| static void | cs_iter_algo_reset (cs_iter_algo_t *algo) |
| | Reset a cs_iter_algo_t structure. More...
| cs_iter_algo_t * | cs_iter_algo_create (int verbosity, cs_param_sles_cvg_t cvg_param) |
| | Create and initialize a new cs_iter_algo_t structure. More...
| void | cs_iter_algo_post_check (const char *func_name, const char *eq_name, const char *algo_name, cs_iter_algo_t *algo) |
| | Check if something wrong happens during the iterative process after one new iteration. More...
| void | cs_iter_algo_update_cvg (cs_iter_algo_t *algo) |
| | Update the convergence status and the number of iterations. The tolerance threshold has to be computed outside the function and before calling this function. More...
| void | cs_iter_algo_update_cvg_default (cs_iter_algo_t *algo) |
| | Update the convergence status and the number of iterations. The tolerance threshold is computed by a default formula relying on the relative tolerance scaled by the normalization factor and the absolute tolerance. More...
| void | cs_iter_algo_reset_nl (cs_param_nl_algo_t nl_algo_type, cs_iter_algo_t *algo) |
| | Reset a cs_iter_algo_t structure in case of a non-linear algorothm. More...
| cs_iter_algo_aa_t * | cs_iter_algo_aa_create (cs_iter_algo_param_aa_t aap, cs_lnum_t n_elts) |
| | Create a new cs_iter_algo_aa_t structure for Anderson acceleration. More...
| cs_iter_algo_param_aa_t | cs_iter_algo_get_anderson_param (cs_iter_algo_t *algo) |
| | Retrieve the set of parameters for an Anderson algorithm. More...
| void | cs_iter_algo_aa_allocate_arrays (cs_iter_algo_aa_t *aa) |
| | Allocate arrays needed by the "Anderson acceleration" algorithm. More...
| void | cs_iter_algo_aa_free_arrays (cs_iter_algo_aa_t *aa) |
| | Free arrays used during the Anderson acceleration. More...
| void | cs_iter_algo_aa_free (cs_iter_algo_t *algo) |
| | Free a cs_iter_algo_aa_t structure inside a cs_iter_algo_t structure This structure is used to manage the Anderson acceleration. More...
| void | cs_iter_algo_aa_update (cs_iter_algo_t *algo, cs_real_t *cur_iterate, const cs_real_t *pre_iterate, cs_cdo_blas_dotprod_t *dotprod, cs_cdo_blas_square_norm_t *sqnorm) |
| | Apply one more iteration of the Anderson acceleration. More...
◆ cs_iter_algo_aa_allocate_arrays()
- Parameters
| [in,out] | aa | pointer to the structure managing the Anderson algo. |
◆ cs_iter_algo_aa_create()
- Parameters
| [in] | aap | set of parameters for the Anderson acceleration |
| [in] | n_elts | number of elements by direction |
- Returns
- a pointer to the new allocated structure
◆ cs_iter_algo_aa_free()
- Parameters
| [in,out] | algo | pointer the main structure. Free the context part. |
◆ cs_iter_algo_aa_free_arrays()
- Parameters
◆ cs_iter_algo_aa_update()
- Parameters
| [in,out] | algo | pointer to a cs_iter_algo_t structure |
| [in,out] | cur_iterate | current iterate |
| [in] | pre_iterate | previous iterate |
| [in] | dotprod | function to compute a dot product |
| [in] | sqnorm | function to compute a square norm |
◆ cs_iter_algo_create()
- Parameters
| [in] | verbosity | level of information to print |
| [in] | param | set of parameters driving the convergence of the iterative algorithm |
- Returns
◆ cs_iter_algo_get_anderson_param()
◆ cs_iter_algo_post_check()
| void cs_iter_algo_post_check |
const char * |
func_name, |
const char * |
eq_name, |
const char * |
algo_name, |
cs_iter_algo_t * |
algo |
- Parameters
| [in] | func_name | name of the calling function |
| [in] | eq_name | name of the equation being solved |
| [in] | algo_name | name of the iterative algo. used |
| [in] | algo | pointer to the iterative algo. structure |
| [in] | algo | pointer to the iterative algorithm structure |
◆ cs_iter_algo_reset()
◆ cs_iter_algo_reset_nl()
- Parameters
| [in] | nl_algo_type | type of non-linear algorithm |
| [in,out] | algo | pointer to a cs_iter_algo_t |
◆ cs_iter_algo_update_cvg()
- Parameters
◆ cs_iter_algo_update_cvg_default()
- Parameters
