_t m[3][3], const cs_real_t v[3], cs_real_t mv[restrict 3])
Compute the product of a matrix of 3x3 real values by a vector of 3 real values.
Definition: cs_math.h:591
cs_quadrature_type_t
Definition: cs_quadrature.h:52
void() cs_quadrature_tria_integral_t(double tcur, const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, double area, cs_analytic_func_t *ana, void *input, double results[])
Compute the integral over a triangle based on a specified quadrature rule and add it to results.
Definition: cs_quadrature.h:169
void() cs_quadrature_tetra_integral_t(double tcur, const cs_real_3_t v1, const cs_real_3_t v2, const cs_real_3_t v3, const cs_real_3_t v4, double vol, cs_analytic_func_t *ana, void *input, double results[])
Compute the integral over a tetrahedron based on a specified quadrature rule and add it to results.
Definition: cs_quadrature.h:196
void cs_xdef_cw_eval_flux_by_vector_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the (scalar-valued) normal flux of a quantity defined by an analytic ...
Definition: cs_xdef_cw_eval.c:1997
static void cs_xdef_cw_eval_scalar_face_avg_by_value(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the average on a face of a scalar function defined through a descript...
Definition: cs_xdef_cw_eval.h:362
void cs_xdef_cw_eval_tensor_avg_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating a quantity defined through a descriptor (cs_xdef_t structure) by a ce...
Definition: cs_xdef_cw_eval.c:594
static void cs_xdef_cw_eval_symtens_by_val(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Evaluate a tensor-valued quantity with a symmetric storage by a cellwise process.
Definition: cs_xdef_cw_eval.h:210
static void cs_xdef_cw_eval_face_drham_by_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating at the center of the face a scalar function defined through a descrip...
Definition: cs_xdef_cw_eval.h:440
static void cs_xdef_cw_eval_tensor_by_val(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Evaluate a tensor-valued quantity by a cellwise process.
Definition: cs_xdef_cw_eval.h:235
static void cs_xdef_cw_eval_vector_by_val(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Evaluate a vector-valued quantity by a cellwise process.
Definition: cs_xdef_cw_eval.h:182
void cs_xdef_cw_eval_scalar_face_avg_by_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.c:371
void cs_xdef_cw_eval_vect_avg_reduction_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the reduction by averages of a analytic function by a cellwise proces...
Definition: cs_xdef_cw_eval.c:2390
#define _dp3
Definition: cs_xdef_cw_eval.h:50
void() cs_xdef_cw_eval_int_t(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:113
void cs_xdef_cw_eval_flux_by_scalar_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the normal flux of a quantity defined by analytic function (scalar-va...
Definition: cs_xdef_cw_eval.c:1815
void cs_xdef_cw_eval_flux_v_by_vector_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the normal flux defined by a vector-valued quantities and relying on ...
Definition: cs_xdef_cw_eval.c:1490
void cs_xdef_cw_eval_tensor_face_avg_by_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the average on a face of a tensor function defined through a descript...
Definition: cs_xdef_cw_eval.c:459
void cs_xdef_cw_eval_c_int_by_analytic(const cs_cell_mesh_t *cm, double t_eval, cs_analytic_func_t *ana, void *input, cs_quadrature_tetra_integral_t *qfunc, cs_real_t *eval)
Integrate an analytic function over a cell.
Definition: cs_xdef_cw_eval.c:160
void cs_xdef_cw_eval_vector_flux_by_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the normal vector-valued flux of a quantity defined by analytic funct...
Definition: cs_xdef_cw_eval.c:2169
void cs_xdef_cw_eval_at_xyz_by_analytic(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval)
Function pointer for evaluating a quantity defined by analytic function at a precise location (x,...
Definition: cs_xdef_cw_eval.c:851
void() cs_xdef_cw_eval_xyz_t(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating a quantity at several locations in a cell defined through a descripto...
Definition: cs_xdef_cw_eval.h:91
void cs_xdef_cw_eval_vector_at_xyz_by_field(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval)
Function pointer for evaluating a quantity defined by a field at a precise location inside a cell Use...
Definition: cs_xdef_cw_eval.c:973
static void cs_xdef_cw_eval_vector_at_xyz_by_val(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating a quantity defined by analytic function at a precise location inside ...
Definition: cs_xdef_cw_eval.h:265
void cs_xdef_cw_eval_flux_v_by_vector_val(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_real_t *eval)
Function pointer for evaluating the normal flux defined by vector-valued quantities....
Definition: cs_xdef_cw_eval.c:1104
static void cs_xdef_cw_eval_flux_by_tensor_val(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating the normal flux of a quantity defined by values. Use of a cs_cell_mes...
