1 #ifndef __FVM_TO_HISTOGRAM_H__
2 #define __FVM_TO_HISTOGRAM_H__
133 #if defined(HAVE_MPI)
177 const double time_value);
206 const fvm_nodal_t *
mesh,
216 const void *
const field_values[]);
cs_datatype_t
Definition: cs_defs.h:272
Definition: cs_defs.h:509
Definition: cs_defs.h:319
unsigned long cs_gnum_t
global mesh entity number
Definition: cs_defs.h:298
cs_interlace_t
Definition: cs_defs.h:481
Definition: cs_defs.h:313
void * fvm_to_histogram_init_writer(const char *name, const char *path, const char *options, fvm_writer_time_dep_t time_dependency)
Definition: fvm_to_histogram.c:550
void() fvm_to_histogram_display_t(cs_real_t var_min, cs_real_t var_max, cs_gnum_t count[], fvm_to_histogram_writer_t *w, char *var_name)
Definition: fvm_to_histogram.h:104
void fvm_to_histogram_set_mesh_time(void *writer, const int time_step, const double time_value)
Definition: fvm_to_histogram.c:699
cs_histogram_format_t
Definition: fvm_to_histogram.h:55
@ CS_HISTOGRAM_PNG
Definition: fvm_to_histogram.h:58
@ CS_HISTOGRAM_TXT
Definition: fvm_to_histogram.h:56
@ CS_HISTOGRAM_TEX
Definition: fvm_to_histogram.h:57
void fvm_to_histogram_export_field(void *writer, const fvm_nodal_t *mesh, const char *name, fvm_writer_var_loc_t location, int dimension, cs_interlace_t interlace, int n_parent_lists, const cs_lnum_t parent_num_shift[], cs_datatype_t datatype, int time_step, double time_value, const void *const field_values[])
Definition: fvm_to_histogram.c:737
void fvm_to_histogram_flush(void *writer)
Definition: fvm_to_histogram.c:827
void * fvm_to_histogram_finalize_writer(void *writer)
Definition: fvm_to_histogram.c:666
Definition: fvm_writer.h:57
Definition: fvm_writer.h:69
Definition: fvm_to_histogram.h:65
int n_sub
Definition: fvm_to_histogram.h:83
int n_ranks
Definition: fvm_to_histogram.h:71
FILE * f
Definition: fvm_to_histogram.h:81
cs_histogram_format_t format
Definition: fvm_to_histogram.h:73
char * path
Definition: fvm_to_histogram.h:68
char * name
Definition: fvm_to_histogram.h:67
int rank
Definition: fvm_to_histogram.h:70
char * file_name
Definition: fvm_to_histogram.h:80
double t
Definition: fvm_to_histogram.h:76
int nt
Definition: fvm_to_histogram.h:75
cs_real_t * buffer
Definition: fvm_to_histogram.h:78
