#include "cs_defs.h"#include <stdio.h>#include <stdlib.h>#include <math.h>#include <float.h>#include <assert.h>#include <string.h>#include <bft_mem.h>#include "cs_boundary_zone.h"#include "cs_cdo_advection.h"#include "cs_cdo_assembly.h"#include "cs_cdo_bc.h"#include "cs_cdo_diffusion.h"#include "cs_hho_builder.h"#include "cs_hodge.h"#include "cs_log.h"#include "cs_math.h"#include "cs_mesh_location.h"#include "cs_post.h"#include "cs_quadrature.h"#include "cs_reco.h"#include "cs_scheme_geometry.h"#include "cs_search.h"#include "cs_sdm.h"#include "cs_source_term.h"#include "cs_hho_vecteq.h"
Include dependency graph for cs_hho_vecteq.c:Macros | |
| #define | CS_HHO_VECTEQ_DBG 0 |
| static cs_cell_builder_t * | _cell_builder_create (cs_param_space_scheme_t space_scheme, const cs_cdo_connect_t *connect) |
| Initialize the local builder structure used for building the system cellwise. More... | |
| static void | _vhho_init_cell_system (const cs_cell_mesh_t *cm, const cs_equation_param_t *eqp, const cs_equation_builder_t *eqb, const cs_hho_vecteq_t *eqc, cs_hho_builder_t *hhob, cs_cell_sys_t *csys, cs_cell_builder_t *cb) |
| Initialize the local structures for the current cell. Case of vector-valued HHO schemes. More... | |
| static void | _condense_and_store (const cs_adjacency_t *c2f, cs_hho_vecteq_t *eqc, cs_cell_builder_t *cb, cs_cell_sys_t *csys) |
| Proceed to a static condensation of the local system and keep information inside the builder to be able to compute the values at cell centers. More... | |
| void | cs_hho_vecteq_init_sharing (cs_flag_t scheme_flag, const cs_cdo_quantities_t *quant, const cs_cdo_connect_t *connect, const cs_time_step_t *time_step) |
| Allocate work buffer and general structures related to HHO schemes Set shared pointers. More... | |
| void | cs_hho_vecteq_get (cs_cell_sys_t **csys, cs_cell_builder_t **cb, cs_hho_builder_t **hhob) |
| void | cs_hho_vecteq_finalize_sharing (void) |
| Free buffers and generic structures related to HHO schemes. More... | |
| void * | cs_hho_vecteq_init_context (const cs_equation_param_t *eqp, int var_id, int bflux_id, cs_equation_builder_t *eqb) |
| Initialize a cs_hho_vecteq_t structure storing data useful for managing such a scheme. More... | |
| void * | cs_hho_vecteq_free_context (void *data) |
| Destroy a cs_hho_vecteq_t structure. More... | |
| void | cs_hho_vecteq_init_values (cs_real_t t_eval, const int field_id, const cs_mesh_t *mesh, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Set the initial values of the variable field taking into account the boundary conditions. Case of vector-valued HHO schemes. More... | |
| void | cs_hho_vecteq_compute_source (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data) |
| Compute the contributions of source terms (store inside builder) More... | |
| void | cs_hho_vecteq_build_system (const cs_mesh_t *mesh, const cs_real_t *field_val, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| Build the linear system arising from a scalar convection/diffusion equation with a HHO scheme. One works cellwise and then process to the assembly. More... | |
| void | cs_hho_vecteq_update_field (const cs_real_t *solu, const cs_real_t *rhs, const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *data, cs_real_t *field_val) |
| Store solution(s) of the linear system into a field structure Update extra-field values required for hybrid discretization. More... | |
