8.0
cs_turbulence_bc.h
1 #ifndef __CS_TURBULENCE_BC_H__
2 #define __CS_TURBULENCE_BC_H__
5  * Base turbulence boundary conditions.
31  * Local headers
34 #include "cs_defs.h"
41  * Macro definitions
45  * Type definitions
49  * Global variables
51
52 /*=============================================================================
53  * Public function prototypes
55
56 /*----------------------------------------------------------------------------*/
60 /*----------------------------------------------------------------------------*/
61
62 void
64
65 /*----------------------------------------------------------------------------*/
69 /*----------------------------------------------------------------------------*/
70
71 void
73
117 /*----------------------------------------------------------------------------*/
118
119 void
120 cs_turbulence_bc_ke_hyd_diam(double uref2,
121  double dh,
122  double rho,
123  double mu,
124  double *ustar2,
125  double *k,
126  double *eps);
127
147
148 void
150  double t_intensity,
151  double dh,
152  double *k,
153  double *eps);
154
155 /*----------------------------------------------------------------------------*/
188 /*----------------------------------------------------------------------------*/
189
190 void
192  double uref2,
193  double dh,
194  double rho,
195  double mu);
196
197 /*----------------------------------------------------------------------------*/
209 /*----------------------------------------------------------------------------*/
210
211 void
213  double uref2,
214  double t_intensity,
215  double dh);
216
217 /*----------------------------------------------------------------------------*/
226 /*----------------------------------------------------------------------------*/
227
228 void
230  double k,
231  double eps);
232
233 /*----------------------------------------------------------------------------*/
251 /*----------------------------------------------------------------------------*/
252
253 void
255  double vel_dir[],
256  double shear_dir[],
257  double uref2,
258  double dh,
259  double rho,
260  double mu);
261
262 /*----------------------------------------------------------------------------*/
277 /*----------------------------------------------------------------------------*/
278
279 void
281  double uref2,
282  double t_intensity,
283  double dh);
284
285 /*----------------------------------------------------------------------------*/
296 /*----------------------------------------------------------------------------*/
297
298 void
300  double k,
301  double eps,
302  double vel_dir[],
303  double shear_dir[]);
304
305 /*----------------------------------------------------------------------------*/
361 /*----------------------------------------------------------------------------*/
362
363 void
365  cs_real_t p_lg[3][3],
366  cs_real_t alpha[6][6]);
367
368 /*----------------------------------------------------------------------------*/
369
371
372 #endif /* __CS_TURBULENCE_BC_H__ */
Definition: cs_defs.h:509
Definition: cs_defs.h:319
Definition: cs_defs.h:313
@ k
@ mu
Definition: cs_field_pointer.h:103
@ eps
Definition: cs_field_pointer.h:71
@ rho
void cs_turbulence_bc_ke_turb_intensity(double uref2, double t_intensity, double dh, double *k, double *eps)
Calculation of and from a diameter , a turbulent intensity and the reference velocity for a circu...
Definition: cs_turbulence_bc.c:827
Definition: cs_turbulence_bc.c:871
void cs_turbulence_bc_set_uninit_inlet_turb_intensity(cs_lnum_t face_id, double uref2, double t_intensity, double dh)
Set inlet boundary condition values for turbulence variables based on a diameter ,...
Definition: cs_turbulence_bc.c:984
void cs_turbulence_bc_rij_transform(int is_sym, cs_real_t p_lg[3][3], cs_real_t alpha[6][6])
Compute matrix used in the computation of the Reynolds stress tensor boundary conditions.
Definition: cs_turbulence_bc.c:1081
void cs_turbulence_bc_inlet_k_eps(cs_lnum_t face_id, double k, double eps)
Definition: cs_turbulence_bc.c:923
void cs_turbulence_bc_free_pointers(void)
Free memory allocations for turbulence boundary condition pointers.
Definition: cs_turbulence_bc.c:741
void cs_turbulence_bc_set_uninit_inlet_k_eps(cs_lnum_t face_id, double k, double eps, double vel_dir[], double shear_dir[])
Set inlet boundary condition values for turbulence variables based on given k and epsilon values only...
Definition: cs_turbulence_bc.c:1011
void cs_turbulence_bc_ke_hyd_diam(double uref2, double dh, double rho, double mu, double *ustar2, double *k, double *eps)
Calculation of , and from a diameter and the reference velocity for a circular duct flow with smo...
Definition: cs_turbulence_bc.c:795
void cs_turbulence_bc_init_pointers(void)
Initialize turbulence model boundary condition pointers.
Definition: cs_turbulence_bc.c:650
void cs_turbulence_bc_inlet_turb_intensity(cs_lnum_t face_id, double uref2, double t_intensity, double dh)
Definition: cs_turbulence_bc.c:899
void cs_turbulence_bc_set_uninit_inlet_hyd_diam(cs_lnum_t face_id, double vel_dir[], double shear_dir[], double uref2, double dh, double rho, double mu)
Definition: cs_turbulence_bc.c:951
double precision, dimension(nozppm), save dh
hydraulic diameter
Definition: ppincl.f90:811
double precision, dimension(ncharm), save alpha
Definition: cpincl.f90:99
