Include dependency graph for cs_param_types.h:Go to the source code of this file.
Macros | |
| #define | CS_DOF_VTX_SCAL 0 |
| #define | CS_DOF_VTX_VECT 1 |
| #define | CS_DOF_FACE_SCAL 2 |
| #define | CS_DOF_FACE_VECT 3 |
| #define | CS_DOF_FACE_SCAP1 3 |
| #define | CS_DOF_FACE_SCAP2 4 |
| #define | CS_DOF_FACE_VECP0 3 |
| #define | CS_DOF_FACE_VECP1 5 |
| #define | CS_DOF_FACE_VECP2 6 |
| #define | CS_DOF_EDGE_SCAL 7 |
| #define | CS_N_DOF_CASES 8 |
| #define | CS_ISOTROPIC_DIFFUSION (1 << 0) |
| #define | CS_ORTHOTROPIC_DIFFUSION (1 << 1) |
| #define | CS_ANISOTROPIC_LEFT_DIFFUSION (1 << 2) |
| #define | CS_ANISOTROPIC_RIGHT_DIFFUSION (1 << 3) |
| #define | CS_ANISOTROPIC_DIFFUSION ((1 << 2) + (1 << 3)) |
| typedef void() | cs_analytic_func_t(cs_real_t time, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *coords, bool dense_output, void *input, cs_real_t *retval) |
| Generic function pointer for an evaluation relying on an analytic function. More... | |
| typedef void() | cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval) |
| Generic function pointer for computing a quantity at predefined locations such as degrees of freedom (DoF): cells, faces, edges or or vertices. More... | |
| typedef void() | cs_time_func_t(double time, void *input, cs_real_t *retval) |
| Function which defines the evolution of a quantity according to the current time and any structure given as a parameter. More... | |
Enumerations | |
| enum | cs_param_space_scheme_t { CS_SPACE_SCHEME_LEGACY , CS_SPACE_SCHEME_CDOVB , CS_SPACE_SCHEME_CDOVCB , CS_SPACE_SCHEME_CDOEB , CS_SPACE_SCHEME_CDOFB , CS_SPACE_SCHEME_CDOCB , CS_SPACE_SCHEME_HHO_P0 , CS_SPACE_SCHEME_HHO_P1 , CS_SPACE_SCHEME_HHO_P2 , CS_SPACE_N_SCHEMES } |
| Type of numerical scheme for the discretization in space. More... | |
| enum | cs_param_dof_reduction_t { CS_PARAM_REDUCTION_DERHAM , CS_PARAM_REDUCTION_AVERAGE , CS_PARAM_N_REDUCTIONS } |
| bool | cs_param_space_scheme_is_face_based (cs_param_space_scheme_t scheme) |
| Return true if the space scheme has degrees of freedom on faces, otherwise false. More... | |
| const char * | cs_param_get_space_scheme_name (cs_param_space_scheme_t scheme) |
| Get the name of the space discretization scheme. More... | |
| const char * | cs_param_get_time_scheme_name (cs_param_time_scheme_t scheme) |
| Get the name of the time discretization scheme. More... | |
| const char * | cs_param_get_advection_form_name (cs_param_advection_form_t adv_form) |
| Get the label associated to the advection formulation. More... | |
| const char * | cs_param_get_advection_scheme_name (cs_param_advection_scheme_t scheme) |
| Get the label of the advection scheme. More... | |
| const char * | cs_param_get_advection_strategy_name (cs_param_advection_strategy_t adv_stra) |
| Get the label associated to the advection strategy. More... | |
| const char * | cs_param_get_advection_extrapol_name (cs_param_advection_extrapol_t extrapol) |
| Get the label associated to the extrapolation used for the advection field. More... | |
| const char * | cs_param_get_bc_name (cs_param_bc_type_t bc) |
| Get the name of the type of boundary condition. More... | |
| const char * | cs_param_get_bc_enforcement_name (cs_param_bc_enforce_t type) |
| Get the name of the type of enforcement of the boundary condition. More... | |
| const char * | cs_param_get_nl_algo_name (cs_param_nl_algo_t algo) |
| Get the name of the non-linear algorithm. More... | |
| const char * | cs_param_get_nl_algo_label (cs_param_nl_algo_t algo) |
| Get the label (short name) of the non-linear algorithm. More... | |
| const char * | cs_param_get_dotprod_type_name (cs_param_dotprod_type_t dp_type) |
| Get the name of the type of dot product to apply. More... | |
