8.0
fvm_to_histogram.h File Reference
#include "fvm_defs.h"
#include "fvm_nodal.h"
#include "fvm_writer.h"
+ Include dependency graph for fvm_to_histogram.h:
Data Structures
struct  fvm_to_histogram_writer_t
Typedefs
typedef void() fvm_to_histogram_display_t(cs_real_t var_min, cs_real_t var_max, cs_gnum_t count[], fvm_to_histogram_writer_t *w, char *var_name)
Enumerations
enum  cs_histogram_format_t { CS_HISTOGRAM_TXT , CS_HISTOGRAM_TEX , CS_HISTOGRAM_PNG }
void * fvm_to_histogram_init_writer (const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency)
void * fvm_to_histogram_finalize_writer (void *writer)
void fvm_to_histogram_set_mesh_time (void *writer, const int time_step, const double time_value)
void fvm_to_histogram_export_field (void *writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
void fvm_to_histogram_flush (void *writer)
Typedef Documentation
◆ fvm_to_histogram_display_t
Function pointer to display histograms.
parameters: var_min <– minimum variable value var_max <– maximum variable value count <– count for each histogram slice f <– pointer to the histogram file
◆ cs_histogram_format_t
Enumerator
CS_HISTOGRAM_TXT
CS_HISTOGRAM_TEX
CS_HISTOGRAM_PNG
◆ fvm_to_histogram_export_field()
void fvm_to_histogram_export_field ( void *  writer,
const fvm_nodal_t *  mesh,
const char *  name,
int  dimension,
int  n_parent_lists,
int  time_step,
double  time_value,
◆ fvm_to_histogram_finalize_writer()
void* fvm_to_histogram_finalize_writer ( void *  writer)
◆ fvm_to_histogram_flush()
void fvm_to_histogram_flush ( void *  writer)
◆ fvm_to_histogram_init_writer()
void* fvm_to_histogram_init_writer ( const char *  name,
const char *  path,
const char *  options,
◆ fvm_to_histogram_set_mesh_time()
void fvm_to_histogram_set_mesh_time ( void *  writer,
