8.1
cs_air_props.h
1 #ifndef __CS_AIR_PROPS_H__
2 #define __CS_AIR_PROPS_H__
5  * Specific laws for air properties (temperature, enthalpy)
35  * Local headers
38 #include "cs_base.h"
45  * Structure definition
48 /* Structure associated to general properties */
49
50 typedef struct {
51
52  cs_real_t humidity0; /* Reference humidity */
53  cs_real_t cp_a; /* Specific heat of dry air */
54  cs_real_t cp_v; /* Specific heat of vapor */
55  cs_real_t cp_l; /* Specific heat of liquid water */
56  cs_real_t hv0; /* Chaleur latente */
57  cs_real_t rho_l; /* Masse volumique de l eau */
58  cs_real_t lambda_h; /* Humid air conductivity */
59  cs_real_t lambda_l; /* Water conductivity */
60  cs_real_t droplet_diam; /* Drop diameter for rain zones */
61  cs_real_t molmass_rat; /* Ratio of the molar mass (H2O) over the
62  molar mass (air) */
63  cs_real_t sigma; /* Surface tension between water and air */
64
66
68
69 /*============================================================================
70  * Public function prototypes for Fortran API
71  *============================================================================*/
72
73 /*============================================================================
74  * Prototypes of public function
75  *============================================================================*/
76
77 /*----------------------------------------------------------------------------*/
86
89
98 /*----------------------------------------------------------------------------*/
99
100 cs_real_t
101 cs_air_hvap(cs_real_t t_vap);
102
103 /*----------------------------------------------------------------------------*/
113
114 cs_real_t
116  cs_real_t p0);
117
118 /*----------------------------------------------------------------------------*/
128
129 cs_real_t
131  cs_real_t x_s);
132
133 /*----------------------------------------------------------------------------*/
144 /*----------------------------------------------------------------------------*/
145
146 cs_real_t
148  cs_real_t x,
149  cs_real_t x_s,
150  cs_real_t t_h);
151
152 /*----------------------------------------------------------------------------*/
163 /*----------------------------------------------------------------------------*/
164
165 cs_real_t
167  cs_real_t x,
168  cs_real_t x_s,
169  cs_real_t h_h);
170
171 /*----------------------------------------------------------------------------*/
179 /*----------------------------------------------------------------------------*/
180
181 cs_real_t
183
184 /*----------------------------------------------------------------------------*/
192 /*----------------------------------------------------------------------------*/
193
194 cs_real_t
196
197 /*----------------------------------------------------------------------------*/
198
199 /*----------------------------------------------------------------------------*/
208 /*----------------------------------------------------------------------------*/
209
210 cs_real_t
212  cs_real_t p);
213
214 /*----------------------------------------------------------------------------*/
224 /*----------------------------------------------------------------------------*/
225
226 cs_real_t
228  cs_real_t p);
229
230 /*----------------------------------------------------------------------------*/
239 /*----------------------------------------------------------------------------*/
240
241 cs_real_t
243
244 /*----------------------------------------------------------------------------*/
253 /*----------------------------------------------------------------------------*/
254
255 cs_real_t
256 cs_air_x_to_yw(const cs_real_t x);
257
258 /*----------------------------------------------------------------------------*/
267 /*----------------------------------------------------------------------------*/
268
269 cs_real_t
271
272 /*----------------------------------------------------------------------------*/
284 /*----------------------------------------------------------------------------*/
285
286 void
287 cs_rho_humidair(cs_real_t ywm, //TODO rename yw_h
288  cs_real_t t_liq,
289  cs_real_t p,
290  cs_real_t *yw_liq,
291  cs_real_t *t_h,
292  cs_real_t *rho_h);
293
294 /*----------------------------------------------------------------------------*/
307 /*----------------------------------------------------------------------------*/
308
309 cs_real_t
311  cs_real_t rho0,
312  cs_real_t p0,
313  cs_real_t t0,
314  cs_real_t molmassrat,
315  cs_real_t t_h);
316
317 /*----------------------------------------------------------------------------*/
318
320
321 #endif /* __CS_AIR_PROPERTIES_H__ */
cs_real_t cs_liq_h_to_t(cs_real_t h_l)
Calculation of the temperature of liquid water.
