#include "cs_defs.h"#include <assert.h>#include <ctype.h>#include <stdio.h>#include <stdlib.h>#include <string.h>#include "bft_mem.h"#include "bft_error.h"#include "cs_log.h"#include "cs_mesh_location.h"#include "cs_assert.h"#include "cs_balance_by_zone.h"#include "cs_boundary_zone.h"#include "cs_elec_model.h"#include "cs_field_default.h"#include "cs_field_operator.h"#include "cs_function.h"#include "cs_function_default.h"#include "cs_mesh_quantities.h"#include "cs_math.h"#include "cs_parameters.h"#include "cs_physical_constants.h"#include "cs_physical_model.h"#include "cs_post.h"#include "cs_rotation.h"#include "cs_thermal_model.h"#include "cs_turbomachinery.h"#include "cs_volume_zone.h"
Include dependency graph for cs_function_default.c:Functions | |
| void | cs_function_default_define (void) |
| Define functions based on code_saturne case setup. More... | |
| cs_function_t * | cs_function_define_mpi_rank_id (cs_mesh_location_type_t location_id) |
| Create or access a function for evaluation of element's MPI rank id. More... | |
| cs_function_t * | cs_function_define_refinement_generation (cs_mesh_location_type_t location_id) |
| Create or access a function for evaluation of mesh element's refinement generation (i.e. level). More... | |
| cs_function_t * | cs_function_define_boundary_stress (void) |
| Define function object for computation of boundary stress. More... | |
| cs_function_t * | cs_function_define_boundary_stress_normal (void) |
| Define function object for computation of normal boundary stress. More... | |
| cs_function_t * | cs_function_define_boundary_stress_tangential (void) |
| Define function object for computation of tangential boundary stress. More... | |
| cs_function_t * | cs_function_define_boundary_thermal_flux (void) |
| Define function object for computation of boundary thermal flux. More... | |
| cs_function_t * | cs_function_define_boundary_nusselt (void) |
| Define function for computation of boundary layer Nusselt. More... | |
| cs_function_t * | cs_function_define_q_criterion (void) |
| Define function for computation of cell Q criterion. More... | |
| void | cs_function_class_or_zone_id (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Extract optional boundary face class of element zone id. More... | |
| void | cs_function_field_boundary_nr (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Compute non-reconstructed cell-based field values at boundary. More... | |
| void | cs_function_boundary_stress (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Compute stress at boundary. More... | |
| void | cs_function_boundary_stress_normal (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Compute normal stress at boundary. More... | |
| void | cs_function_boundary_stress_tangential (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Compute tangential stress at boundary. More... | |
| void | cs_function_boundary_thermal_flux (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Compute thermal flux at boundary (in | |
| void | cs_function_boundary_nusselt (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Compute local Nusselt number near boundary. More... | |
| void | cs_function_q_criterion (int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals) |
| Compute the Q-criterion from Hunt et. al over each cell of a specified volume region. More... | |
Base predefined function objects.
| void cs_function_boundary_nusselt | ( | int | location_id, |
| cs_lnum_t | n_elts, | ||
| void * | input, | ||
| void * | vals | ||
This function matches the cs_eval_at_location_t function profile.
| [in] | location_id | base associated mesh location id |
| [in] | n_elts | number of associated elements |
| [in] | elt_ids | ids of associated elements, or NULL if no filtering is required |
| [in,out] | input | ignored |
| [in,out] | vals | pointer to output values (size: n_elts*dimension) |
| void cs_function_boundary_stress | ( | int | location_id, |
| void * | vals | ||
| void cs_function_boundary_stress_normal | ( | int | location_id, |
| void * | vals | ||
| void cs_function_boundary_stress_tangential | ( | int | location_id, |
| void * | vals | ||
| void cs_function_boundary_thermal_flux | ( | int | location_id, |
| void * | vals | ||
| void cs_function_class_or_zone_id | ( | int | location_id, |
| void * | vals | ||
For boundary faces, if no face classes have been defined by cs_boundary_zone_face_class_id the highest boundary face zone id is
For cells, the highest cell volume zone id is used.
| [in,out] | input | pointer to field |
| void cs_function_default_define | ( | void | ) |
| cs_function_t* cs_function_define_boundary_nusselt | ( | void | ) |
| cs_function_t* cs_function_define_boundary_stress | ( | void | ) |
| cs_function_t* cs_function_define_boundary_stress_normal | ( | void | ) |
| cs_function_t* cs_function_define_boundary_stress_tangential | ( | void | ) |
| cs_function_t* cs_function_define_boundary_thermal_flux | ( | void | ) |
| cs_function_t* cs_function_define_mpi_rank_id | ( | cs_mesh_location_type_t | location_id | ) |
| cs_function_t* cs_function_define_q_criterion | ( | void | ) |
| cs_function_t* cs_function_define_refinement_generation | ( | cs_mesh_location_type_t | location_id | ) |
| void cs_function_field_boundary_nr | ( | int | location_id, |
| void * | vals | ||
| void cs_function_q_criterion | ( | int | location_id, |
| void * | vals | ||
where
is the vorticity tensor and
the deviatoric of the rate of strain tensor.