| const char * | cs_param_get_solver_name (cs_param_itsol_type_t solver) |
| Get the name of the solver. More... | |
| const char * | cs_param_get_precond_name (cs_param_precond_type_t precond) |
| Get the name of the preconditioner. More... | |
| const char * | cs_param_get_precond_block_name (cs_param_precond_block_t type) |
| Get the name of the type of block preconditioning. More... | |
| const char * | cs_param_get_schur_approx_name (cs_param_schur_approx_t type) |
| Get the name of the type of Schur complement approximation. More... | |
| const char * | cs_param_get_amg_type_name (cs_param_amg_type_t type) |
| Get the name of the type of algebraic multigrid (AMG) More... | |
| const char | cs_sep_h1 [80] |
| const char | cs_sep_h2 [80] |
| const char | cs_sepline [80] |
| const char | cs_med_sepline [50] |
Numerical settings for time discretization | |
| enum | cs_param_time_scheme_t { CS_TIME_SCHEME_STEADY , CS_TIME_SCHEME_EULER_IMPLICIT , CS_TIME_SCHEME_EULER_EXPLICIT , CS_TIME_SCHEME_CRANKNICO , CS_TIME_SCHEME_THETA , CS_TIME_SCHEME_BDF2 , CS_TIME_N_SCHEMES } |
Settings for non-linear algorithms | |
| enum | cs_param_nl_algo_t { CS_PARAM_NL_ALGO_NONE , CS_PARAM_NL_ALGO_PICARD , CS_PARAM_NL_ALGO_ANDERSON , CS_PARAM_N_NL_ALGOS } |
| Class of non-linear iterative algorithm. More... | |
| typedef void() cs_analytic_func_t(cs_real_t time, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, const cs_real_t *coords, bool dense_output, void *input, cs_real_t *retval) |
For the calling function, elt_ids is optional. If not NULL, the coords array should be accessed with an indirection. The same indirection can be applied to fill retval if dense_output is set to false.
| [in] | time | when ? |
| [in] | elt_ids | list of elements ids (in coords and retval) |
| [in] | coords | where ? |
| [in,out] | retval | resulting value(s). Must be allocated. |
| typedef void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval) |
For the calling function, elt_ids is optional. If not NULL, array(s) should be accessed with an indirection. The same indirection can be applied to fill retval if dense_output is set to false.
| typedef void() cs_time_func_t(double time, void *input, cs_real_t *retval) |
| [in] | time | value of the time at the end of the last iteration |
| [in] | retval | result of the evaluation |
Choice of how to extrapolate the advection field in the advection term.
Type of formulation for the advection term
Type of numerical scheme for the advection term
| Enumerator | |
| CS_PARAM_ADVECTION_SCHEME_CENTERED | centered discretization |
| CS_PARAM_ADVECTION_SCHEME_CIP | Continuous Interior Penalty discretization. Only available for CS_SPACE_SCHEME_CDOVCB |
| CS_PARAM_ADVECTION_SCHEME_CIP_CW | Continuous Interior Penalty discretization. Only available for CS_SPACE_SCHEME_CDOVCB Variant with a cellwise constant approximation of the advection field |
| CS_PARAM_ADVECTION_SCHEME_HYBRID_CENTERED_UPWIND | Centered discretization with a portion between [0,1] of upwinding. The portion is specified thanks to CS_EQKEY_ADV_UPWIND_PORTION If the portion is equal to 0, then one recovers CS_PARAM_ADVECTION_SCHEME_CENTERED. If the portion is equal to 1, then one recovers CS_PARAM_ADVECTION_SCHEME_UPWIND |
| CS_PARAM_ADVECTION_SCHEME_SAMARSKII | Weighting between an upwind and a centered discretization relying on the Peclet number. Weighting function = Samarskii |
| CS_PARAM_ADVECTION_SCHEME_SG | Weighting between an upwind and a centered discretization relying on the Peclet number. Weighting function = Scharfetter-Gummel |
| CS_PARAM_ADVECTION_SCHEME_UPWIND | Low order upwind discretization |
| CS_PARAM_N_ADVECTION_SCHEMES | |
Choice of how to handle the advection term in an equation.
