| integer(c_int), pointer, save | iale |
| | Activates (> 0) or not (= 0), activate the ALE module: More...
| integer(c_int), save | nalinf = 0 |
| | the number of sub-iterations of initialization of the fluid More...
| integer(c_int), save | nalimx = 1 |
| | maximum number of implicitation iterations of the structure displacement More...
| real(c_double), save | epalim = 1.d-5 |
| | relative precision of implicitation of the structure displacement More...
| integer(c_int), save | italin = -999 |
| | iteration (yes=1, no=0) to initialize ALE More...
| integer, dimension(:), allocatable | impale |
| | indicator of imposed displacement More...
| integer, dimension(:), allocatable | ialtyb |
| | defines the mesh velocity from the color of the boundary faces, or more generally from their properties (colors, groups, ...), from the boundary conditions defined in cs user boundary conditions, or even from their coordinates. More...
| integer, save | fdiale |
| | Pointer to field over vertices: mesh displacement. More...
