8.0
fvm_writer.h
1 #ifndef __FVM_WRITER_H__
2 #define __FVM_WRITER_H__
5  * Handle export of mesh and fields.
30 #include "cs_defs.h"
33  * Local headers
36 #include "cs_timer.h"
38 #include "fvm_defs.h"
39 #include "fvm_nodal.h"
46  * Macro definitions
48
50  * Type definitions
52
53 /*----------------------------------------------------------------------------
54  * Element types
55  *----------------------------------------------------------------------------*/
56
57 typedef enum {
58
59  FVM_WRITER_FIXED_MESH, /* Mesh definitions do not change with time */
60  FVM_WRITER_TRANSIENT_COORDS, /* Vertex coordinates may change with time */
61  FVM_WRITER_TRANSIENT_CONNECT /* Mesh connectivity may change with time */
62
64
65 /*----------------------------------------------------------------------------
66  * Variable definition type
67  *----------------------------------------------------------------------------*/
68
69 typedef enum {
70
71  FVM_WRITER_PER_NODE, /* Variable values per node */
72  FVM_WRITER_PER_ELEMENT, /* Variable values per element */
73  FVM_WRITER_PER_PARTICLE /* Variable values per particle */
74
76
77 /*----------------------------------------------------------------------------
78  * Opaque structure defining a writer definition
79  *----------------------------------------------------------------------------*/
80
81 typedef struct _fvm_writer_t fvm_writer_t;
82
83 /*=============================================================================
84  * Static global variables
85  *============================================================================*/
86
87 /* Names of time dependency enumeration values */
88
89 extern const char *fvm_writer_time_dep_name[];
90
91 /*=============================================================================
92  * Public function prototypes
93  *============================================================================*/
94
95 /*----------------------------------------------------------------------------
96  * Find the format matching a name,
97  *
98  * parameters:
99  * format_name <-- name of desired format
100  *
101  * returns:
102  * index of the format matching the given name, or -1 if none matches.
103  *----------------------------------------------------------------------------*/
104
105 int
106 fvm_writer_get_format_id(const char *format_name);
107
108 /*----------------------------------------------------------------------------
109  * Returns number of known formats.
110  *----------------------------------------------------------------------------*/
111
112 int
114
115 /*----------------------------------------------------------------------------
116  * Returns name of a known format.
117  *
118  * parameters:
119  * format_index <-- index of format in known format list (0 to n-1)
120  *
121  * returns:
122  * pointer to constant string containing the format's name
123  *----------------------------------------------------------------------------*/
124
125 const char *
126 fvm_writer_format_name(int format_index);
127
128 /*----------------------------------------------------------------------------
129  * Returns availability of a known format.
130  *
131  * parameters:
132  * format_index <-- index of format in known format list (0 to n-1)
133  *
134  * returns:
135  * 1 if the format is available, 0 otherwise.
136  *----------------------------------------------------------------------------*/
137
138 int
139 fvm_writer_format_available(int format_index);
140
141 /*----------------------------------------------------------------------------
142  * Returns number of library version strings associated with a given format.
143  *
144  * For writers requiring an external library, the first associated
145  * version string should correspond to that library, with possible
146  * additional version strings for its dependencies.
147  *
148  * For writers only requiring standard libraries (libc, MPI, MPI-IO),
149  * this function should return 0.
150  *
151  * parameters:
152  * format_index <-- index of format in known format list (0 to n-1)
153  *
154  * returns:
155  * number of library version strings associated with a given format.
156  *----------------------------------------------------------------------------*/
157
158 int
159 fvm_writer_n_version_strings(int format_index);
160
161 /*----------------------------------------------------------------------------
162  * Returns a library version string associated with a given format.
163  *
164  * We must have string_index < fvm_writer_n_version_strings(format_index).
165  *
166  * In certain cases, when using dynamic libraries, fvm may be compiled
167  * with one library version, and linked with another. If both run-time
168  * and compile-time version information is available, this function
169  * will return the run-time version string by default.
170  *
171  * Setting the compile_time flag to 1, the compile-time version string
172  * will be returned if this is different from the run-time version.
173  * If the version is the same, or only one of the 2 version strings are
174  * available, a NULL character string will be returned with this flag set.