| Enumerator | |
| CS_PARAM_ADVECTION_IMPLICIT_FULL | The advection term is implicitly treated. The non-linearity stemming from this term has to be solved using a specific algorithm such as the Picard (fixed-point) technique or more elaborated techniques. |
| CS_PARAM_ADVECTION_IMPLICIT_LINEARIZED | The advection term is implicitly treated. The non-linearity stemming from this term is simplified. Namely, one assumes a linearized advection. This is equivalent to a one-step Picard technique. |
| CS_PARAM_ADVECTION_EXPLICIT | The advection term is treated explicitly. One keeps the non-linearity stemming from this term at the right hand-side. An extrapolation can be used for the advection field (cf. cs_param_advection_extrapol_t) |
| CS_PARAM_N_ADVECTION_STRATEGIES | |
| enum cs_param_amg_type_t |
Type of AMG (Algebraic MultiGrid) algorithm to use (either as a preconditioner with or a solver). There are different choices of implementation and of type of cycle
Type of method for enforcing the boundary conditions. According to the type of numerical scheme, some enforcements are not available.
| Enumerator | |
| CS_PARAM_BC_ENFORCE_ALGEBRAIC | Weak enforcement of the boundary conditions (i.e. one keeps the degrees of freedom in the algebraic system) with an algebraic manipulation of the linear system |
| CS_PARAM_BC_ENFORCE_PENALIZED | Weak enforcement of the boundary conditions (i.e. one keeps the degrees of freedom in the algebraic system) with a penalization technique using a huge value. |
| CS_PARAM_BC_ENFORCE_WEAK_NITSCHE | Weak enforcement of the boundary conditions (i.e. one keeps the degrees of freedom in the algebraic system) with a Nitsche-like penalization technique. This technique does not increase the conditioning number as much as CS_PARAM_BC_ENFORCE_PENALIZED but is more computationally intensive. The computation of the diffusion term should be activated with this choice. |
| CS_PARAM_BC_ENFORCE_WEAK_SYM | Weak enforcement of the boundary conditions (i.e. one keeps the degrees of freedom in the algebraic system) with a Nitsche-like penalization technique. This variant enables to keep the symmetry of the algebraic contrary to CS_PARAM_BC_ENFORCE_WEAK_NITSCHE. The computation of the diffusion term should be activated with this choice. |
| CS_PARAM_N_BC_ENFORCEMENTS | |
| enum cs_param_bc_type_t |
Type of boundary condition to enforce.
Type of solver to use to solve a linear system. Some of the mentionned solver are available only if the PETSc library is linked with code_saturne.
| Enumerator | |
| CS_PARAM_ITSOL_NONE | No iterative solver (equivalent to a "preonly" choice in PETSc) |
| CS_PARAM_ITSOL_AMG | Algebraic multigrid solver (additional options may be set using cs_param_amg_type_t) |
| CS_PARAM_ITSOL_BICG | Bi-Conjuguate gradient (useful for non-symmetric systems) |
| CS_PARAM_ITSOL_BICGSTAB2 | Stabilized Bi-Conjuguate gradient (useful for non-symmetric systems) |
| CS_PARAM_ITSOL_CG | Conjuguate Gradient (solver of choice for symmetric positive definite systems) |
| CS_PARAM_ITSOL_CR3 | 3-layer conjugate residual (can handle non-symmetric systems) |
| CS_PARAM_ITSOL_FCG | Flexible Conjuguate Gradient (variant of the CG when the preconditioner may change from one iteration to another. For instance when using an AMG as preconditioner) |
| CS_PARAM_ITSOL_FGMRES | Only with PETSc Flexible Generalized Minimal RESidual |
| CS_PARAM_ITSOL_GAUSS_SEIDEL | Gauss-Seidel |
| CS_PARAM_ITSOL_GCR | Generalized conjugate residual (flexible iterative solver for symmetric or non-symmetric system) |
