#include "cs_defs.h"#include <assert.h>#include <math.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include <ple_locator.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "fvm_nodal_extract.h"#include "cs_air_props.h"#include "cs_atmo.h"#include "cs_base.h"#include "cs_boundary_conditions.h"#include "cs_boundary_zone.h"#include "cs_field.h"#include "cs_field_default.h"#include "cs_field_operator.h"#include "cs_field_pointer.h"#include "cs_halo.h"#include "cs_halo_perio.h"#include "cs_log.h"#include "cs_math.h"#include "cs_mesh.h"#include "cs_mesh_location.h"#include "cs_mesh_quantities.h"#include "cs_parameters.h"#include "cs_parall.h"#include "cs_physical_constants.h"#include "cs_physical_model.h"#include "cs_post.h"#include "cs_prototypes.h"#include "cs_restart.h"#include "cs_selector.h"#include "cs_thermal_model.h"#include "cs_velocity_pressure.h"#include "cs_volume_zone.h"#include "cs_ctwr.h"
Include dependency graph for cs_ctwr.c:Functions | |
| void | cs_ctwr_add_variable_fields (void) |
| void | cs_ctwr_add_property_fields (void) |
| void | cs_ctwr_bcond (void) |
| void | cs_ctwr_fields_init0 (void) |
| void | cs_ctwr_fields_init1 (void) |
| cs_ctwr_option_t * | cs_get_glob_ctwr_option (void) |
| void | cs_ctwr_define (const char zone_criteria[], int z_id, cs_ctwr_zone_type_t zone_type, cs_real_t delta_t, cs_real_t relax, cs_real_t t_l_bc, cs_real_t q_l_bc, cs_real_t xap, cs_real_t xnp, cs_real_t surface, cs_real_t xleak_fac) |
| Define a cooling tower exchange zone. More... | |
| void | cs_ctwr_field_pointer_map (void) |
| Map fields used by the cooling tower module to pointers. More... | |
| void | cs_ctwr_define_zones (void) |
| Define cooling tower zones. More... | |
| void | cs_ctwr_build_all (void) |
| Define the cells belonging to the different packing zones. More... | |
| void | cs_ctwr_all_destroy (void) |
| Destroy cs_ctwr_t structures. More... | |
| void | cs_ctwr_log_setup (void) |
| Log Packing zone definition setup information. More... | |
| void | cs_ctwr_log_balance (void) |
| Perform balances in packing zones. More... | |
| void | cs_ctwr_init_field_vars (cs_real_t rho0, cs_real_t t0, cs_real_t p0, cs_real_t molmassrat) |
| Initialize the field variables. More... | |
| void | cs_ctwr_init_flow_vars (cs_real_t liq_mass_flow[]) |
| Initialize the flow variables relevant to the cooling tower scalars inside the packing zones. More... | |
| void | cs_ctwr_restart_field_vars (cs_real_t rho0, cs_real_t t0, cs_real_t p0, cs_real_t humidity0, cs_real_t molmassrat) |
| Reset the field variables based on the restart values. More... | |
| void | cs_ctwr_phyvar_update (cs_real_t rho0, cs_real_t t0, cs_real_t p0) |
| Update the thermo physical properties fields for the humid air and the liquid. More... | |
| void | cs_ctwr_source_term (int f_id, cs_real_t exp_st[], cs_real_t imp_st[]) |
| Phase change source terms - Exchange terms between the injected liquid and the water vapor phase in the bulk, humid air. More... | |
| void | cs_ctwr_bulk_mass_source_term (cs_real_t mass_source[]) |
| Phase change mass source term from the evaporating liquid to the bulk, humid air. More... | |
| cs_ctwr_zone_t * | cs_ctwr_by_id (int ct_id) |
| void cs_ctwr_add_property_fields | ( | void | ) |
| void cs_ctwr_add_variable_fields | ( | void | ) |
| void cs_ctwr_all_destroy | ( | void | ) |
| void cs_ctwr_bcond | ( | void | ) |
| void cs_ctwr_build_all | ( | void | ) |
| void cs_ctwr_bulk_mass_source_term | ( | cs_real_t | mass_source[] | ) |
Careful, this is different from an injection source term, which would normally be handled with a 'cs_equation_add_volume_mass_injection_' function.
| [out] | mass_source | Mass source term |
| cs_ctwr_zone_t* cs_ctwr_by_id | ( | int | ct_id | ) |
| void cs_ctwr_define | ( | const char | zone_criteria[], |
| int | z_id, | ||
| cs_ctwr_zone_type_t | zone_type, | ||
| cs_real_t | delta_t, | ||
| cs_real_t | relax, | ||
| cs_real_t | t_l_bc, | ||
| cs_real_t | q_l_bc, | ||
| cs_real_t | xap, | ||
| cs_real_t | xnp, | ||
| cs_real_t | surface, | ||
| cs_real_t | xleak_fac | ||
| [in] | zone_criteria | zone selection criteria (or NULL) |
| [in] | z_id | z_id if zone already created (-1 otherwise) |
| [in] | zone_type | exchange zone type |
| [in] | delta_t | imposed delta temperature delta between inlet and oulet of the zone |
| [in] | relax | relaxation of the imposed delta temperature |
| [in] | t_l_bc | liquid water temperature at the inlet |
| [in] | q_l_bc | mass flow rate at the inlet |
| [in] | xap | beta_x_0 of the exchange law |
| [in] | xnp | exponent n of the exchange law |
| [in] | surface | total Surface of ingoing water |
| [in] | xleak_fac | leakage factor (ratio of outlet/inlet flow rate) |
| void cs_ctwr_define_zones | ( | void | ) |
Define zones.
TODO rename this: definition (at setup stage) and build (instanciation on actual mesh are not the same).
| void cs_ctwr_field_pointer_map | ( | void | ) |
| void cs_ctwr_fields_init0 | ( | void | ) |
| void cs_ctwr_fields_init1 | ( | void | ) |
| [in] | rho0 | Reference density of humid air |
| [in] | t0 | Reference temperature of humid air |
| [in] | p0 | Reference pressure |
| [in] | molmassrat | Dry air to water vapor molecular mass ratio |
| void cs_ctwr_init_flow_vars | ( | cs_real_t | liq_mass_flow[] | ) |
| [in,out] | liq_mass_flow | Liquid mass flow rate |
| void cs_ctwr_log_balance | ( | void | ) |
| void cs_ctwr_log_setup | ( | void | ) |
| void cs_ctwr_restart_field_vars | ( | cs_real_t | rho0, |
| cs_real_t | t0, | ||
| cs_real_t | p0, | ||
| cs_real_t | humidity0, | ||
| cs_real_t | molmassrat | ||
| [in] | humidity0 | Reference humidity |
| [in] | f_id | field id |
| [in,out] | exp_st | Explicit source term |
| [in,out] | imp_st | Implicit source term |
| cs_ctwr_option_t* cs_get_glob_ctwr_option | ( | void | ) |
