#include "cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <math.h>#include <string.h>#include <fcntl.h>#include <unistd.h>#include <assert.h>#include "bft_mem.h"#include "bft_error.h"#include "bft_printf.h"#include "fvm_selector.h"#include "cs_ale.h"#include "cs_atmo.h"#include "cs_base.h"#include "cs_boundary.h"#include "cs_boundary_conditions.h"#include "cs_boundary_zone.h"#include "cs_cf_thermo.h"#include "cs_combustion_model.h"#include "cs_equation_param.h"#include "cs_parameters.h"#include "cs_gui_util.h"#include "cs_gui.h"#include "cs_gui_specific_physics.h"#include "cs_ht_convert.h"#include "cs_meg_prototypes.h"#include "cs_mesh.h"#include "cs_field.h"#include "cs_field_default.h"#include "cs_field_operator.h"#include "cs_field_pointer.h"#include "cs_physical_model.h"#include "cs_thermal_model.h"#include "cs_timer.h"#include "cs_tree.h"#include "cs_turbulence_bc.h"#include "cs_turbulence_model.h"#include "cs_parall.h"#include "cs_elec_model.h"#include "cs_wall_functions.h"#include "cs_gui_boundary_conditions.h"
Include dependency graph for cs_gui_boundary_conditions.c:Functions | |
| void | uiclim (const int *nozppm, int *iqimp, int *icalke, int *ientat, int *ientcp, int *inmoxy, int *ientox, int *ientfu, int *ientgf, int *ientgb, int *iprofm, int *iautom, int *itypfb, int *izfppp, double *qimp, double *qimpat, double *qimpcp, double *dh, double *xintur, double *timpat, double *timpcp, double *tkent, double *fment, double *distch) |
| void | uiclve (const int *nozppm) |
| void | cs_gui_boundary_conditions_define (cs_boundary_t *bdy) |
| Define boundary conditions based on setup file. More... | |
| void | cs_gui_boundary_conditions_free_memory (void) |
| Free GUI boundary condition structures. More... | |
| cs_gui_boundary_meg_context_t * | cs_gui_boundary_add_meg_context (const cs_zone_t *zone, const char *name, const char *condition, int dim) |
| Add new MEG-based cs_dof_func_t context info. More... | |
| void | cs_gui_boundary_conditions_dof_func_meg (cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval) |
| cs_dof_func_t function to compute boundary condition values using a MEG generated function. More... | |
| cs_gui_boundary_meg_context_t* cs_gui_boundary_add_meg_context | ( | const cs_zone_t * | zone, |
| const char * | name, | ||
| const char * | condition, | ||
| int | dim | ||
| [in] | zone | pointer to associated zone |
| [in] | name | name of associated field or array |
| [in] | condition | associated condition type |
| [in] | dim | associated dimension |
| void cs_gui_boundary_conditions_define | ( | cs_boundary_t * | bdy | ) |
| [in,out] | bdy | boundaries structure to update (if NULL, default to cs_glob_domain->boundaries) |
| void cs_gui_boundary_conditions_dof_func_meg | ( | cs_lnum_t | n_elts, |
| bool | dense_output, | ||
| void * | input, | ||
| cs_real_t * | retval | ||
cs_dof_func_t function to compute a boundary profiles using a MEG generated function.
For the calling function, elt_ids is optional. If not NULL, array(s) should be accessed with an indirection. The same indirection can be applied to fill retval if dense_output is set to false. In the current case, retval is allocated to mesh->n_b_faces
| [in,out] | retval | resulting value(s). Must be allocated. |
| void cs_gui_boundary_conditions_free_memory | ( | void | ) |
| void uiclim | ( | const int * | nozppm, |
| int * | iqimp, | ||
| int * | icalke, | ||
| int * | ientat, | ||
| int * | ientcp, | ||
| int * | inmoxy, | ||
| int * | ientox, | ||
| int * | ientfu, | ||
| int * | ientgf, | ||
| int * | ientgb, | ||
| int * | iprofm, | ||
| int * | iautom, | ||
| int * | itypfb, | ||
| int * | izfppp, | ||
| double * | qimp, | ||
| double * | qimpat, | ||
| double * | qimpcp, | ||
| double * | dh, | ||
| double * | xintur, | ||
| double * | timpat, | ||
| double * | timpcp, | ||
| double * | tkent, | ||
| double * | fment, | ||
| double * | distch | ||
| void uiclve | ( | const int * | nozppm | ) |