175  *
176  * parameters:
177  * format_index <-- index of format in known format list (0 to n-1)
178  * string_index <-- index in format's version string list (0 to n-1)
179  * compile_time <-- 0 by default, 1 if we want the compile-time version
180  * string, if different from the run-time version.
181  *
182  * returns:
183  * pointer to constant string containing the library's version.
184  *----------------------------------------------------------------------------*/
185
186 const char *
187 fvm_writer_version_string(int format_index,
188  int string_index,
189  int compile_time_version);
190
191 /*----------------------------------------------------------------------------
192  * Remove a given option from a format options list if present.
193  *
194  * The possible separators are also transformed to whitespace and merged.
195  *
196  * parameters:
197  * format_options <-> options for the selected format (case-independent,
198  * whitespace or comma separated list)
199  * exclude_option <-- option to be excluded
200  *----------------------------------------------------------------------------*/
201
202 void
203 fvm_writer_filter_option(char *format_options,
204  const char *exclude_option);
205
206 /*----------------------------------------------------------------------------
207  * Initialize FVM mesh and field output writer.
208  *
209  * Allowed options depend on what is applicable to a given format. Those
210  * not relevant to a given writer are ignored. Possible options include:
211  * text output text files (EnSight)
212  * binary output binary files (EnSight, default)
213  * big_endian force binary files to big-endian (EnSight)
214  * adf use ADF file type (CGNS)
215  * hdf5 use HDF5 file type (CGNS, default if available)
216  * discard_polygons do not output polygons or related values
217  * discard_polyhedra do not output polyhedra or related values
218  * divide_polygons tesselate polygons with triangles
219  * divide_polyhedra tesselate polyhedra with tetrahedra and pyramids
220  * (adding a vertex near each polyhedron's center)
221  * separate_meshes use a different writer for each mesh
222  *
223  * parameters:
224  * name <-- base name of output
225  * path <-- optional directory name for output
226  * (directory automatically created if necessary)
227  * format_name <-- name of selected format (case-independent)
228  * format_options <-- options for the selected format (case-independent,
229  * whitespace or comma separated list)
230  * time_dependency <-- indicates if and how meshes will change with time
231  *
232  * returns:
233  * pointer to mesh and field output writer
234  *----------------------------------------------------------------------------*/
235
236 fvm_writer_t *
237 fvm_writer_init(const char *name,
238  const char *path,
239  const char *format_name,
240  const char *format_options,
241  fvm_writer_time_dep_t time_dependency);
242
243 /*----------------------------------------------------------------------------
244  * Finalize FVM mesh and field output writer.
245  *
246  * parameters:
247  * this_writer <-- pointer to mesh and field output writer
248  *
249  * returns:
250  * NULL pointer
251  *----------------------------------------------------------------------------*/
252
253 fvm_writer_t *
254 fvm_writer_finalize(fvm_writer_t *this_writer);
255
256 /*----------------------------------------------------------------------------
257  * Return a writer's name.
258  *
259  * parameters:
260  * this_writer <-- pointer to mesh and field output writer
261  *
262  * returns:
263  * pointer to base name of output associated with the writer
264  *----------------------------------------------------------------------------*/
265
266 const char *
267 fvm_writer_get_name(const fvm_writer_t *this_writer);
268
269 /*----------------------------------------------------------------------------
270  * Return a writer's associated format name.
271  *
272  * parameters:
273  * this_writer <-- pointer to mesh and field output writer
274  *
275  * returns:
276  * pointer to output format name associated with the writer
277  *----------------------------------------------------------------------------*/
278
279 const char *
280 fvm_writer_get_format(const fvm_writer_t *this_writer);
281
282 /*----------------------------------------------------------------------------
283  * Return a writer's associated format options.
284  *
285  * parameters:
286  * this_writer <-- pointer to mesh and field output writer
287  *
288  * returns:
289  * pointer to output format options associated with the writer
290  *----------------------------------------------------------------------------*/
291
292 const char *
293 fvm_writer_get_options(const fvm_writer_t *this_writer);
294
295 /*----------------------------------------------------------------------------
296  * Return a writer's associated output directory.
