7.3
cs_lagr_sde.c File Reference
#include "cs_math.h"
#include "cs_prototypes.h"
#include "cs_random.h"
#include "cs_thermal_model.h"
#include "cs_lagr.h"
#include "cs_lagr_adh.h"
#include "cs_lagr_deposition_model.h"
#include "cs_lagr_event.h"
#include "cs_lagr_tracking.h"
#include "cs_lagr_sde.h"
+ Include dependency graph for cs_lagr_sde.c:
static void _add_resuspension_event (cs_lagr_event_set_t *events, cs_lagr_particle_set_t *particles, cs_lnum_t p_id, cs_lnum_t face_id, const cs_real_t particle_velocity[3])
 Add a resulspension event. More...
static void _lages1 (cs_real_t dtp, const cs_real_t taup[], const cs_real_3_t tlag[], const cs_real_3_t piil[], const cs_real_33_t bx[], const cs_real_33_t vagaus[], const cs_real_t brgaus[], const cs_real_3_t force_p[], const cs_real_3_t beta[], cs_real_t *terbru)
 Integration of SDEs by 1st order time scheme. More...
static void _lages2 (cs_real_t dtp, const cs_real_t taup[], const cs_real_3_t tlag[], const cs_real_3_t piil[], const cs_real_33_t bx[], cs_real_t tsfext[], const cs_real_33_t vagaus[], const cs_real_t brgaus[], const cs_real_3_t force_p[], cs_real_t *terbru)
 Integration of SDEs by 2nd order scheme. More...
static void _lagesd (cs_real_t dtp, cs_lnum_t ip, const cs_real_t taup[], const cs_real_3_t piil[], const cs_real_33_t vagaus[], const cs_real_t romp[], const cs_real_3_t force_p[], cs_real_t tempf, const cs_real_t vislen[], cs_lagr_event_set_t *events, cs_real_t *depint, cs_lnum_t *nresnew)
 Deposition submodel. More...
static void _lagdep (cs_real_t dtp, const cs_real_t taup[], const cs_real_3_t tlag[], const cs_real_3_t piil[], const cs_real_33_t bx[], const cs_real_33_t vagaus[], const cs_real_t romp[], const cs_real_3_t force_p[], const cs_real_t vislen[], cs_lnum_t *nresnew)
void cs_lagr_sde (cs_real_t dt_p, const cs_real_t taup[], const cs_real_3_t tlag[], const cs_real_3_t piil[], const cs_real_33_t bx[], cs_real_t tsfext[], const cs_real_3_t gradpr[], const cs_real_33_t gradvf[], cs_real_t terbru[], const cs_real_t vislen[], const cs_real_3_t beta[], cs_lnum_t *nresnew)
 Integration of particle equations of motion: More...
void cs_lagr_sde_attr (cs_lagr_attribute_t attr, cs_real_t *tcarac, cs_real_t *pip)
 Integration of a stochastic differential equation (SDE) for a user particle variable (attribute). More...
◆ _add_resuspension_event()
static void _add_resuspension_event ( cs_lagr_event_set_t events,
cs_lagr_particle_set_t particles,
cs_lnum_t  p_id,
cs_lnum_t  face_id,
static
TODO add additional info to events.
[in]eventspointer to events set
[in]particlespointer to particle set
[in]p_idparticle id
[in]face_idassociated face id
[in]particle_velocityvelocity after event
◆ _lagdep()
static void _lagdep ( cs_real_t  dtp,
cs_lnum_t nresnew
static
Main subroutine of the submodel 1/ Calculation of the normalized wall-normal distance of the boundary-cell particles 2/ Sorting of the particles with respect to their normalized wall-normal distance
  • If y^+ > depint : the standard Langevin model is applied
  • If y^+ < depint : the deposition submodel is applied
[in]dtptime step
[in]taupdynamic characteristic time
[in]tlagfluid characteristic time
[in]piilterm in integration of UP SDEs
[in]bxturbulence characteristics
[in]vagausgaussian random variables
[in]rompparticles associated density
[in]force_ptaup times forces on particles (m/s)
[in]vislenFIXME
◆ _lages1()
static void _lages1 ( cs_real_t  dtp,
cs_real_t terbru
static
[in]dtptime step
[in]tlaglagrangian fluid characteristic time
[in]bxcaracteristiques de la turbulence
[in]brgausgaussian random variables
[in]betaproportional to the gradient of T_lag
[out]terbruDiffusion coefficient accounting for Brownian (molecular) effect
◆ _lages2()
static void _lages2 ( cs_real_t  dtp,
cs_real_t  tsfext[],
cs_real_t terbru
static
When there has beed interaction with a boundary face, the velocity and velocity seen computations are forced to 1st order.
[in]tauptemps caracteristique dynamique
[in]tlagtemps caracteristique fluide
[in]piilterme dans l'integration des eds up
[in]tsfextinfos pour couplage retour dynamique
[in]vagausvariables aleatoires gaussiennes
[in]brgausgaussian variable for brownian movement
[in]rompmasse volumique des particules
[out]terbru
◆ _lagesd()
static void _lagesd ( cs_real_t  dtp,
cs_lnum_t  ip,
cs_real_t  tempf,
cs_real_t depint,
cs_lnum_t nresnew
static
1/ Modification of the coordinate system (global ->local) 2/ Call of subroutine lagcli 3/ Integration of the stochastic differential equations in the 2 directions different from the normal to the boundary face 4/ Modification of the coordinate system (local ->global) 5/ Update of the particle position
[in]dtptime step
[in]ipparticle id
[in]tempftemperature of the fluid (K)
[in]vislenFIXME
[in]eventsassociated events set
[in]depintinterface location near-wall/core-flow
◆ cs_lagr_sde()
void cs_lagr_sde ( cs_real_t  dt_p,
cs_real_t  tsfext[],
cs_real_t  terbru[],
cs_lnum_t nresnew
  • Standard Model : First or second order
  • Deposition submodel (Guingo & Minier, 2008) if needed
[in]dt_plagrangian time step
[in]piilterm in integration of U-P SDEs
[out]tsfextinfo for return coupling source terms
[in]gradprpressure gradient
[in]gradvffluid velocity gradient
[in]vislennu/u* = y/y+
◆ cs_lagr_sde_attr()
void cs_lagr_sde_attr ( cs_lagr_attribute_t  attr,
cs_real_t tcarac,
cs_real_t pip
\[ \frac{dV}{dt} = \frac{V - PIP}{TCARAC} \]
When there is interaction with a boundary face, the integration degenerates to order 1 (even if the 2nd order scheme is active).
[in]attrattribute/variable
[in]tcaracvariable characteristic time
[in]pipright-hand side associated with SDE
