1 #ifndef __CS_CDO_BLAS_H__
2 #define __CS_CDO_BLAS_H__
double cs_cdo_blas_dotprod_vertex(const cs_real_t *a, const cs_real_t *b)
Compute the dot product of two arrays using the classical Euclidean dot product (without weight)....
Definition: cs_cdo_blas.c:615
cs_real_t cs_cdo_blas_square_norm_pcsp(const cs_real_t *array)
Compute the square norm of an array Case of a scalar-valued array defined as a potential at primal ce...
Definition: cs_cdo_blas.c:353
cs_real_t cs_cdo_blas_square_norm_pcsp_diff(const cs_real_t *a, const cs_real_t *b)
Compute the norm ||b - a||**2 Case of two scalar-valued arrays a and b defined as a potential at prim...
Definition: cs_cdo_blas.c:435
cs_real_t cs_cdo_blas_square_norm_face(const cs_real_t *array)
Compute the square norm of an array using an Euclidean 2-norm. Case of a scalar-valued array defined ...
Definition: cs_cdo_blas.c:1015
cs_real_t cs_cdo_blas_square_norm_pfvp(const cs_real_t *array)
Compute the square norm of an array Case of a vector-valued array defined as a potential at primal fa...
Definition: cs_cdo_blas.c:1065
cs_real_t() cs_cdo_blas_square_norm_t(const cs_real_t *array)
Generic function pointer for computing a square norm. Parallel synchronization is performed.
Definition: cs_cdo_blas.h:79
cs_real_t cs_cdo_blas_square_norm_pfsf(const cs_real_t *array)
Compute the square norm of an array Case of a scalar-valued array defined as a flux at primal faces....
Definition: cs_cdo_blas.c:1187
cs_real_t cs_cdo_blas_dotprod_face(const cs_real_t *a, const cs_real_t *b)
Definition: cs_cdo_blas.c:996
cs_real_t cs_cdo_blas_dotprod_pfsf(const cs_real_t *a, const cs_real_t *b)
Compute the dot product of two arrays using a weighted Euclidean dot product relying on CDO quantitie...
Definition: cs_cdo_blas.c:1093
double cs_cdo_blas_square_norm_vertex(const cs_real_t *array)
Definition: cs_cdo_blas.c:634
double cs_cdo_blas_square_norm_2pvsp(const cs_real_t *array)
Compute the square norm of an array Case of a non-interlaced scalar-valued array of stride = 2 define...
Definition: cs_cdo_blas.c:864
double cs_cdo_blas_dotprod_2pvsp(const cs_real_t *a, const cs_real_t *b)
Definition: cs_cdo_blas.c:903
cs_real_t cs_cdo_blas_square_norm_pvsp(const cs_real_t *array)
Compute the square norm of an array Case of a scalar-valued array defined as a potential at primal ve...
Definition: cs_cdo_blas.c:748
double cs_cdo_blas_dotprod_pvsp(const cs_real_t *a, const cs_real_t *b)
Definition: cs_cdo_blas.c:660
cs_real_t() cs_cdo_blas_square_norm_diff_t(const cs_real_t *a, const cs_real_t *b)
Generic function pointer for computing a square norm of the difference between two arrays (defined at...
Definition: cs_cdo_blas.h:96
cs_real_t cs_cdo_blas_square_norm_pfsp(const cs_real_t *array)
Compute the square norm of an array Case of a scalar-valued array defined as a potential at primal fa...
Definition: cs_cdo_blas.c:1039
cs_real_t cs_cdo_blas_square_norm_pfsf_diff(const cs_real_t *a, const cs_real_t *b)
Compute the norm ||b - a||**2 Case of a scalar-valued array defined as a flux at primal faces....
Definition: cs_cdo_blas.c:1281
cs_real_t cs_cdo_blas_square_norm_pcsp_ndiff(const cs_real_t *a, const cs_real_t *ref)
Compute the norm ||a - ref||**2 / || ref||**2 Case of two scalar-valued arrays a and ref defined as a...
Definition: cs_cdo_blas.c:520
void cs_cdo_blas_init_sharing(const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect)
Definition: cs_cdo_blas.c:330
cs_real_t cs_cdo_blas_square_norm_pvsp_diff(const cs_real_t *a, const cs_real_t *b)
Definition: cs_cdo_blas.c:774
cs_real_t() cs_cdo_blas_dotprod_t(const cs_real_t *a, const cs_real_t *b)
Generic function pointer for computing a dot product. Parallel synchronization is performed.
Definition: cs_cdo_blas.h:64
Definition: cs_defs.h:509
Definition: cs_defs.h:319
double precision, save a
Definition: cs_fuel_incl.f90:148
double precision, save b
Definition: cs_cdo_quantities.h:137