297  *
298  * parameters:
299  * this_writer <-- pointer to mesh and field output writer
300  *
301  * returns:
302  * pointer to output format options associated with the writer
303  *----------------------------------------------------------------------------*/
304
305 const char *
306 fvm_writer_get_path(const fvm_writer_t *this_writer);
307
308 /*----------------------------------------------------------------------------
309  * Return geometry time dependency status of a writer.
310  *
311  * parameters:
312  * this_writer <-- pointer to mesh and field output writer
313  *
314  * returns:
315  * time dependency status
316  *----------------------------------------------------------------------------*/
317
319 fvm_writer_get_time_dep(const fvm_writer_t *this_writer);
320
321 /*----------------------------------------------------------------------------
322  * Associate new time step with a mesh.
323  *
324  * parameters:
325  * this_writer_p <-- pointer to associated writer
326  * time_step <-- time step number
327  * time_value <-- time_value number
328  *----------------------------------------------------------------------------*/
329
330 void
331 fvm_writer_set_mesh_time(fvm_writer_t *this_writer,
332  int time_step,
333  double time_value);
334
335 /*----------------------------------------------------------------------------
336  * Query if elements of a given type will need to be tesselated
337  * for use of a nodal mesh with an output writer.
338  *
339  * This function should be called before any fvm_writer_export_...()
340  *
341  * parameters:
342  * this_writer <-- pointer to mesh and field output writer
343  * mesh <-- pointer to nodal mesh
344  * element_type <-- type of element
345  *
346  * returns:
347  * 0 if no tesselation is necessary, 1 if tesselation is necessary.
348  *----------------------------------------------------------------------------*/
349
350 int
351 fvm_writer_needs_tesselation(fvm_writer_t *this_writer,
352  const fvm_nodal_t *mesh,
353  fvm_element_t element_type);
354
355 /*----------------------------------------------------------------------------
356  * Export FVM nodal mesh.
357  *
358  * parameters:
359  * this_writer <-- pointer to mesh and field output writer
360  * mesh <-- pointer to nodal mesh
361  *----------------------------------------------------------------------------*/
362
363 void
364 fvm_writer_export_nodal(fvm_writer_t *this_writer,
365  const fvm_nodal_t *mesh);
366
367 /*----------------------------------------------------------------------------
368  * Export field associated with a nodal mesh.
369  *
370  * Assigning a negative value to the time step indicates a time-independent
371  * field (in which case the time_value argument is unused).
372  *
373  * parameters:
374  * this_writer <-- pointer to mesh and field output writer
375  * mesh <-- pointer to associated nodal mesh structure
376  * name <-- variable name
377  * location <-- variable definition location (nodes or elements)
378  * dimension <-- variable dimension (0: constant, 1: scalar,
379  * 3: vector, 6: sym. tensor, 9: asym. tensor)
380  * interlace <-- indicates if variable in memory is interlaced
381  * n_parent_lists <-- indicates if variable values are to be obtained
382  * directly through the local entity index (when 0) or
383  * through the parent entity numbers (when 1 or more)
384  * parent_num_shift <-- parent number to value array index shifts;
385  * size: n_parent_lists
386  * datatype <-- indicates the data type of (source) field values
387  * time_step <-- number of the current time step
388  * time_value <-- associated time value
389  * field_values <-- array of associated field value arrays
390  *----------------------------------------------------------------------------*/
391
392 void
393 fvm_writer_export_field(fvm_writer_t *this_writer,
394  const fvm_nodal_t *mesh,
395  const char *name,
396  fvm_writer_var_loc_t location,
397  int dimension,
398  cs_interlace_t interlace,
399  int n_parent_lists,
400  const cs_lnum_t parent_num_shift[],
401  cs_datatype_t datatype,
402  int time_step,
403  double time_value,
404  const void *const field_values[]);
405
406 /*----------------------------------------------------------------------------
407  * Flush files associated with a given writer.
408  *
409  * parameters:
410  * this_writer <-- pointer to mesh and field output writer
411  *----------------------------------------------------------------------------*/
412
413 void
414 fvm_writer_flush(fvm_writer_t *this_writer);
415
416 /*----------------------------------------------------------------------------
417  * Return accumulated times associated with output for a given writer.