| CS_PARAM_ITSOL_GKB_CG | Golub-Kahan Bidiagonalization algorithm. Useful for solving saddle-point systems. The inner solver is a (flexible) CG solver. |
| CS_PARAM_ITSOL_GKB_GMRES | Golub-Kahan Bidiagonalization algorithm. Useful for solving saddle-point systems. The inner solver is a (flexible) GMRES solver. |
| CS_PARAM_ITSOL_GMRES | Only with PETSc Generalized Minimal RESidual |
| CS_PARAM_ITSOL_JACOBI | Jacobi (diagonal relaxation) |
| CS_PARAM_ITSOL_MINRES | Only with PETSc Mininal residual algorithm |
| CS_PARAM_ITSOL_MUMPS | Only with PETSc or MUMPS MUMPS direct solver (LU factorization) |
| CS_PARAM_ITSOL_MUMPS_FLOAT | Only with MUMPS MUMPS direct solver (LU factorization with float instead of double). This enables a saving of the memory consumption which is acceptable if one considers a preconditioner |
| CS_PARAM_ITSOL_MUMPS_FLOAT_LDLT | Only with MUMPS MUMPS direct solver (LDLT factorization also known as Cholesky factorization). Only for SPD matrices. This enables a saving of the memory consumption which is acceptable if one considers a preconditioner |
| CS_PARAM_ITSOL_MUMPS_FLOAT_SYM | Only with MUMPS MUMPS direct solver for general symmetric matrices This enables a saving of the memory consumption which is acceptable if one considers a preconditioner |
| CS_PARAM_ITSOL_MUMPS_LDLT | Only MUMPS MUMPS direct solver (LDLT factorization also known as Cholesky factorization) for SPD matrices |
| CS_PARAM_ITSOL_MUMPS_SYM | Only with MUMPS MUMPS direct solver for general symmetric matrices |
| CS_PARAM_ITSOL_SYM_GAUSS_SEIDEL | Symmetric Gauss-Seidel |
| CS_PARAM_ITSOL_USER_DEFINED | User-defined iterative solver. It relies on the implementation of the the function cs_user_sles_it_solver() |
| CS_PARAM_N_ITSOL_TYPES | |
| enum cs_param_nl_algo_t |
Type of preconditioning by block
| Enumerator | |
| CS_PARAM_PRECOND_BLOCK_NONE | No block preconditioner is requested (default) |
| CS_PARAM_PRECOND_BLOCK_DIAG | Only the diagonal blocks are considered in the preconditioner |
| CS_PARAM_PRECOND_BLOCK_FULL_DIAG | Only the diagonal blocks are considered in the preconditioner. All possible blocks are considered. With simple cases, this is equivalent to CS_PARAM_PRECOND_BLOCK_DIAG |
| CS_PARAM_PRECOND_BLOCK_FULL_LOWER_TRIANGULAR | The diagonal blocks and the lower blocks are considered in the preconditioner. All possible blocks are considered. With simple cases, this is equivalent to CS_PARAM_PRECOND_BLOCK_FULL_LOWER_TRIANGULAR |
| CS_PARAM_PRECOND_BLOCK_FULL_SYM_GAUSS_SEIDEL | A symmetric Gauss-Seidel block preconditioning is considered (cf. Y. Notay, "A new analysis of block preconditioners for saddle-point problems" (2014), SIAM J. Matrix. Anal. Appl.) All possible blocks are considered. With simple cases, this is equivalent to CS_PARAM_PRECOND_BLOCK_FULL_SYM_GAUSS_SEIDEL |
| CS_PARAM_PRECOND_BLOCK_FULL_UPPER_TRIANGULAR | The diagonal blocks and the upper blocks are considered in the preconditioner All possible blocks are considered. With simple cases, this is equivalent to CS_PARAM_PRECOND_BLOCK_FULL_UPPER_TRIANGULAR |
| CS_PARAM_PRECOND_BLOCK_LOWER_TRIANGULAR | The diagonal blocks and the lower blocks are considered in the preconditioner |
| CS_PARAM_PRECOND_BLOCK_SYM_GAUSS_SEIDEL | A symmetric Gauss-Seidel block preconditioning is considered (cf. Y. Notay, "A new analysis of block preconditioners for saddle-point problems" (2014), SIAM J. Matrix. Anal. Appl.) |
| CS_PARAM_PRECOND_BLOCK_UPPER_TRIANGULAR | The diagonal blocks and the upper blocks are considered in the preconditioner |
| CS_PARAM_PRECOND_BLOCK_UZAWA | One iteration of block Uzawa is performed as preconditioner |
