8.0
cs_function.h
1 #ifndef __CS_FUNCTION_H__
2 #define __CS_FUNCTION_H__
5  * Function objects management.
35  * Local headers
38 #include "cs_defs.h"
39 #include "cs_mesh_location.h"
40 #include "cs_param_types.h"
41 #include "cs_restart_default.h"
46
48  * Macro definitions
50
57 /*
58  * Function property type
59  */
60
62 #define CS_FUNCTION_INTENSIVE (1 << 0)
63
65 #define CS_FUNCTION_EXTENSIVE (1 << 1)
66
68 #define CS_FUNCTION_TIME_INDEPENDENT (1 << 2)
69
71 #define CS_FUNCTION_USER (1 << 3)
72
75 /*============================================================================
76  * Type definitions
77  *============================================================================*/
78
79 /*----------------------------------------------------------------------------*/
103 /*----------------------------------------------------------------------------*/
104
105 typedef void
106 (cs_eval_at_location_t) (int location_id,
107  cs_lnum_t n_elts,
108  const cs_lnum_t *elt_ids,
109  void *input,
110  void *vals);
111
112 /* Function descriptor */
113 /*---------------------*/
114
115 typedef struct {
116
117  const char *name;
118  char *label;
121  const int id;
122  int type;
124  const int dim;
127  const int location_id;
131  int post_vis;
135  int log;
154  void *func_input; /* Pointer to optional (untyped)
155  value or structure, for use by
156  evaluation function */
157
158 } cs_function_t;
159
160 /*=============================================================================
161  * Global variables
162  *============================================================================*/
163
164 /*============================================================================
165  * Public function prototypes
166  *============================================================================*/
167
168 /*----------------------------------------------------------------------------*/
187 /*----------------------------------------------------------------------------*/
188
190 cs_function_define_by_func(const char *name,
191  int location_id,
192  int dim,
193  bool is_intensive,
194  cs_datatype_t datatype,
195  cs_eval_at_location_t *data_func,
196  void *data_input);
197
198 /*----------------------------------------------------------------------------*/
218 /*----------------------------------------------------------------------------*/
219
221 cs_function_define_by_analytic_func(const char *name,
222  int location_id,
223  int dim,
224  bool is_intensive,
225  cs_analytic_func_t *data_func,
226  void *data_input);
227
228 /*----------------------------------------------------------------------------*/
248 /*----------------------------------------------------------------------------*/
249
251 cs_function_define_by_dof_func(const char *name,
252  int location_id,
253  int dim,
254  bool is_intensive,
255  cs_dof_func_t *data_func,
256  void *data_input);
257
258 /*----------------------------------------------------------------------------
259  * Destroy all function management metadata.
260  *----------------------------------------------------------------------------*/
261
262 void
264
265 /*----------------------------------------------------------------------------*/
271 /*----------------------------------------------------------------------------*/
272
273 int
275
276 /*----------------------------------------------------------------------------*/
286 /*----------------------------------------------------------------------------*/
287
289 cs_function_by_id(int id);
290
291 /*----------------------------------------------------------------------------*/
301 /*----------------------------------------------------------------------------*/
302
304 cs_function_by_name(const char *name);
305
306 /*----------------------------------------------------------------------------*/
316 /*----------------------------------------------------------------------------*/
317
319 cs_function_by_name_try(const char *name);
320
321 /*----------------------------------------------------------------------------*/
328 /*----------------------------------------------------------------------------*/
329
330 void
332  const char *label);
333
334 /*----------------------------------------------------------------------------*/
338 /*----------------------------------------------------------------------------*/
339
340 void
342
343 /*----------------------------------------------------------------------------*/
348 /*----------------------------------------------------------------------------*/
349
350 void
352
353 /*----------------------------------------------------------------------------*/
370 /*----------------------------------------------------------------------------*/
371
372 void
374  const cs_time_step_t *ts,
375  int location_id,
376  cs_lnum_t n_elts,
377  const cs_lnum_t *elt_ids,
378  void *vals);
379
380 /*----------------------------------------------------------------------------*/
381
383
384 #endif /* __CS_FUNCTION_H__ */
cs_datatype_t
Definition: cs_defs.h:272
Definition: cs_defs.h:509
Definition: cs_defs.h:313
cs_function_t * cs_function_define_by_func(const char *name, int location_id, int dim, bool is_intensive, cs_datatype_t datatype, cs_eval_at_location_t *data_func, void *data_input)
Define a function whose data values will be computed using the provided evaluation function.
Definition: cs_function.c:303
void() cs_eval_at_location_t(int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *input, void *vals)
Function pointer for evaluation of local function values.
Definition: cs_function.h:106
cs_function_t * cs_function_define_by_analytic_func(const char *name, int location_id, int dim, bool is_intensive, cs_analytic_func_t *data_func, void *data_input)
Define a function whose data values will be computed using the provided "degree of freedom" type eval...
Definition: cs_function.c:346
cs_function_t * cs_function_by_name_try(const char *name)
Return a pointer to a function object based on its name if present.
Definition: cs_function.c:511
void cs_function_set_label(cs_function_t *f, const char *label)
Assig a label to a function object.
Definition: cs_function.c:531
cs_function_t * cs_function_by_name(const char *name)
Return a pointer to a function object based on its name.
Definition: cs_function.c:485
void cs_function_log_defs(void)
Log function definition setup information.
Definition: cs_function.c:545
void cs_function_evaluate(const cs_function_t *f, const cs_time_step_t *ts, int location_id, cs_lnum_t n_elts, const cs_lnum_t *elt_ids, void *vals)
Evaluate function values.
Definition: cs_function.c:787
void cs_function_log_all_settings(void)
Print info relative to all given function object settings to log file.
Definition: cs_function.c:693
cs_function_t * cs_function_define_by_dof_func(const char *name, int location_id, int dim, bool is_intensive, cs_dof_func_t *data_func, void *data_input)
Definition: cs_function.c:388
cs_function_t * cs_function_by_id(int id)
Return a pointer to a function object based on its id.
Definition: cs_function.c:461
int cs_function_n_functions(void)
Return the number of defined functions.
Definition: cs_function.c:443
void cs_function_destroy_all(void)
Destroy all functions management metadata.
Definition: cs_function.c:414
void() cs_dof_func_t(cs_lnum_t n_elts, const cs_lnum_t *elt_ids, bool dense_output, void *input, cs_real_t *retval)
Definition: cs_param_types.h:154
cs_restart_file_t
Definition: cs_restart_default.h:54
char * label
Definition: keywords.h:71
Definition: cs_function.h:115
cs_dof_func_t * dof_func
Definition: cs_function.h:151
const cs_datatype_t datatype
Definition: cs_function.h:129
int log
Definition: cs_function.h:135
cs_eval_at_location_t * eval_func
Definition: cs_function.h:147
const int id
Definition: cs_function.h:121
int post_vis
Definition: cs_function.h:131
const char * name
Definition: cs_function.h:117
cs_restart_file_t restart_file
Definition: cs_function.h:142
int type
Definition: cs_function.h:122
char * label
Definition: cs_function.h:118
Definition: cs_function.h:127
int time_stamp
Definition: cs_function.h:139
cs_analytic_func_t * analytic_func
Definition: cs_function.h:149
void * func_input
Definition: cs_function.h:154
const int dim
Definition: cs_function.h:124
time step descriptor
Definition: cs_time_step.h:64