418  *
419  * parameters:
420  * this_writer <-- pointer to mesh and field output writer
421  * mesh_time --> Meshes output time (or NULL)
422  * field_time --> Fields output time (or NULL)
423  * flush_time --> remaining (applying output) time (or NULL)
424  *----------------------------------------------------------------------------*/
425
426 void
427 fvm_writer_get_times(fvm_writer_t *this_writer,
431
432 /*----------------------------------------------------------------------------*/
433
435
436 #endif /* __FVM_WRITER_H__ */
cs_datatype_t
Definition: cs_defs.h:272
Definition: cs_defs.h:509
cs_interlace_t
Definition: cs_defs.h:481
Definition: cs_defs.h:313
fvm_element_t
Definition: fvm_defs.h:48
const char * fvm_writer_format_name(int format_index)
Definition: fvm_writer.c:919
void fvm_writer_get_times(fvm_writer_t *this_writer, cs_timer_counter_t *mesh_time, cs_timer_counter_t *field_time, cs_timer_counter_t *flush_time)
Definition: fvm_writer.c:1626
void fvm_writer_set_mesh_time(fvm_writer_t *this_writer, int time_step, double time_value)
Definition: fvm_writer.c:1412
void fvm_writer_export_field(fvm_writer_t *this_writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
Definition: fvm_writer.c:1528
Definition: fvm_writer.h:57
@ FVM_WRITER_TRANSIENT_COORDS
Definition: fvm_writer.h:60
@ FVM_WRITER_TRANSIENT_CONNECT
Definition: fvm_writer.h:61
@ FVM_WRITER_FIXED_MESH
Definition: fvm_writer.h:59
void fvm_writer_filter_option(char *format_options, const char *exclude_option)
Definition: fvm_writer.c:1044
const char * fvm_writer_get_name(const fvm_writer_t *this_writer)
Definition: fvm_writer.c:1327
const char * fvm_writer_version_string(int format_index, int string_index, int compile_time_version)
Definition: fvm_writer.c:1015
fvm_writer_time_dep_t fvm_writer_get_time_dep(const fvm_writer_t *this_writer)
Definition: fvm_writer.c:1397
void fvm_writer_flush(fvm_writer_t *this_writer)
Definition: fvm_writer.c:1585
Definition: fvm_writer.h:69
@ FVM_WRITER_PER_NODE
Definition: fvm_writer.h:71
@ FVM_WRITER_PER_PARTICLE
Definition: fvm_writer.h:73
@ FVM_WRITER_PER_ELEMENT
Definition: fvm_writer.h:72
const char * fvm_writer_get_format(const fvm_writer_t *this_writer)
Definition: fvm_writer.c:1343
const char * fvm_writer_get_path(const fvm_writer_t *this_writer)
Definition: fvm_writer.c:1378
int fvm_writer_n_version_strings(int format_index)
Definition: fvm_writer.c:975
int fvm_writer_n_formats(void)
Definition: fvm_writer.c:903
fvm_writer_t * fvm_writer_finalize(fvm_writer_t *this_writer)
Definition: fvm_writer.c:1275
int fvm_writer_format_available(int format_index)
Definition: fvm_writer.c:939
const char * fvm_writer_get_options(const fvm_writer_t *this_writer)
Definition: fvm_writer.c:1359
int fvm_writer_needs_tesselation(fvm_writer_t *this_writer, const fvm_nodal_t *mesh, fvm_element_t element_type)
Definition: fvm_writer.c:1449
const char * fvm_writer_time_dep_name[]
Definition: fvm_writer.c:462
void fvm_writer_export_nodal(fvm_writer_t *this_writer, const fvm_nodal_t *mesh)
Definition: fvm_writer.c:1475
int fvm_writer_get_format_id(const char *format_name)
Definition: fvm_writer.c:850
fvm_writer_t * fvm_writer_init(const char *name, const char *path, const char *format_name, const char *format_options, fvm_writer_time_dep_t time_dependency)
Definition: fvm_writer.c:1127
Definition: mesh.f90:26
Definition: fvm_writer_priv.h:174
char * path
Definition: fvm_writer_priv.h:179
char * name
Definition: fvm_writer_priv.h:176
cs_timer_counter_t field_time
Definition: fvm_writer_priv.h:187
cs_timer_counter_t mesh_time
Definition: fvm_writer_priv.h:186
cs_timer_counter_t flush_time
Definition: fvm_writer_priv.h:188
Definition: cs_timer.h:55