Definition: cs_xdef_cw_eval.h:330
void cs_xdef_cw_eval_by_analytic(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity at the cell center defined using an analytic function by a cellwise process (usag...
Definition: cs_xdef_cw_eval.c:662
void cs_xdef_cw_eval_flux_v_by_scalar_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the normal flux defined by a scalar-valued quantities and relying on ...
Definition: cs_xdef_cw_eval.c:1172
void() cs_xdef_cw_eval_t(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:70
void cs_xdef_cw_eval_f_int_by_analytic(const cs_cell_mesh_t *cm, double t_eval, short int f, cs_analytic_func_t *ana, void *input, cs_quadrature_tria_integral_t *qfunc, cs_real_t *eval)
Integrate an analytic function over a face.
Definition: cs_xdef_cw_eval.c:105
static void cs_xdef_cw_eval_tensor_face_avg_by_array(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:586
void cs_xdef_cw_eval_scal_avg_reduction_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.c:2335
void cs_xdef_cw_eval_vector_avg_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.c:548
void cs_xdef_cw_eval_vector_face_avg_by_analytic(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Function pointer for evaluating the average on a face of a vector function defined through a descript...
Definition: cs_xdef_cw_eval.c:414
static void cs_xdef_cw_eval_scalar_by_val(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *input, cs_real_t *eval)
Evaluate a scalar-valued quantity by a cellwise process.
Definition: cs_xdef_cw_eval.h:158
void cs_xdef_cw_eval_scalar_avg_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, void *context, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.c:504
void cs_xdef_cw_eval_by_field(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity inside a cell defined using a field Variation using a cs_cell_mesh_t structure.
Definition: cs_xdef_cw_eval.c:799
static void cs_xdef_cw_eval_vector_face_avg_by_value(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:469
void cs_xdef_cw_eval_flux_v_by_scalar_val(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *context, cs_real_t *eval)
Function pointer for evaluating the normal flux defined by scalar-valued quantities....
Definition: cs_xdef_cw_eval.c:1038
void cs_xdef_cw_eval_by_array(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity at cells defined by an array. Array is assumed to be interlaced....
Definition: cs_xdef_cw_eval.c:692
void cs_xdef_cw_eval_by_time_func(const cs_cell_mesh_t *cm, cs_real_t time_eval, void *context, cs_real_t *eval)
Evaluate a quantity by a cellwise process using a definition by time function.
Definition: cs_xdef_cw_eval.c:636
static void cs_xdef_cw_eval_scalar_face_avg_by_array(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:399
void cs_xdef_cw_eval_vector_at_xyz_by_array(const cs_cell_mesh_t *cm, cs_lnum_t n_points, const cs_real_t *xyz, cs_real_t time_eval, void *context, cs_real_t *eval)
Definition: cs_xdef_cw_eval.c:887
void cs_xdef_cw_eval_fc_int_by_analytic(const cs_cell_mesh_t *cm, cs_real_t t_eval, cs_analytic_func_t *ana, void *input, const short int dim, cs_quadrature_tetra_integral_t *q_tet, cs_quadrature_tria_integral_t *q_tri, cs_real_t *c_int, cs_real_t *f_int)
Routine to integrate an analytic function over a cell and its faces.
Definition: cs_xdef_cw_eval.c:255
static void cs_xdef_cw_eval_vector_face_avg_by_array(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:507
static void cs_xdef_cw_eval_tensor_face_avg_by_value(const cs_cell_mesh_t *cm, short int f, cs_real_t t_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:546
static void cs_xdef_cw_eval_flux_by_vector_val(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *input, cs_real_t *eval)
Function pointer for evaluating the normal flux of a quantity defined by a vector-valued flux for the...
Definition: cs_xdef_cw_eval.h:300
void() cs_xdef_cw_eval_face_t(const cs_cell_mesh_t *cm, short int f, cs_real_t time_eval, void *input, cs_quadrature_type_t qtype, cs_real_t *eval)
Definition: cs_xdef_cw_eval.h:135
cs_lnum_t * f_ids
Definition: cs_cdo_local.h:240
cs_eflag_t flag
Definition: cs_cdo_local.h:205
cs_quant_t * face
Definition: cs_cdo_local.h:244
double meas
Definition: cs_cdo_quantities.h:131
double center[3]
Definition: cs_cdo_quantities.h:133
double unitv[3]
Definition: cs_cdo_quantities.h:132
Context structure when a definition by analytic function is used.
Definition: cs_xdef.h:292
cs_analytic_func_t * func
Definition: cs_xdef.h:304
void * input
Definition: cs_xdef.h:311
Context structure when an array is used for the definition.
Definition: cs_xdef.h:213
cs_real_t * values
Definition: cs_xdef.h:273
cs_flag_t value_location
Definition: cs_xdef.h:269