| cs_real_t * | cs_hho_vecteq_get_face_values (void *data, bool previous) |
| Get the computed values at faces (DoF used in the linear system are located at primal faces) More... | |
| cs_real_t * | cs_hho_vecteq_get_cell_values (void *data, bool previous) |
| Get the computed values at cells (DoF used in the linear system are located at primal faces) More... | |
| void | cs_hho_vecteq_read_restart (cs_restart_t *restart, const char *eqname, void *scheme_context) |
| void | cs_hho_vecteq_write_restart (cs_restart_t *restart, const char *eqname, void *scheme_context) |
| void | cs_hho_vecteq_extra_post (const cs_equation_param_t *eqp, cs_equation_builder_t *eqb, void *context) |
| static cs_cell_sys_t ** | cs_hho_cell_sys = NULL |
| static cs_cell_builder_t ** | cs_hho_cell_bld = NULL |
| static cs_hho_builder_t ** | cs_hho_builders = NULL |
| static const cs_cdo_quantities_t * | cs_shared_quant |
| static const cs_cdo_connect_t * | cs_shared_connect |
| static const cs_time_step_t * | cs_shared_time_step |
| #define CS_HHO_VECTEQ_DBG 0 |
static |
| [in] | space_scheme | discretization scheme |
static |
| [in] | c2f | pointer to a cs_adjacency_t structure |
| [in,out] | eqc | pointer to a cs_hho_vecteq_t structure |
static |
| [in] | eqc | pointer to a cs_hho_vecteq_t structure |
| [in,out] | hhob | pointer to a cs_hho_builder_t structure |
| void cs_hho_vecteq_build_system | ( | const cs_mesh_t * | mesh, |
| const cs_real_t * | field_val, | ||
| void * | context | ||
| [in] | field_val | pointer to the current value of the field |
| [in,out] | context | pointer to cs_hho_vecteq_t structure |
| void cs_hho_vecteq_compute_source | ( | const cs_equation_param_t * | eqp, |
| void * | data | ||
| [in,out] | data | pointer to a cs_hho_vecteq_t structure |
| void cs_hho_vecteq_extra_post | ( | const cs_equation_param_t * | eqp, |
| void cs_hho_vecteq_finalize_sharing | ( | void | ) |
| void* cs_hho_vecteq_free_context | ( | void * | data | ) |
| void cs_hho_vecteq_get | ( | cs_cell_sys_t ** | csys, |
| cs_cell_builder_t ** | cb, | ||
| cs_hho_builder_t ** | hhob | ||
| [out] | hhob | pointer to a pointer on a cs_hho_builder_t structure |
| cs_real_t* cs_hho_vecteq_get_cell_values | ( | void * | data, |
| bool | previous | ||
| [in,out] | data | pointer to a data structure cast-on-fly |
| cs_real_t* cs_hho_vecteq_get_face_values | ( | void * | data, |
| void* cs_hho_vecteq_init_context | ( | const cs_equation_param_t * | eqp, |
| int | var_id, | ||
| int | bflux_id, | ||
| void cs_hho_vecteq_init_sharing | ( | cs_flag_t | scheme_flag, |
| [in] | scheme_flag | flag to identify which kind of numerical scheme is requested to solve the computational domain |
| [in] | quant | pointer to a cs_cdo_quantities_t struct. |
| [in] | ms0 | pointer to a cs_matrix_structure_t struct. (P0) |
| [in] | ms1 | pointer to a cs_matrix_structure_t struct. (P1) |
| [in] | ms2 | pointer to a cs_matrix_structure_t struct. (P2) |
| void cs_hho_vecteq_init_values | ( | cs_real_t | t_eval, |
| const int | field_id, | ||
| void cs_hho_vecteq_read_restart | ( | cs_restart_t * | restart, |
| const char * | eqname, | ||
| void cs_hho_vecteq_update_field | ( | const cs_real_t * | solu, |
| void * | data, | ||
| [in,out] | data | pointer to cs_hho_vecteq_t structure |
| void cs_hho_vecteq_write_restart | ( | cs_restart_t * | restart, |
static |
static |
static |
static |
static |
static |