Definition: cs_air_props.c:352
cs_air_fluid_props_t * cs_glob_air_props
Definition: cs_air_props.c:87
cs_real_t cs_air_yw_sat(cs_real_t t_c, cs_real_t p)
Calculation of the air water mass fraction at saturation for a given temperature.
Definition: cs_air_props.c:434
cs_real_t cs_air_x_sat(cs_real_t t_c, cs_real_t p)
Calculation of the air humidity at saturation for a given temperature.
Definition: cs_air_props.c:394
cs_real_t cs_air_cp_humidair(cs_real_t x, cs_real_t x_s)
Calculation of the Cp of humid air.
Definition: cs_air_props.c:260
cs_real_t cs_liq_t_to_h(cs_real_t t_l)
Calculation of the specific enthalpy of liquid water.
Definition: cs_air_props.c:373
cs_real_t cs_air_x_to_yw(const cs_real_t x)
Convert the absolute humidity of humid air to the air water mass fraction qwt = Ym = mw/mh.
Definition: cs_air_props.c:534
cs_real_t cs_air_h_l(cs_real_t t_l)
Calculation water mass enthalpy.
Definition: cs_air_props.c:125
cs_real_t cs_air_rho_humidair(cs_real_t x, cs_real_t rho0, cs_real_t p0, cs_real_t t0, cs_real_t molmassrat, cs_real_t t_h)
Calculation of the density of humid air.
Definition: cs_air_props.c:644
cs_real_t cs_air_yw_to_x(cs_real_t qw)
Convert the air water mass fraction qwt = Ym = mw/mh to the absolute humidity of humid air.
Definition: cs_air_props.c:555
void cs_rho_humidair(cs_real_t ywm, cs_real_t t_liq, cs_real_t p, cs_real_t *yw_liq, cs_real_t *t_h, cs_real_t *rho_h)
Definition: cs_air_props.c:580
cs_real_t cs_air_hvap(cs_real_t t_vap)
Calculation water vapor mass enthalpy.
Definition: cs_air_props.c:143
cs_real_t cs_air_dxsath(cs_real_t th, cs_real_t p0)
Calculation of the derivate of the absolute humidity at saturation.
Definition: cs_air_props.c:167
cs_real_t cs_air_pwv_sat(cs_real_t t_c)
Computes the saturation water vapor pressure function of the temperature (in Celsius)
Definition: cs_air_props.c:459
cs_real_t cs_air_t_humidair(cs_real_t cp_h, cs_real_t x, cs_real_t x_s, cs_real_t h_h)
Calculation of the temperature of humid air.
Definition: cs_air_props.c:324
cs_real_t cs_air_h_humidair(cs_real_t cp_h, cs_real_t x, cs_real_t x_s, cs_real_t t_h)
Calculation of the specific enthalpy of humid air.
Definition: cs_air_props.c:291
Definition: cs_defs.h:514
Definition: cs_defs.h:319
Definition: cs_defs.h:515
@ h_l
Definition: cs_field_pointer.h:202
@ p
Definition: cs_field_pointer.h:67
@ t_l
Definition: cs_field_pointer.h:201
double precision, dimension(:,:,:), allocatable qw
Definition: atimbr.f90:109
real(c_double), pointer, save p0
reference pressure for the total pressure.
Definition: cstphy.f90:170
real(c_double), pointer, save t0
reference temperature.
Definition: cstphy.f90:217
double precision, dimension(npot), save th
temperature (in K)
Definition: ppthch.f90:119
Definition: cs_air_props.h:50
cs_real_t cp_l
Definition: cs_air_props.h:55
cs_real_t cp_v
Definition: cs_air_props.h:54
cs_real_t humidity0
Definition: cs_air_props.h:52
cs_real_t sigma
Definition: cs_air_props.h:63
Definition: cs_air_props.h:60
cs_real_t lambda_l
Definition: cs_air_props.h:59
Definition: cs_air_props.h:61
cs_real_t rho_l
Definition: cs_air_props.h:57
cs_real_t cp_a
Definition: cs_air_props.h:53
cs_real_t lambda_h
Definition: cs_air_props.h:58
cs_real_t hv0
Definition: cs_air_props.h:56