| CS_PARAM_N_PCD_BLOCK_TYPES | |
Type of preconditioner to use with the iterative solver. Some of the mentionned preconditioners are available only if the PETSc library is linked with code_saturne
| Enumerator | |
| CS_PARAM_PRECOND_NONE | No preconditioner |
| CS_PARAM_PRECOND_BJACOB_ILU0 | Only with PETSc Block Jacobi with an ILU zero fill-in in each block |
| CS_PARAM_PRECOND_BJACOB_SGS | Only with PETSc Block Jacobi with a symmetric Gauss-Seidel in each block (rely on Eisenstat's trick with PETSc) |
| CS_PARAM_PRECOND_AMG | Algebraic multigrid preconditioner (additional options may be set using cs_param_amg_type_t) |
| CS_PARAM_PRECOND_DIAG | Diagonal (also Jacobi) preconditioner. The cheapest one but not the most efficient one. |
| CS_PARAM_PRECOND_GKB_CG | Only with PETSc Golub-Kahan Bidiagonalization solver used as a preconditioner. Only useful if one has to solve a saddle-point system (such systems arise when solving Stokes or Navier-Stokes in a fully couple manner). Variant with CG as inner solver. |
| CS_PARAM_PRECOND_GKB_GMRES | Only with PETSc Golub-Kahan Bidiagonalization solver used as a preconditioner. Only useful if one has to solve a saddle-point system (such systems arise when solving Stokes or Navier-Stokes in a fully couple manner). Variant with GMRES as inner solver. |
| CS_PARAM_PRECOND_LU | Only with PETSc LU factorization (direct solver) with PETSc |
| CS_PARAM_PRECOND_ILU0 | Only with PETSc Incomplete LU factorization (fill-in coefficient set to 0) |
| CS_PARAM_PRECOND_ICC0 | Only with PETSc Incomplete Cholesky factorization (fill-in coefficient set to 0). This is variant of the ILU0 preconditioner dedicated to symmetric positive definite system |
| CS_PARAM_PRECOND_MUMPS | Only with MUMPS Direct solver available with the MUMPS library and used as a preconditioner Case of a L.U factorization and double-precision |
| CS_PARAM_PRECOND_MUMPS_FLOAT | Only with MUMPS Direct solver available with the MUMPS library and used as a preconditioner Case of a L.U factorization and single-precision |
| CS_PARAM_PRECOND_MUMPS_FLOAT_LDLT | Only with MUMPS Direct solver available with the MUMPS library and used as a preconditioner Case of a L.D.Lt factorization and single-precision The input matrix should be symmetric positive definite (SPD). |
| CS_PARAM_PRECOND_MUMPS_FLOAT_SYM | Only with MUMPS Direct solver available with the MUMPS library and used as a preconditioner Case of single-precision factorization. The input matrix should be symmetric |
| CS_PARAM_PRECOND_MUMPS_LDLT | Only with MUMPS Direct solver available with the MUMPS library and used as a preconditioner Case of a L.D.Lt factorization and double-precision The input matrix should be symmetric definite positive (SPD). |
| CS_PARAM_PRECOND_MUMPS_SYM | Only with MUMPS Direct solver available with the MUMPS library and used as a preconditioner Case of double-precision factorization. The input matrix should be symmetric |
| CS_PARAM_PRECOND_POLY1 | Neumann polynomial preconditioning. Polynoms of order 1. |
| CS_PARAM_PRECOND_POLY2 | Neumann polynomial preconditioning. Polynoms of order 2. |
| CS_PARAM_PRECOND_SSOR | Symmetric Successive OverRelaxations (can be seen as a symmetric Gauss-Seidel preconditioner) |
| CS_PARAM_N_PRECOND_TYPES | |
Way to renormalize (or not) the residual arising during the resolution of linear systems
Type of preconditioner used to solve a saddle-point system. Up to now, this happens only with CDO cell-based schemes. Saddle-point system arising from the Stokes or Navier-Stokes equations are handled differently even though there are several similarities.
