157 const int *ale_bc_type);
@ CS_ALE_LEGACY
Definition: cs_ale.h:56
@ CS_ALE_NONE
Definition: cs_ale.h:55
@ CS_ALE_CDO
Definition: cs_ale.h:57
void cs_ale_activate(void)
Activate the mesh velocity solving with CDO.
Definition: cs_ale.c:1518
void cs_ale_finalize_setup(cs_domain_t *domain)
Finalize the setup stage for the equation of the mesh velocity.
Definition: cs_ale.c:1747
int cs_glob_ale
Definition: cs_ale.c:83
void cs_ale_update_mesh(int itrale)
Update mesh in the ALE framework.
Definition: cs_ale.c:1397
void cs_ale_update_bcs(int *ale_bc_type, cs_real_3_t *b_fluid_vel)
Update ALE BCs for required for the fluid.
Definition: cs_ale.c:1477
void cs_ale_destroy_all(void)
Free the main structure related to the ALE mesh velocity solving.
Definition: cs_ale.c:1770
void cs_ale_init_setup(cs_domain_t *domain)
Setup the equations related to mesh deformation.
Definition: cs_ale.c:1577
void cs_ale_solve_mesh_velocity(int iterns, const int *impale, const int *ale_bc_type)
Solve a Poisson equation on the mesh velocity in ALE framework.
Definition: cs_ale.c:1500
void cs_ale_setup_boundaries(const cs_domain_t *domain)
Setup the equations solving the mesh velocity.
Definition: cs_ale.c:1641
bool cs_ale_is_activated(void)
Test if mesh velocity solving with CDO is activated.
Definition: cs_ale.c:1560
void cs_ale_update_mesh_quantities(cs_real_t *min_vol, cs_real_t *max_vol, cs_real_t *tot_vol)
Compute cell and face centers of gravity, cell volumes and update bad cells.
Definition: cs_ale.c:1140
void cs_ale_project_displacement(const int ale_bc_type[], const cs_real_3_t *meshv, const cs_real_33_t gradm[], const cs_real_3_t *claale, const cs_real_33_t *clbale, const cs_real_t *dt, cs_real_3_t *disp_proj)
Project the displacement on mesh vertices (solved on cell center).
Definition: cs_ale.c:1173
int cs_glob_ale_need_init
Definition: cs_defs.h:509
Definition: cs_defs.h:319
cs_real_t cs_real_3_t[3]
Definition: cs_defs.h:332
cs_real_t cs_real_33_t[3][3]
Definition: cs_defs.h:341
@ dt
integer, dimension(:), allocatable impale
indicator of imposed displacement
Definition: albase.f90:61
Definition: cs_domain.h:138
