8.0
fvm_writer.h File Reference
#include "cs_timer.h"
#include "fvm_defs.h"
#include "fvm_nodal.h"
+ Include dependency graph for fvm_writer.h:
Enumerations
enum  fvm_writer_time_dep_t { FVM_WRITER_FIXED_MESH , FVM_WRITER_TRANSIENT_COORDS , FVM_WRITER_TRANSIENT_CONNECT }
enum  fvm_writer_var_loc_t { FVM_WRITER_PER_NODE , FVM_WRITER_PER_ELEMENT , FVM_WRITER_PER_PARTICLE }
int fvm_writer_get_format_id (const char *format_name)
int fvm_writer_n_formats (void)
const char * fvm_writer_format_name (int format_index)
int fvm_writer_format_available (int format_index)
int fvm_writer_n_version_strings (int format_index)
const char * fvm_writer_version_string (int format_index, int string_index, int compile_time_version)
void fvm_writer_filter_option (char *format_options, const char *exclude_option)
fvm_writer_t * fvm_writer_init (const char *name, const char *path, const char *format_name, const char *format_options, fvm_writer_time_dep_t time_dependency)
fvm_writer_t * fvm_writer_finalize (fvm_writer_t *this_writer)
const char * fvm_writer_get_name (const fvm_writer_t *this_writer)
const char * fvm_writer_get_format (const fvm_writer_t *this_writer)
const char * fvm_writer_get_options (const fvm_writer_t *this_writer)
const char * fvm_writer_get_path (const fvm_writer_t *this_writer)
fvm_writer_time_dep_t fvm_writer_get_time_dep (const fvm_writer_t *this_writer)
void fvm_writer_set_mesh_time (fvm_writer_t *this_writer, int time_step, double time_value)
int fvm_writer_needs_tesselation (fvm_writer_t *this_writer, const fvm_nodal_t *mesh, fvm_element_t element_type)
void fvm_writer_export_nodal (fvm_writer_t *this_writer, const fvm_nodal_t *mesh)
void fvm_writer_export_field (fvm_writer_t *this_writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
void fvm_writer_flush (fvm_writer_t *this_writer)
void fvm_writer_get_times (fvm_writer_t *this_writer, cs_timer_counter_t *mesh_time, cs_timer_counter_t *field_time, cs_timer_counter_t *flush_time)
const char * fvm_writer_time_dep_name []
◆ fvm_writer_time_dep_t
Enumerator
◆ fvm_writer_var_loc_t
Enumerator
FVM_WRITER_PER_NODE
◆ fvm_writer_export_field()
void fvm_writer_export_field ( fvm_writer_t *  this_writer,
const fvm_nodal_t *  mesh,
const char *  name,
int  dimension,
int  n_parent_lists,
int  time_step,
double  time_value,
◆ fvm_writer_export_nodal()
void fvm_writer_export_nodal ( fvm_writer_t *  this_writer,
◆ fvm_writer_filter_option()
void fvm_writer_filter_option ( char *  format_options,
const char *  exclude_option
◆ fvm_writer_finalize()
fvm_writer_t* fvm_writer_finalize ( fvm_writer_t *  this_writer)
◆ fvm_writer_flush()
void fvm_writer_flush ( fvm_writer_t *  this_writer)
◆ fvm_writer_format_available()
int fvm_writer_format_available ( int  format_index)
◆ fvm_writer_format_name()
const char* fvm_writer_format_name ( int  format_index)
◆ fvm_writer_get_format()
const char* fvm_writer_get_format ( const fvm_writer_t *  this_writer)
◆ fvm_writer_get_format_id()
int fvm_writer_get_format_id ( const char *  format_name)
◆ fvm_writer_get_name()
const char* fvm_writer_get_name ( const fvm_writer_t *  this_writer)
◆ fvm_writer_get_options()
const char* fvm_writer_get_options ( const fvm_writer_t *  this_writer)
◆ fvm_writer_get_path()
const char* fvm_writer_get_path ( const fvm_writer_t *  this_writer)
◆ fvm_writer_get_time_dep()
fvm_writer_time_dep_t fvm_writer_get_time_dep ( const fvm_writer_t *  this_writer)
◆ fvm_writer_get_times()
void fvm_writer_get_times ( fvm_writer_t *  this_writer,
cs_timer_counter_t mesh_time,
cs_timer_counter_t field_time,
cs_timer_counter_t flush_time
◆ fvm_writer_init()
fvm_writer_t* fvm_writer_init ( const char *  name,
const char *  path,
const char *  format_name,
const char *  format_options,
◆ fvm_writer_n_formats()
int fvm_writer_n_formats ( void  )
◆ fvm_writer_n_version_strings()
int fvm_writer_n_version_strings ( int  format_index)
◆ fvm_writer_needs_tesselation()
int fvm_writer_needs_tesselation ( fvm_writer_t *  this_writer,
◆ fvm_writer_set_mesh_time()
void fvm_writer_set_mesh_time ( fvm_writer_t *  this_writer,
int  time_step,
double  time_value
◆ fvm_writer_version_string()
const char* fvm_writer_version_string ( int  format_index,
int  string_index,
◆ fvm_writer_time_dep_name
const char* fvm_writer_time_dep_name[]
extern