| Enumerator | |
| CS_PARAM_SADDLE_PRECOND_NONE | No preconditioner to apply. |
| CS_PARAM_SADDLE_PRECOND_DIAG_SCHUR | A block-diagonal preconditioner is used. The (1,1)-block is an approximation of the (1,1)-block in the saddle-point system based on a cheap resolution. The parameter settings for this resolution relies on the structure cs_param_sles_t. The (2,2)-block in the preconditioner is the Schur approximation. Please refer to cs_param_schur_approx_t to get a detailed view of the possibilities. |
| CS_PARAM_SADDLE_PRECOND_LOWER_SCHUR | A 2x2 block matrix is used as preconditioner with the (1,2)-block fills with zero. The (1,1)-block is an approximation of the (1,1)-block in the saddle-point system based on a cheap resolution. The parameter settings for this resolution relies on the structure cs_param_sles_t The (2,2)-block in the preconditioner is the Schur approximation. Please refer to cs_param_schur_approx_t to get a detailed view of the possibilities. |
| CS_PARAM_SADDLE_PRECOND_UPPER_SCHUR | A 2x2 block matrix is used as preconditioner with the (2,1)-block fills with zero. The (1,1)-block is an approximation of the (1,1)-block in the saddle-point system based on a cheap resolution. The parameter settings for this resolution relies on the structure cs_param_sles_t The (2,2)-block in the preconditioner is the Schur approximation. Please refer to cs_param_schur_approx_t to get a detailed view of the possibilities. |
| CS_PARAM_SADDLE_N_PRECOND | |
Type of solver used to solve a saddle-point system. Up to now, this happens only with CDO cell-based schemes. Saddle-point system arising from the Stokes or Navier-Stokes equations are handled differently even though there are several similarities. The main differences are the fact that the (1,1) block is vector-valued and that there can be specific optimizations in the preconditioning (the Schur complement approximation for instance) since one has a more advanced knowledge of the system.
Strategy to build the Schur complement approximation. This appears in block preconditioning or Uzawa algorithms when a fully coupled (also called monolithic) approach) is used.
The exact Schur complement is then
How is defined the degree of freedom.
Type of numerical scheme for the discretization in time
| const char* cs_param_get_advection_extrapol_name | ( | cs_param_advection_extrapol_t | extrapol | ) |
| [in] | extrapol | type of extrapolation for the advection field |
| const char* cs_param_get_advection_form_name | ( | cs_param_advection_form_t | adv_form | ) |
| [in] | adv_form | type of advection formulation |
| const char* cs_param_get_advection_scheme_name | ( | cs_param_advection_scheme_t | scheme | ) |
| [in] | scheme | type of advection scheme |
| const char* cs_param_get_advection_strategy_name | ( | cs_param_advection_strategy_t | adv_stra | ) |
| [in] | adv_stra | type of advection strategy |
| const char* cs_param_get_amg_type_name | ( | cs_param_amg_type_t | type | ) |
| [in] | type | type of AMG |
| const char* cs_param_get_bc_enforcement_name | ( | cs_param_bc_enforce_t | type | ) |
| [in] | type | type of enforcement of boundary conditions |
| const char* cs_param_get_bc_name | ( | cs_param_bc_type_t | type | ) |
| [in] | type | type of boundary condition |
| const char* cs_param_get_dotprod_type_name | ( | cs_param_dotprod_type_t | dp_type | ) |
| [in] | dp_type | type of dot product |
| const char* cs_param_get_nl_algo_label | ( | cs_param_nl_algo_t | algo | ) |
| [in] | algo | type of algorithm |
| const char* cs_param_get_nl_algo_name | ( | cs_param_nl_algo_t | algo | ) |
| const char* cs_param_get_precond_block_name | ( | cs_param_precond_block_t | type | ) |
| [in] | type | type of block preconditioning |
| const char* cs_param_get_precond_name | ( | cs_param_precond_type_t | precond | ) |
| [in] | precond | type of preconditioner |
| const char* cs_param_get_schur_approx_name | ( | cs_param_schur_approx_t | type | ) |
| [in] | type | type of Schur complement approximation |
| const char* cs_param_get_solver_name | ( | cs_param_itsol_type_t | solver | ) |
| [in] | solver | type of iterative solver |
| const char* cs_param_get_space_scheme_name | ( | cs_param_space_scheme_t | scheme | ) |
| [in] | scheme | type of space scheme |
| const char* cs_param_get_time_scheme_name | ( | cs_param_time_scheme_t | scheme | ) |
| [in] | scheme | type of time scheme |
| bool cs_param_space_scheme_is_face_based | ( | cs_param_space_scheme_t | scheme | ) |
extern |
extern |
extern |
extern |
